Question about Dryers
Dryer wont run
My wife dryed 1 load and loaded another, when she hit the start switch nothing happened, the light is on in the drum, and i can hear the timer running, any ideas ?
  • taky1 Mar 21, 2008
    Whirlpool duet steam electric dryer dried one load but when i pushed the start button it wouldn't start to dry the next.  All the lights come on in response but nothing happens.  I tried all the trouble shooting suggestions but nothing helped.
I had the same problem. It was the door switch. cost me about 8 bucks to fix.
Posted on Jan 17, 2009
  • 30 Answers
My best guess is a faulty start switch. Use your model number on www3.sears.com to get a price estimate of the start switch button and to see if your local Sears Parts store carries it. NOTE: The part number can also be used at any other appliance parts store.
Posted on Mar 08, 2008
I have the LG Model# DLE1101W dryer. The dryer will power up but when I go to start the dryer after I put a second load in, I get a series of dinging sounds when pressing the start button and the drye
Id like to see if I could help you so you will have to use more definitive terms, "Start" I'm guessing that you mean that the drum doesn't turn? (the lights come on and you push the start button and the drum does not turn) If that's the case I would start with the door switch, Best to start with the most obvious first. Try jumping it to over ride wait your response
Sep 17, 2014 | LG DLE1101W 7.3 cu. ft. Ultra Large...
When i push the start button i can hear and feel the timer working yet nothing else happens. when i release the start button the timer quits working.door switch is working. i've checked all the connectors...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 06, 2010 | Kenmore Dryers
Dryer won't start up
Ok, you have one of two problems.
  1. A bad thermal fuse and cut off. They are located inside on the dust. They are round (Nickel size) and have two wires.
  2. A bad element. Located inside the shoot.
Either one of these will cause what your sayiing. You also nee to check the vent. This will make the parts on #1 go out.
Oct 09, 2009 | Kenmore Dryers
Whirlpool Electric dryer won't start
Your problem sounds like it could be a broken belt, faulty motor, or maybe the belt has slipped off of the motor or idler arm pulley.
You can try this first:
Uplug the dryer, reach inside and try to turn the drum 1/4 to 1/2 turn, the plug the dryer back in, and push the start button. Sometimes motors will get dead zones in them and this will move it from that zone.
If you attempt the repair, and if you have a front loading machine, you would remove the front of the machine, this will expose the drum and belt, you can now check the belt to see if it is ok. If it is ok, then you can remove the drum and belt and this will expose the motor, idler arm with pulley and drum rollers.
While you have the drum out of there it is a good time to check the condition of the drum rollers to see if they have flat spots on them, if they do have flat spots on them, then need to be replaced. If not then I recommend that you lubricate them at the shaft with a good grade of Machine Oil such as 3 in One oil. This will save problems later.
Good luck,
I hope this helps you
Oct 04, 2009 | Whirlpool LER5636P Electric Dryer
Kenmore 90 Series Electric Dryer will not run
chech to see if your belt is broken. It may have a belt switch
Oct 28, 2008 | Kenmore 62602 Electric Dryer
Dryer stopped running, will not restart
When you try to restart do you hear a motor running? If you do hear that sound and the dryer does not turn your belt could be the problem. (broken)
May 26, 2008 | Maytag Atlantis MDG8400AW Gas Dryer
Whirlpool Model LG7681ZSN1
check the door switch if it is working then a broken belt can cause this problem let me know how you make out
Sep 13, 2007 | Whirlpool LGB6000KQ Gas Dryer
Dryers Logo
96 people viewed this question
Top Dryers Experts
Marvin
Marvin
