Question about Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV
Rca projection screen model p52151wk chassis ptk169ptb popped shutoff
I have the above named television it has always worked great until about 2 years ago. It made a loud pop then shut off, at first it would come back on after a while but now it wont. I did pay a local repairman to come pick it up repair it and return it.... within weeks it was doing it again. when i called them they said unplug it for 30 minutes and plug it back in. THAT DID NOT HELP AT ALL. so much for having him fix any thing in the future.
also a fuse popped inside near the power supply and i had one to replace it with (it has been quite sometime but i seem to think i put a weaker fuse in it than what was there) what amp should that be to be proper?
the set was made in 1992 but i would like to save it if i can.
any help would be much appreciated.
  • Anonymous Mar 08, 2008
    component input board
    Champion:
  • 206 Answers
We have a saying in the TV business, " TV's age just like Cats" so at 16 years old you could have several problems. The most common is as capacitors age they loose the ability to function properly. this causes voltages to change and stresses out components like resistor, Ic's and many other high voltage components. This will also cause cold solder joints at the solder connection that can easily destroy a set. Even if you change all the capacitor, resistor that are bad or week when the set runs again it now has different voltages and usually destroys other componet in a short time. So what happens is you keep pouring cash to fix this set that seems to fail every six or nine months. Then the other problem, most manufacture only carry componets for about 7 years after the model end production, what this means if you need a special part like the high voltage transformer or CRT these most likely will not be available.The bottom line is this.... After you spend a few hundred bucks fixing this set that in all likelihood will not last more than six moths you know what you have?.... A 16 year old set
Posted on Mar 07, 2008
I have 2 RCA 52" projection TV's. One has a
dale_earn387,
RCA always has the part number stamped on the board. It will be a six digit number and usually is preceeded by "P/N". I have worked on these units and would guess that many of the boards are the same. Check the part numbers and if they are the same and the physical layout of the board looks the same the boards should be interchangable. I could not determine through research if the parts are the same because the units are older. I did determine that the CRTs are identical which would mean that more than likely the control signal board for them will also work.
Thanks for using FixYa and for the great rating.
hardrocko
Apr 19, 2011 | RCA P52921 52" Rear Projection Television
RCA projection HD52W59 won't turn on 2 green flashes at power but
Most techs dont know much about the ITC222A chassis which is what your model is. I would double check the ribbon cables that connect the Main deflection board and signal board. There are two of them just be sure they are proerly seated into their sockets as Those connections can cause that type of random operation
Jun 20, 2009 | RCA HD52W59 HDTV Projection Television
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
RCA 52 PROJECTION TV MODEL P52151WK
No , if fuse was blown you would not get the popping. How old is unit ? It sounds like your high volt splitter. common problem with rca. repair should not cost more than 250.00. you will want to have chassis number  and manu date for help
www.classtorations.com
Jun 04, 2008 | RCA P52937 52" Rear Projection Television
RCA P52937SG 52" TV Made March 2002
youre having deflection problems could be related to the flyback. But this type of repair is better off with an experienced tech that has the proper equipment and knowledge to diagnose this chassis
Apr 06, 2008 | RCA P52937 52" Rear Projection Television
ProScan rear projection
Proscans are manufactured in conjunction with RCA what is the chassis number of your set? I can help you out if you can provide the chassis number. Should be located on the back cover of your set.
Mar 02, 2008 | RCA P61960 61" Rear Projection Television
P52151WK 52" projection TV, no video
Is the audio coming from the TV's internal speakers, or from an external sound system? In the 169 series chassis, if the power supply caps or secondary rectifier are bad, or if the high voltage splitter has shorted inside, the set will not run and there will be no picture or sound from the TV. If the picture is completely black but the TV still has audio, press the menu button and see if the menu comes up on the screen. If the menu is there, check your cables on the back of the TV. If you are using a cable or satellite box, the box could be bad or the video wire could be bad or loose. If you do not get the on-screen menu, then I would guess that the solder joint next to the flyback transformer that sends filament (heater) voltage up to the picture tubes has cracked, or the low value resistor in the heater circuit has opened up. If that is the case, have the set serviced by a qualified tech familiar with the 169 series chassis.
Aug 26, 2007 | Televison & Video
Power Problem
There are two different chassis used in that model. If yours has chassis # ITC222 then the part number will be 264102 if it is chassis # ATC221 then it will be part # 258762. The defelection board for the ATC221 is the cheapest. Here are two links for both to order. http://www.partstore.com/ProductDetail.aspx?ProductSKU=2187237&ProductType=PART http://www.partstore.com/ProductDetail.aspx?ProductSKU=7747288&ProductType=PART
Mar 12, 2007 | RCA D56W20 56" Rear Projection Television
Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV Logo
87 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
