Question about Dell 2300MP Multimedia Projector
Dell 2300MP shows no connection after 15 min of work
Dell 2300MP connected to PC HP Laptop WinXP and works fine for 15-20 min and strips start to run over projection more and more over the time. Finaly it comes white or blue display and cannot connect to PC. After one hour it start to work again in the same manner.
  • nstrelch Mar 07, 2008
    That were my thought too. To check it I've placed additional vent to get better ejection or at leat extend the time of connection. But it didnot help. When I've removed cover ther is not sign of dust or lint.
Unable to view any display on the HP HP Pavilion dv9730nr Notebook PC
Posted on Apr 21, 2008
  • 682 Answers
Something is getting hot inside please you must confirm good ventillation around it confirm that intake slots are clear from any obstruction body which block fresh air supply to the projector.-
clean filter of air with air blower-after you did all above still have problem go to qualified service technician.
Posted on Mar 07, 2008
  • mohamed eltoni
    mohamed eltoni Mar 07, 2008
    after visual inspection and you did not find the problem you must go deeper with aid of schematics diagram and service manual(qualified service technician.
    Genius:
  • 3,587 Answers
That's a clear indication that you have a major heating issue inside the box..the internals are apparently overheating, as it will work after cooling down, right?
  • Patrick Michaels
    Patrick Michaels Mar 07, 2008
    is the fan working as usual? all the ports for air open and unblocked? it may be clogged up with lint, dust, paper pieces..
    or the control board may simply be unhappy
  • Patrick Michaels
    Patrick Michaels Mar 08, 2008
    ok..here's another check..is the fan running continuously during operation? If not, that is a definite sign that there's something amiss in the thermostatic control of the fan assy, which means that you'll need to replace the board, one way or the other.
Projector is connected to an HP laptop. Once everything is plugged in and the projector is turned on, I turned on laptop as per the manual. The projector recognizes the device, shows the HP start up...
Press Fn + F4 keys, it will change output to external monitor.
Toggle keys to get needed combonation: projector only -> Projector+Laptop screen -> Laptop screen
Mar 09, 2011 | Dell 2300MP Multimedia Projector
I have a Dell 2300MP projector which works perfectly in cloned monitor mode with a 3-year-old desktop computer running Windows XP with an ATI card. I have very recently bought a new desktop running under...
Hello
This problem was also faced by me some time ago, i just change the data cable (vga cable) and then it will recognized by system,
i suggest to change the vga cable and try to find the DVI cable if possible to connect the projector to system end.
Hope this helps.
Jan 25, 2011 | Dell 2300MP Multimedia Projector
Dell E510 desktop was fine. Went to start again and yellow light on tower. Keyboard and mouse won't work. Screen is black. Unplugged waited 10 min. And turned on - yellow light still on.have xp.have...
check if your booting device is working fine... and see the booting device in the BIOS.. if it is not found there, try connecting the same in other PC as a slave..if there also it does not work, the device might have gone
Jun 25, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
My touch area on my studio 15 isn't working. like where the sound is and the play and etc. buttons were help!
The media control strip has a small cable connection underneath the strip, make sure it is connected properly. If no change, the strip will need to be replaced.
http://support.dell.com/support/edocs/systems/1535/en/SM/cntrcont.htm#wp1180201
Dec 18, 2009 | Dell Studio 15 Laptop
AcerAL1714 LCD Not Connecting With DELL Inspiron 15 Vista Laptop
There is a symbol of Two monitors on F3 Or F4 button
1. Press Fn key and hold it
2. by holding Fn key press F3 key
Your monitor will start displaying
Oct 05, 2009 | Acer AL1714 17" LCD Monitor
PC will not connect unless Laptop is turned on?
first reset the connection, and try to connect the pc with switch and when net start working the connect the laptop
Mar 11, 2009 | Linksys WRT160N Wireless Router
My dell laptop (inspiron 1000)can't wielessly connect with my new hp printer (6380. Ran the cd and laptop shows : photosmart c6300 series sn my873181qf0544 ip address 192.168.1.101 but when I...
Had the same problem on my Dell Latitude running WinXP SP2, installing a HP6380.
I noticed the installer was trying to access the other network printers I had setup (the status of these printers turned into "unable to connect" in Control Panel.) These printers are on the company's network and were not accessible from the home network I was on at the moment of installation.
I then started a VPN connection to the company's network, so that the printers were all accessible. The "add device" part of the insallation then went through and the printer was setup successfully.
Emiel Odijk
Dec 07, 2008 | Office Equipment & Supplies
Acer Aspire5100 laptop modem disappears from hardware profile!?!
Could it be the screen saver when you said about Vertical lines.
I mean ,your computer was set to a certain period of time that if it stay idle, then the screen saver program will start to run.
takecare.
Apr 19, 2008 | Acer Aspire 5100 Notebook
Media player movie picture won't display
Yes, I have the same problem with a Dell Inspiron 700m laptop. I have never been able to show videos using two seemingly compatible devices. This is not a projector issue however, as my projector displays video DVD fine from this PC, only videos inserted into PowerPoint will not play. Using another computer it works fine. Imagine that, Dell selling two highly practical devices that are not compatible.
Nov 10, 2006 | Dell 2300MP Multimedia Projector
Dell 2300MP Multimedia Projector Logo
484 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
