Question about DeLonghi Retro DCG59 Electric Burr Grinder
Won't come on?
I have a new DeLonghi (DCG59) and used it twice. However, it will not come on. It appears that something is not making electical contact.
Jon
I just bought a brand new unit and as recommended I unscrewed the top bean hopper and the coffee ground container-cleaned and wiped.After that I screwed back everything and tried to grind some beans.The timer was ticking away but the grinder just refused to start.I switched off the main and unscrewed the hopper and carefully screwed it back.Halfway through,I noticed and felt that you must balanced and screwed it with a smooth movement until the the whole piece is in place.The grinder just started without a hitch.This grinder has a protection circuit whereby if any part is not properly installed it will not start.
Posted on Aug 17, 2008
How can i fix the hot milk function on delonghi coffee machine?
The voice from the grinder ??
If so that's men you pushed the cappatino
Try to push the same button twice you will read
Further and steemar
Apr 06, 2015 | DeLonghi Magnifica Coffee Makers &...
There appears to be a screw up inside where the filter holder goes that won't allow the filter holder to be turned! Is it defective or am I doing something wrong??
U.S. Residents:
Please contact toll free hotline at 1-800-322-3848 or log onto website at www.delonghi.com.
For all accessories, spare parts or replacement parts, please contact parts division at 1-800-865-6330.
Residents of Canada:
Please contact toll free hotline at 1-888-335-6644 or log onto website at www.delonghi.com.
Jul 08, 2014 | DeLonghi EC155 Espresso Machine
This is difficult to describe but my delonghi magnifica has developed a small problem, after turning the machine on via the front panel On button, the pump activates (slightly) even though no other buttons...
It might be a normal cleaning cycle or flushing itself out. You don't mention whether it's not working anymore, so is it just that the sounds and lights seem concerning, or has it actually stopped working?
Oct 28, 2013 | DeLonghi Magnifica 3300 Espresso Machine
Delonghi Superser won't light there is gas getting
Clean pilot first see if it lights if not you could change thermocouple
Apr 03, 2012 | DeLonghi Heating & Cooling
Delonghi EC 155 does not make coffee even after I put new filter
DeLonghi EC155 Espresso Machine so what does it do?Possible nothing,and do you know your last time you ran vingar though it to CLean it out?Normally solution is Vingar depend on size put 1-cup Vingar,half cup water,run it though.then run only water then next step in full pot,do this twice.Should work fine.
Aug 08, 2010 | DeLonghi EC155 Espresso Machine
How to program dcf212t
If you're talking about the timer, first make sure your time is set correctly by holding down the "set clock" button until the proper time appears. make sure it's correct for am or PM. Then hold down the "set timer" button until the time appears that you want it to turn on. Again, ensure it's AM or PM. Then push the "on auto" button twice, so the light is green. You're done.
Oct 28, 2009 | DeLonghi DCF212T
DeLonghi Debige 2440 Electric/Gas Double Oven Fan Failure Light
I had the very same problem. I slid the oven out of the wall about 6" or so, unplugged it, plugged it back in. It worked. I'm not sure if I jostled some connection, or if unplugging/repluging it in reset some sort of circuit fault.
Feb 02, 2008 | DeLonghi DEBIGE 2440 Electric Double Oven
DeLonghi EC701 Pump out
I had the same issue. Scale build up in the port that routes water to the boiler outlet for the coffee filter basket. Frother tube was fine.
I used CLR to open it back up. Used 1 part to 4 of water and ran a whole reserviour through the unit. At first, it only dripped and then finally it blew open when the CLR dissolved the scale.
Make sure to run lots of clean water through the unit after so that you don't end up drinking acid with your next cup. I ran about a gallon through to rinse it out.
Jan 08, 2008 | DeLonghi EC701 Espresso Machine
DeLonghi Retro DCG59 Electric Burr Grinder Logo
294 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
