Question about Brother MFC 7420 All-In-One Laser Printer
Suddenly Does not print
Printer suddenly stopped printing and displays" manual feed, inset paper" message.
  • 1 more comment
  • Anonymous Apr 03, 2008
    the printer sudenly stopped and displays message manual feed insert paper
  • Anonymous Apr 22, 2008
    same issue!
  • michaeljn91 Feb 03, 2009
    my brother printer say 'no paper feed' or something to that capacity- and for me to put in new paper: there is clearly enough paper in there and it just keeps redisplaying the same message each time i try
    Novelist:
  • 105 Answers
This is typically caused by the program you are using having the print set up for "manual feed". When you are clicking the print icon, check your properties tab to see if it is set up for manual feed.
This frequently happens in MS Word and similar programs, when you are printing envelopes or something that is not standard size paper. However that is not the only reason the application gets set in that mode.
The bottom line is that this happens to me periodically and when I go back and check on what the settings were, I figure out my error.
Posted on Feb 04, 2009
I want to download new and start
Posted on Mar 10, 2008
When i print ,I get this error 'Manual Feeder Paper Empty
You are most likely getting this message because of a paper size mis-match. For example, you are sending a print job as letter size but your printer is set to or has a4 size installed. When the printer sees that the print job is not a matched size to the paper in the tray, it will look to the manual feed tray for paper to print on, hopefully the correct size. Make sure your paper setting in printer properties on your computer match the paper in the printer and the print job "page setup" is also the same size/
Oct 06, 2010 | Samsung SCX4623F Laser All-in-One Printer
The paper isnt going through
If the paper feed rollers are not clean, they may slip and cause paper feeding problems.
The problem may be alleviated by performing paper feed roller cleaning.
1. Open the Printers folder.
- For Windows XP Home Edition Click/Select "Start," "Control Panel," "Printers and Other Hardware," and "Printers and Faxes."
- For Windows XP Professional Edition Click "Start" and "Printers and Faxes."
- For Windows 2000/Me/98 Click/Select "Start," and "Settings," then "Printers."
2. Right-click the icon of the printer for paper feed roller cleaning, and select Properties from the displayed list.
3. Click the Maintenance tab and click Roller Cleaning. 4. Remove all sheets of paper from the auto sheet feeder, and click OK. 5. Confirm the message to be displayed, and click OK.
Do not try other operations until printer's operation completes.
6. When the printer's operation is completed, follow the confirmation message to load three new sheets of A4 or letter-sized plain paper in the auto sheet feeder
7. Click OK.
8. Confirm the message to be displayed, and click OK.
Do not try other operations until all the three sheets are ejected.
Memo: The printer prints nothing on those sheets.
9. When all the three sheets of the paper are ejected, paper feed roller cleaning is completed.
10. Click OK.
Performing Roller Cleaning is completed.
Nov 09, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Printer prints from manual feed but not from tray.
you need ot open up the papper tray and more the laser down then it should work
please rate my helf i need you to i am a exert
Apr 20, 2009 | Brother HL-2040 Laser Printer
Zebra 4M printer stopping due to error message
The printer is dirty sensor label or no label is calibrated. Turn off the printer and press FEED, CANCEL, PAUSE and turn on, release the keys to advancing the label, and let print be calibrated. Roberto Martinez Mexico bartech9@yahoo.com.mx
Feb 26, 2009 | Zebra Z4M Printer
Printer says printing but no print out.
all my cartridges are full/newly changed. my epson stylus cx5200 keeps on feeding papers, displaying printing message but with no actual print out i.e. blank paper comes out. please help. thanks!!
Darren.
darren.lee54@yahoo.co.uk
Oct 06, 2008 | Epson Stylus CX5200 All-In-One InkJet...
Everytime I try to print to my PIXMA 9000 I get an error from the print spooler that the printer is not responding. THe print job starts to print, stalls after a few lines.
1. First, clean your printer. Get some spray-n-wipe cleaner and a clean cloth and clean the entire inside of the printer. Also ensure your paper isn't dirty. Now print a test page. Does the symptom persist?
2. Remove all jammed paper. Check the paper tray first. Look closely at the paper rollers nearest where the paper exits the printer; this is a common source of jams. If you’re trying to print labels, they will often jam just before exiting the printer.
3. Try to print a test page. Does the printer still jam? If you can find no source of the jamming, check the printer's message display window and refer to your user’s manual to look up the printer error code.
OR=
1. Check the printer and/or the software to see if "manual feed" is selected. If manual feed is selected, the printer may be looking for paper in another tray.
2. Reseat paper. Ensure printer is on-line. Check for paper jams or obstructions.
3. Likely suspect: paper-out sensor is damaged or broken. Consult a computer repair shop.
Sep 16, 2008 | Office Equipment & Supplies
Print Feed Issue on 924
Make sure that there are no obstructions blocking a sensor or in the way of the paper path.
Are the cartridges jammed?
Jun 19, 2008 | Dell 924 All-in-One InkJet Printer
IBM Infoprint 1512 out of paper message
It could be a problem with the paper feed roller above the tray or a sensor problem.
It should be looked at by a service technician.
Jun 12, 2008 | IBM Infoprint 1512 Laser Printer
Randomly printer stops printing - need switch off and on to restart printing
Sounds like you are just beginning to have problems with the paper feeding. Try cleaning the roller or applying rubber cement per my other post on the paper feed topic.
Apr 12, 2008 | Samsung ML 1210 Laser Printer
HP Laser Jet 4p printer problem - will not print continuously
Go to the printer setting's and make sure that the printer paper feed are not set into a Manual feed.
Thanks,
Feb 27, 2008 | HP LaserJet 4p Printer
Brother MFC 7420 All-In-One Laser Printer Logo
170 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
