Question about Maytag Refrigerators
Lights blinking and ice door flopping - Maytag Refrigerators
  • 3 Answers
Call (800) 688-9900. This number will send you to the Whirlpool call center. They recently bought out Maytag. This is a common problem with a board in the back of the fridge. This happened to me over the weekend. I called this morning, and they are sending the part overnight, and the tech is scheduled for the day following. As for a temp solution to the flapping noise (which is very annoying) there are two solutions. 1. You can put a small towel through the opening to muffle the sound. 2. You can tape the opening open using box tape or duck tape.
Posted on Mar 17, 2008
Kenmore elite refrigerator
Check the door switch by depressing it with your finger. maybe not making contact that well with the door ?
Dec 12, 2013 | Refrigerators
The on the door blink off and on and the flapper where the ice cubes are discharged clunks and the lights blink. The only thing I have done is unplug and leave off for five minutes and then plug back...
It will be much better if you leave it switched off for a couple of hours. I believe there is excess ice build up inside the ice maker which has frozen up the tilting mechanism. Letting this ice melt away should solve this problem
Jan 11, 2011 | Amana AFB2534DE Bottom Freezer French Door...
Lights on panel blinking. ice dispenser keeps opening and closing
there is the HV board on the back under a cover . 2 680uf capacitors @ 35v are likely domed instead of flat on the top and are likely hot. replacing these with an equal value will cure the problem. they are in parallel so 1000 and 470uf will cure it. mine was same model except white. local dealer said no warranty. did not call maytag but he indicated it might help. good luck
Jun 02, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
My GE PSS26SGRSS is not working. The panel lights are blinking.
Problem is the circut board in the back, you can go to ge appliances.com go to service and support type in model# go to unit and main board parts to order.
Nov 14, 2008 | GE PSS26SGRSS Stainless Steel Side by Side...
Removal of ice dispensing mechanism from freezer door
The Ice chute door is seems to be broken. It doesn't open when the Ice is coming through the ice shoot. The Ice chute door just flops around in the ice shoot.
May 03, 2008 | Refrigerators
Maytag MF12568AEB refrigerator
the high voltage control board is bad. located on rear of machine.
Feb 15, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Exterior lights blink, ice door opens and closes on own?
im honing my psychic powers here, it a french door bottom freezer right?? Its built by samsung and the High Voltage board has failed. Had the same problem with one here
Sep 28, 2007 | Maytage MSD2652KE 26 cu. ft. Side-By-Side...
Refrigerators Logo
154 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
