There's probably a port for a cable to attach...USB/HDMI/? Depends on the camera. Try to figure out the attachments needed on each end, and order that cord from Amazon. Or, just take your camera to Best Buy and let them help you. Normally, once you attach the cable to the camera and computer; your computer will recognize it. Then transfer the pics to a designated folder for viewing. Hope this helps.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
What do you mean by "attach a photo"? Attach it to what?
If you want to download photos from your camera to your computer, the best way involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Yes a camera can be attached to any type of computer more than likely. Actually it just sits on the monitor or where ever you want it to sit. It is installed or attached to the computer not really the monitor, it just displays on the monitor. But the computer itself is what drives the camera.
For the camera to be recognized it needs to be turned on and the computer, if Windows, needs the correct driver installed for the camera to be recognized.
Use usb cable to attach camera to computer and then go to My Computer and Download images to Computer.
You can Also print photos by directly attaching to printer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Camera's usually come with cords that attach the camera to the computer usb. The other way is to buy a card reader that would attach to your computer via a USB port.
This can cause by a bad usb cable that you're using to connect the camera to the computer, so better try to use another USB cable and also connect the camera to another USB port on your computer so we can check if the USB port is bad or not...
