Question about RCA P60920BL 60" Rear Projection Television
TV set Well, I replaced the fuse, set still wont power on. Thanks for the tips though.
  • RCA Master
  • 8,617 Answers
Youre welcome if you had some trouble shooting skills I could try help you diagnose it. But TVs are dangerous without some troubleshooting experience.
Posted on Mar 07, 2008
55pfl5706/f7 wont power on
If the display panel has failed, it will be best to buy a new TV, rather than trying to make it repaired.
Aug 22, 2013 | Televison & Video
Samsung HCM653W 65 in rear projection tv
its the convergence board/bulb problem for sure.check that and replace it.every thing will be fine.thanks.
Aug 22, 2008 | Samsung HCM653W 65" Rear Projection...
Where is My Philips 32pfl3505d f7 LCD TV fuses
I assume you are referring to the ac fuse, it is located on the power supply board. Just follow the ac power cord and it should lead you to it. If your set doesn't have a built in power cord, the fuse will be next to the power cord connector.
Sep 01, 2012 | Philips 32PFL3505D 32 in LCD TV
BPL TV NOT STARTING
if no any power indicator that light or even blinking, the first place to be check will be the power supply section you must check weather the fuse is blown.if the fuse is blown before you replaced with new one you need to check other component in the power supply section like transistor and diode. so this case need proper trouble shooting, if you think you don't have enough idea in any electronic repair just leave it to the trained tv technician.
Aug 12, 2012 | Televison & Video
Why wont my westinghouse tv turn on even though it shows that it has power?
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.5_30_2012_1_32_20_pm.jpg
May 29, 2012 | Westinghouse Lvm42w2 42 1080p Lcd Tv no...
LG 42PQ30 plasma tv wont turn on anymore, when you plug the tv in it makes a click noise and when you hit the power button the blue light comes on then changes to red after couple seconds. Note the...
ISSUES:
Answers to issues:
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.5_15_2012_1_19_09_pm.jpg
May 15, 2012 | LG 42PQ30 42 in. Plasma TV
Hello my heater tipped over and wont heat now even though the lights are still on at the swiches thanks
It may be short in your heating element. Check power to heater element. If yes, replace heater element. Helpful?
Jan 20, 2011 | Heating & Cooling
My lcd tv does not start though i switched on the button. pl help
Problem :
Tv wont turn on
Solution:
Undo the back, check in the power supply area any blow fuse or bad capacitor.
be careful when and replace with the exact replacement of any burned part
please rate my solution
Aug 20, 2010 | Samsung Televison & Video
TV won't power up and blows the fuse
A 10 year old RCa most likly has a bad Horizontal output transistor as well as the main High Voltage transformer and The transformer is no lonmger available from RCA. The replacement wont last longer then a year if your lucky. My advice on a set this old ?? Buy a newer one!!
Sep 11, 2006 | RCA F35670MB 35" TV
Av32D104 JVC Television Wont turn on , Has power to light on front that reads "auto timer" what now?
Unplug the tv set for 30 seconds, plug back in and turn set on, if its wont fix the problem, and you're NOT under warranty you should at least open the TV and look for a blown fuse near where the power cable enters the set. A lot of times you can buy replacement fuses at a local electronic or hardware store and they're easy to replace. Check the fuse. If it is blown, it will be obvious and make sure that the set is unplugged before replacing it. If it blows again, or if it is not blown, your problem is probably in the 'X' volt regulator and you will need professional help with the repairs. You can also check the board where the components are mounted and resoled any that look bad. Brief power outages may cause the TV to turn off on its own. If you are using a surge protector, try connecting the set directly to the wall outlet. In your case it could caused by a blown fuse, a leaky diodes or a bad solder joint at the horizontal drive transformer. All can be replaced at a local electronic or hardware store and they're easy to replace If this does not correct the problem, you may need to have your TV serviced. good luck!
Jan 05, 2006 | JVC AV-32D104 32" TV
Televison & Video Logo
50 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
