Question about JVC AV-32020 32" TV
Unlock JVC tv model number AV-32320
We have no remote for our tv and our daughter some how locked us out. Can you please help me?
  • Anonymous Jun 18, 2008
    JVC AV-32020 32" TV
  • Anonymous Jun 20, 2008
    my JVC TV is locked and to unlock every time I have to dial 4 numbers. How can I permanently unlock it?
What do you mean by locked out? If you are talking about not being able to turn on the power without the remote hold down the power button on the tv itself for 5 seconds to turn it on. other than that you probably should get a universal remote.
Posted on Jun 29, 2008
Tv has gone black and white
Look to see if same issue when a DVD etc is connected via the audio/video jacks this set should have.
If no color there it is a fairly expensive repair--likely the chroma/video chip which for this model may not be available any longer.
Jun 10, 2012 | JVC AV-32320 32" TV
We just got the JVC 32320 from a friend to use in our kids playroom. However, when we plug it in, it is just a loud fuzzy noise. The buttons do not work and there is no remote. We were going to try to...
The code will depend on the make & model of the remote that you purchase. The instructions that come with it will crossmatch to your TV brand and model.
Feb 09, 2018 | JVC AV-32320 32" TV
There. Is a channel lock on my tv. So I can't change the channels. How do I take it off?? Help!
Hello
you have to unlock your jvc set, and reset the V-Chip settings. There are two ways to unlock JVC TVs, you have to find out which proceedings frome below mentioned will work with your TV.
[1]
Press the "Menu" button to set the lock code for your JVC TV. A padlock icon will appear on the menu display.
Press "Zero" to access the lock code function then use the left and right arrows to select the four-digit number for your code. Use the up and down arrows to move to the next area of the display.
Select the up or down arrow to finish your lock code then use the left or right arrow to save your lock code settings and exit the menu. You can return to this display if you forget your four-digit lock code and set another code.
Write your four-digit lock code down and keep it in a safe, private area.
Select the locked TV channel you desire to watch or want to unlock. A message will appear on the display requesting you to enter your lock code to unlock the channel.
Unlock your JVC TV by entering your lock code on the 10-key pad. The message "Invalid Lock Code!" will appear on the screen if you enter the wrong lock code.
[2]
Select "TV" from the menu then select "V-Chip" from the drop-down list on the screen. "Please Input Password" will appear on the screen.
Enter your four-digit password by selecting numbers on the 10-pad that appears on the V-Chip menu display or your remote control. Create a new password if you forget it by unplugging your TV power cord from the outlet then reconnect the power cord. This procedure resets your password to "0000." Enter four numbers for your new password using the keypad on the screen or your remote and select the arrow to advance to the next number. Press "OK" on your remote or select "OK" on the screen to set your new password.
Unlock a TV rating or TV channel by selecting "MPAA" or "TVPG" from the V-Chip menu. Use the up or down arrows to select the locked rating then select "OK" on the display or press the "OK" button on your remote control to unlock it. The MPAA represents the U.S. Motion Picture Association of America rating system, such as "NC-17," meaning not intended for viewers 17 years or younger. TVPG provides you
May 10, 2011 | JVC AV-27020 TV
My JVC AV-32820 is locked and I do not know the code to unlock it. Is there a general default code that I can use to unlock my t.v.?
How can i unlock my jvc av 32820 it turns on but is locked in one channel and i do not have the remote that came with the set can i use my cox remote to set the menu on tv
Dec 25, 2010 | JVC AV-32820 32" TV
On/off timer on a 2002 JVC AV-32320 is blinking. Could this be a fuse? most likely something is broken and needs replacement inside. What are the most likely items to be fixes? It also makes a steady...
Hi, my name is John. Welcome to FixYa. Its not a fuse. It has went into stand-by mode, how many times does it blink? Thanks for choosing FixYa...John
Nov 24, 2010 | JVC AV-32320 32" TV
it could be the fuse you can check this yourself by unpluging the tv and opening the back, the fuse would be right next to the power cord on the motherboard, and if you get that far you can get a good look at what might be causing this, you really need to look at the motherboard and check for burnt diodes or ressisters and what knot. You can tell if its burnt cause it will usually a blackish brown color. Hope this helps Good Luck! P.S as long as the tv isnt plugged in and stay away from anything on the board that says (warning high voltage) stay safe Good day
A black rectangle is displayed on the screen
the black rectangle appears as soon as the channel indicator goes off. someone has turned on the closed captioning in the menu of the set. it is in the "text" mode. go into the menu and turn off the closed caption feature.
Mar 20, 2009 | JVC AV-32320 32" TV
I locked my tv through remote now i dont know how to unlock it
Please Help me unlock my TV. I cant use the remote
Jan 14, 2009 | JVC AV-20220 TV
JVC Channel Code locked and need to unlock
The square box is not a channel lock it's closed caption and labled CC in your menu.. Go into the menu and set CC off... No more box...
Jan 27, 2008 | JVC AV-32020 32" TV
JVC AV-32020 32" TV Logo
599 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
