Question about Dryers
When starting, hear a noise like if the motor has problem rolling. The dryer works but stops during the cycle. Smeling heating after a while. And few minutes later, restarts and works, and stops again. thank you for any help for a diagnosis
  • Dryers Master
  • 2,651 Answers
Sounds like your motor is on the way out. Hard to start-- when it does go it eventually overheats---- wont restart till cools down. sounds like a motor going bad
Posted on Mar 08, 2008
Timer won't stop after cycle finished.
Dryer will not shut off:
The timer: Located in the control console of the dryer the timer consists of a small motor connected to a series of gears that rotate cams, which turn electric contacts off and on inside the timer. The timer contacts control the dryer motor as well as the heat circuit and the timer motor itself. A defective timer motor or a defect in the timer's electrical contacts can cause the timer motor to fail and the timer will need to be replaced. The contacts can be checked for continuity with a multi-meter. This test should only be made when the dryer is unplugged. Another test u can do is observe by eyesight and see does the timer advance or is it stuck on one cycle?
1. On gas and electric dryers that have an "Auto Dry" cycle, the cycling thermostat is often used to advance the timer as well regulate the drum temperature. Essentially, thermostat will alternately turn on the heat source or the timer motor when the temperature has been satisfied. To check this thermostat, you will have to check for power to the timer motor with a multi-meter, during a cycle. This is a live voltage test and caution should be used.
2. Some dryers will use a cool down thermostat to tumble the clothes without heat, at the end of the dry cycle. Power is routed through this thermostat to the drive motor to keep it running until the drum temperature has dropped to a specific temperature. If this thermostat fails it can cause the drum to turn indefinitely or until the door is opened. You can check the thermostat for continuity with a multi-meter. This test should only be made with the power removed from the dryer.
Lastly check the moister sensor for OHMS according to ur schematic as it must show a certain amount of ohms as per ur unit. When unit has been on short while
May 20, 2015 | Dryers
What does it mean when a dryer starts to tick like a clock
the ticking sound you hear is the timer motor.this is normal on timed dry.on auto dry you should only hear it when the heater is turned off.if the dryer shuts off and will not start after 20 to30 min. the motor has over heated and stopped to prevent over heating.venting is the no.1 cause of this.the vent system needs to be checked first.if it is a magic chef,admiral,or maytag under a few years the part below the lint screen needs to have all that lint removed every 6mo.
Mar 15, 2014 | Haier HLP140E Electric Portable Dryer
Kenmore electric dryer 70 series - it starts, motor sounds horrible, turns, gets hot, almost a burnt smell. what do i do?
it sounds like its bad...they usually will drag slightly when you push start. in other words, you can hear a delay in it starting...almost a hum, but not always...if its smelling like burnt usually cuts off and will not come back on until it cools down..
Are you sure its the motor thats making noise?? if a roller goes will go thump,thump, thump and they make alot of noise too...does it stop during the cycle? if you have more question, let me know and hope this helps
Feb 03, 2011 | Dryers
Dryer makes clunking noise when it starts and stops. Also noisy during the drying cycle. It's a Maytag
May need a new blower wheel.
The wheel is mounted to the motor and if it is stripped out it will not move air past the heat element.
Have it checked before the heat element fails.
Jan 16, 2010 | LG DLE2515S Gas Dryer
Rumbling noise during draining
i know with my fridgeadair it was the pump going out of mine , it would take me 3 spins to get the clothes wrung out enough to put in the dryer.
Dec 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Dryer Mod. #110.68932792 Ser. MJ1907445 Dryer in heat cycle starts and runs 10 to 15 minutes then motor stops, after about 2 minutes motor starts back on it's own, operator doesn't have to do...
there is a motor relay in the consol part 3405281,there is also a heat relay too,you can swap em out to see if this is the problem, the one on right side with blue wires is the motor relay let me know how you make out
Nov 19, 2009 | Kenmore Dryers
Roper dryer stopped working during cycle REX6634RQO
replace your t-fuse again but also chekc to see if the vent going outside is restricted. if hte vent is smashed or clogged the heat has nowhere to go. i would say that is your issue. clean your vent before you change he t-fuse.
Jul 27, 2009 | Roper REX4634KQ Electric Dryer
My Kenmore Soft Heat Dryer starts, then stops.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
Dec 10, 2008 | Kenmore 74602 Gas Dryer
Whirlpool dryer
If your dryer stops during its cycle, wait ten minutes and start dryer again. If dryer starts, then the motor was overheating.
Solution, Check for lint blockage around the motor and for possible overloading. If dryer repeatedly stops during its cycle, especially during consecutive loads, replace motor.
Good luck
Aug 10, 2008 | Whirlpool LER5636P Electric Dryer
I have an equator washer/dryer combo. It seems to have a few problems. The washer doesn't spin during the spin cycle, although it spins during the rest of the wash cycle. The pump is making a weird...
I have one of these things, too, an EZ 3612 CEE. I've replaced the pump on mine, but I am in no way an appliance technician. However, your problem seems like an electronics problem to me and the service people I've spoke to about this machine have told me that the main circuit boards in these machines fail regularly. That has yet to happen to me. I would suggest calling the equator service number. You'll be connected to some technician in India, almost certainly. But my experience with these guys has been great. They have VERY patiently talked me through a couple of different diagnostic procedures and solved some problems. Don't have the phone # just now but you can google equator appliance and get it.
Jun 23, 2008 | Equator Washing Machines
Dryers Logo
100 people viewed this question
Top Dryers Experts
