Question about Acer Aspire 5100 Notebook
Internet issues with Cable Modem
Hello, I just signed up for the cox internet service yesterday and have been unable to get an internet connection. I spoke with Cox and they have said that the modem is online, but something on my computers end is not allowing me to get online. Does anyone know of any ideas to fix this asap?
  • RubyBelle Mar 07, 2008
    I have attempted that. I used to have DSL. When I first hooked up I attempted to go through our wireless router from Linksys, but it would not let me. So, instead have been attempting to go straight through the modem. If you have any other ideas I appreciate your help. I might have to figure something else out in the mean time.
    Genius:
  • 3,587 Answers
Yes..it's most likely in your network connections settings. open up control panel, go to network settings, and add a new internet connection. follow instructions, and see if that helps
Posted on Mar 07, 2008
Yesterday had Cable Internet hooked up at new house--when done modem had all lights green, and wireless router connected and worked fine. Now router won't connect to Internet, and USB connection direct to...
Sounds like a problem with your cable connection. Check your coaxial cable, and the splitter from where the cable enters your home. The tech will use a signal meter to measure the quality of your cable, and then replace the wiring if necessary.
Jan 04, 2011 | Motorola Computers & Internet
I run 3 computers connected to the internet using the Linksys EtherFast EZXS55W 5x10/100 switch. Switch is connected to COX cable broadband. Any issues with "crashing" on this switch? Seems...
Hi, I would recommend downloading the latest firmware for this device and then se if your "crashing" goes away.
If you plug directly into the cox modem do you have problems?
If that doesn't work I would replace the Cat 5e network cable from the switch to the cox modem.
If that doesn't work replace the coax cable from the cox modem.
If you continue to have issues replace the switch.
Dec 02, 2010 | Linksys EtherFast EZXS55W 5x10/100 Mbps...
I am on Cox cable. I lost my connection to the internet several times this evening. Cox checked out my modem and said the problem was in the router. When I connect modem to computer, internet pops up...
Cox people are really correct that everything is working from them and from there modem and doing a firmware update is really a good thing to do to correct your problem. For that firmware update you just need to download it from your routers manufacturer like Linksys , Belkin , Dlink or Netgear just go to there web site and search the model of your router so you can download the latest firmware for it.
Feb 03, 2010 | Computers & Internet
Added Cox Phone Service/Modem and now 2614 router won't work
That would be a problem for the Cox phone service provider.
Jul 06, 2017 | Siemens SpeedStream 2614 Router (ss2614)
Can I use 2WIRE 2701HG-B router in COX internet connection
No. A router has 2 main interface types WAN (for the internet connection side, and LAN (for the home network side) the 'LAN' side often has up to 4 ports and wireless connectivity for the home network.
The most common routers available at electronics retail use a CAT-5 connection for the WAN ports and the LAN ports. Your DSL modem/router uses a phone line input for it's WAN port, which uses a signal type that is incompatible with the cable modem output.
If COX doesn't offer a router with the cable modem package, you can go and purchase and common brand of home networking router, and attach it to the output of the cable modem.
Feb 28, 2009 | 2wire 2700HG-B Router (2700HGB)
Well i had just bought a lynksys router from my friend with no software cd so right now i am trying to download the software online so when i switch my cox modem with the linksys modem i want the software...
You should be able to get any software that you need from LinkSys.com but I have a couple of quick questions first:
1. Is the LinkSys unit you just purchased a router or modem?
If the unit is a router, you are still going to need a Cox compatible modem. If the unit is a modem, you will still need a router to complete the network setup unless LinkSys makes a combination cable router/modem, and I haven't been able to research one.
2. If it is a modem, is it a cable modem and, if it is, is it Cox compatible?
According to the Cox Web Site, the only models of LinkSys modems that are currently compatible with the Cox High Speed Cable Internet Service are:
BEFCMU10 v3
BEFCMU10 v4
WCG200
WCG200 v2
CM100
In this particular case, you may need to contact LinkSys and/or your Internet Service Provider. In most cases, they will not only tell you exactly what type of equipment you need, they will also talk you through setting up the network once you have the equipment - usually at no charge.
Graye
Nov 25, 2008 | Computers & Internet
CAN A 2WIRE DSL ROUTER WORK WITH A CABLE INTERNET CONEECTION
The 2wire dsl modem/router cannot be use with a another cable modem , since this 2wire device is also a modem/router and its made for the DSL conenction that's why it wont work with Cox cable, the best thing that you can do is to ask Cox to give a wireless modem/router like this 2wire so you can still use the wireless connection of your computer..
Hope that helps..........
Sep 06, 2008 | 2wire (1000-400108-001) Router
Changed from DSL to cable
Usually DSL connections require ppoe while cable uses dchp You need to log into your router and change the settings
Dec 29, 2007 | Linksys EtherFast EZXS88W (DSLSEZXS88W)...
Random Disconnect: PCX 1100U
Toshiba 1100 modem are no longer compatible with any service providers anymore. The reason for this is Toshiba quit making cable modems and no longer supports them. Since they no longer support their modems, they don't write firmware to make them DOCSIS 2.0 compatible and since most service providers use 2.0, your DOCSIS 1.1 modem will not function correctly. Actually what is really happening is the 1100 modems cannot correctly decipher the 2.0 and are constantly changing their transmission power levels. You definitely need another modem, and if you are using Cox, ask about their refurbished ones for about 20 bucks.
May 22, 2007 | Toshiba DOCSIS Cable PCX1100 Modem
Acer Aspire 5100 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
