Question about Quantum SuperLoader 3 LTO 2 Tape Drive
Errors on drive, 0x23
Tape 5 is in the drive (not the magazine), and I can't eject it. The display is showing "Timeout Error 0x23, Cycle Power" and BackupExec 11d indicates that it is offline. Please help, I haven't had a backup in 3 days!
  • CI_19720 Mar 11, 2008
    Forget it. This site is a useless waste of time.... just a front to get you to pay for "premium service".
    http://www.experts-exchange.com is much better.
2 Suggested Answers
JaxPlanet
  • 922 Answers
SOURCE: Quantum ATL SuperLoader
If you cannot physically load a tape into the drive it is a hardware problem and the drive requires service. It is not a software problem.
Of course, the library could already have the maximum tapes it can hold. If this is the case then eject a tape from the library to make room for the tape you want to add.
I hope this helps.
Posted on Aug 11, 2009
When the cam is put on recordning mode a error on the screen shows the following- eject sign followed by ...D , On top on screen its written EJECT LP
The error display shows that the camcorder has some mechanical fault.Follow the instructions below.
1. Eject the Tape
2. Set to OFF
3. Detach the battery
4. Reattach the battery
5. Power ON as usual
Simple faults will be recovered when performing the above procedure.Good Luck
Jun 04, 2011 | Samsung VP-D361 Mini DV Digital Camcorder
Tip
Ejecting magazines from the LTO3
If you need to remove a magazine or both, you can always stick a credit card or hotel room card between the slot on either the left or right of the LTO3 display, this will disengage the lock allowing for one or both magazines to open. Normally you can only remove one magazine at a time.
on Jul 20, 2009 | Quantum SuperLoader 3 LTO-3 Tape Drive
Problem with the Samsung Washing Machines The machine keeps coming up with the message HEI 10x
Here is a list of errors for your machine.
I hope they help you.
SAMSUNG WASHING MACHINES, ERROR FUNCTIONS
When an error occurs, the alarm noise will sound and the error code displayed in the program window. Listed below is a series of error codes you may or may not see for your model of Samsng Washing Machine. The errors are shown as blinking in O.5 second intervals until the error status has cleared. In this case, all the driving devices are turned off until the error is cleared.
1. WATER SUPPLY ERROR - Display shows 4E.
Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the preset water level after 10 Minutes or more at the time of initial water supply. The error status can be cleared by turning the POWER switch OFF and back ON.
2. WATER DRAIN ERROR - Display shows 5E.
5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
3. OVER-FLOW ERROR - Display shows oE.
Over-Flow error occurs when the water level is too high. It can be cleared by turning POWER switch OFF. Water is drained prior to POWER switch OFF. The tub is drained for 2 minutes if a frequency of more than 25 KHz is detected.
4. UNBALANCE ERROR - Display shows UE.
Laundry load is unbalanced, manually loosen any tangled laundry.
If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
5. WATER HEATER ERROR - Display shows HE, HE1.
HE, HE1 is displayed if the water temperature rises by 7 C or more in 1 Min or by 2 C or less 20 Min after heating process has started. The error can be cleared by turning POWER switch OFF.
6. WATER PRESSURE SWITCH ERROR - Display shows 1 E.
* Generated Frequency Signal of WATER LEVEL (WIL) SIW (KHz)
Normal Level = Abnormal W/L Frequency
Low Level = 30.00 Khz
High Level = 15.00 Khz
If the same signal is detected for more than 5 seconds, it is a PRESSURE SWITCH Error. When this error occurs the drain pump will operate for 3 min. and the display will show 1 E indicating a pressure switch error.
7. ABNORMAL WATER TEMPERATURE ERROR- Display shows cE.
e.g. If the water temperature is 50 C or more, during a Delicate or Wool cycle.
At the time of initial water supply, if the water temperature is not appropriate, the display will show cE. This error can be cleared by POWER SWITCH OFF.
8. WATER LEAKAGE ERROR - Display shows 11 E.
Water Leakage error occurs when the water drains naturally, (by leakage) after the washing program starts.
9. THERMISTOR ERROR - Display shows tE
Nov 21, 2010 | Washing Machines
I can't remove the left magazine from a Superloader 3. The unit has failed and I need to remove the tapes. The eject magazine does not work, it doesn't pull the drive gear back.
I found this solution on line and it worked for me. Believe it or not I used a butter knife and stuck it between the magazine and mail slot close to the bottom. You will hear a click and the magazine will pop out. It is like using a paperclip for a stuck CD. Make sure you power the device down and unplug it.
Oct 01, 2010 | Quantum SuperLoader 3 LTO-3 Tape Drive
My 2001 Landcruiser will not play dvd/cd. It gets
I have the same exact problem:2001 Landcruiser will not play dvd/cd. It gets stuck. Display of dvd error shows. DVD can not eject. Please let me know if you got it to eject. I tried disconnect/connect the battery for full 5 minutes but did not help.
Apr 20, 2010 | 2001 Toyota Land Cruiser
My eurovox radio/cd/tape player displays error message E-99 when i switch to cd
E99 RESET PROCEDURE:
Remove CD magazine by pressing eject button on changer.
Remove all discs from magazine and re-load empty magazine into
changer. Using the Radio RESET CD system by pressing and
holding the “ON”/”POWER” button for about ten seconds, or in
earlier models the “EJECT/6” button.
Oct 03, 2009 | Car Audio & Video
Elem Table Bad (2B) error
The element error usually points to the drive, the best thing is to do is run the full diagnostics for the drive, and see what other hardware codes you receive, if it still points to 2b, then it is either the drive or the solenoid of the magazine failing. If you have a two magazine setup, just reverse the other magazine and test it that way.
Apr 16, 2009 | Quantum SuperLoader 3 LTO-3 Tape Drive
Tape stuck in drive
The best way that I have solved this is by using the move commands from the drive, and move it from drive to any free tape slot. Also if that does not work, put a few tapes in the drive and perform the random moves test in diagnostics, that will fool the drive to move the tape.
Jan 29, 2009 | Quantum SuperLoader 3 LTO-3 Tape Drive
Getting error message "Bad element"
you have to open the bottom and turn the motor or gears , just be sure to turn the cartridge gears too to wind the tape back in
Jan 18, 2008 | Quantum SuperLoader 3 LTO-3 Tape Drive
Quantum SuperLoader 3 LTO 2 Tape Drive Logo
340 people viewed this question
Top Quantum Computers & Internet Experts
Tape-Techie
SirEbrum
terminalcon
Are you a Quantum Computer and Internet Expert? Answer questions, earn points and help others
