2.0 USB External Interface Compatible w Compaq USB Ports????
I am about to buy an external hard drive for backup and it is described as having a 2.0 USB interface. Will this devide work with the USB ports provided on my Presario 4403US Tower?
Thanks much,
Jim
  • 807 Answers
USB 2.0 is just faster.
If you have USB 1.0 ports on the computer the new drive will revert to that speed.
Posted on Mar 07, 2008
When i plug in the usb to my computer it is not recognized and does not show anywher
If you have a SimpleTech SimpleDrive connected to your computer and you're experiencing problems with the external hard drive, there may be several reasons why it's malfunctioning. Troubleshooting your computer can help rule out common problems and the possibility that the hard drive may be defective. If you recently purchased the device and suspect there is something wrong with it, return the defective drive to SimpleTech or the reseller for a replacement. Incompatible USB Port Problems SimpleTech SimpleDrive plug and play options makes it easy for you to connect the device to your computer. But you may encounter problems if your computer's USB (Universal Serial Bus) ports are not compatible with the external hard drive. Make sure your ports are powerful enough to operate the drive. USB 2.0 ports are recommended, but if you're using an older computer with 1.0 ports, the hard drive will function much slower or you may receive an error message that the device is not compatible with your system. b> Missing External Drive Letter If you're unable to find the SimpleTech external hard drive's letter on your desktop after you have installed the drivers for the device, it's possible that the external drive may be assigned to another drive. Sometimes, the hard drive is assigned to a network drive and you may need to manually change the drive's letter in Disk Management. b> SimpleTech SimpleDrive Incorrectly Formatted b> SimpleTech SimpleDrive is normally pre-formatted for Windows NTFS (New Technology File System), but Mac users may need to copy the backup software and reformat the external hard drive for FAT32 or Mac OS to be able to use the external drive. If the external hard drive is not formatted correctly for your system, it may not function or work properly. b> External Hard Drive Inaccessible If you receive an error message that says "Drive Inaccessible," the SimpleTech SimpleDrive may not be able to read the service area of the platter. If the external hard drive emits a loud or abnormal sound, this could mean the device is failing.
Test the drive on another computer to see if it is working properly. Otherwise, the external hard drive's surface area may be damaged or corrupted.
Replacing a Defective Hard Drive You can return a defective hard drive that is under warranty to SimpleTech. The manufacturer will exchange the device if the seal is not broken. But if you break or tear the seal on the case, any warranty claims will not be accepted and the device will be returned back to you. SimpleTech will only accept the device if you contracted a commercial data recovery company to retrieve critical data from the external hard drive and the seal needed to be broken. Before returning the defective drive, you will need to secure a RMA (Return Merchandise Authorization) approval number from SimpleTech and furnish any invoices or documentation regarding the data recovery company's services
or if its a usb external drive you might need a usb 3 card installed on your computer your computer might not have enough usb output power USB 3 card will provide more power when needed to the device to gain maximum throughput and conserve power when the device is connected but is idling http://blog.premiumusb.com/2010/09/usb-2-0-vs-usb-3-0/ these can be purchased on Ebay cheap and easy to install http://www.ebay.com.au/itm/PCI-e-PCI-Express-USB3-0-Card-new-NEC-720200AF1-chipset-/330608109325?pt=LH_DefaultDomain_0&hash=item4cf9c7670d for roughly $9 or $10free postage Hope this helps.
b>
Dec 14, 2012 | SimpleTech 500GB SimpleDrive Pro External...
Won't recognize external hd
Dec 11, 2012 | SimpleTech SimpleDrive Pininfarina 500GB...
I have the Lacie Minidisk Ethernet 500 GB that contains all my house PC backup. I both an USB Minidisk Lacie (1 GB) in order to use MySafe feature but it never worked.
Hello Elio,
Use MySafe to back up the files stored on the Ethernet Disk mini Home to an attached USB storage device. This way, if files on the Ethernet Disk mini are damaged or accidentally deleted, you can restore them to their original locations.
There are three main steps to using MySafe,Connecting an external USB hard drive,Backing up files to the external USB hard drive,Restoring files to the Ethernet Disk mini (if necessary)
Before you can back up files, you need to connect a hard drive to your Ethernet Disk mini via the USB port on the back. Use a hard drive that is USB 2.0 compatible.
While connecting an external hard drive make sure your Ethernet Disk mini is turned on and connected to your network.Turn on the external USB hard drive.Connect the external hard drive's USB cable to the USB port on the back of the Ethernet Disk mini, just like you would connect the external hard drive to your computer.Confirm that the drive is properly connected. Log in and click on the Administer HipServ link. Click on USB External Storage under System.
To back up files, navigate to the file or folder you want to back up to the external hard drive and click on the disk icon in the "Backup" column of the file list.When you back up files to MySafe, the Ethernet Disk mini duplicates the file path in MySafe so that everything you back up is organized in MySafe just as in its original location. So, if you copy a file from MyLibrary, a MyLibrary folder will appear in MySafe, with all folders leading to the backed up file.
Always click the Safely Remove Drive button on the USB External Storage before unplugging your MySafe external hard drive. Wait for the interface to change and for the Use Drive button to appear before disconnecting the USB cable from the Ethernet Disk mini. Failure to safely remove your external hard drive before disconnecting the USB cable can cause data loss and/or damage the drive. Always use the Safely Remove Drive feature when disconnecting an external hard drive.
Jun 03, 2011 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
When i connect my wd 1tb hard drive i get usb device not recognised plz help
Hi sexybarneygu, Assuming you have tried other USB ports getting the same problem, I recommend you return it (if it's under warranty) if not, remove the Hard Drvie from the casing and connect it to another computer internally (I dont want you to get another external case for you Hard drive because you hard drive MIGHT be the one with the problem and you cant fix it (you can't fix hard drives, just work around it in order to get your data back and then trow it away). If the other computer sees your hard drive ok, then go buy an external case and install your hard drive there. make sure it's the same interface - most likely SATA interface. I'm 80% sure it's just the casing not the hard drive. Don't forget to rate if my answer helped you. Thank you :D
Apr 28, 2010 | Western Digital My Book Essential 1TB...
USB's slow and external drive
For the USB ports, you may want to verify that the drivers for the "enhanced USB" are up to date and for USB 2.0 or 1.1. USB 2.0 ports are generally backwards compatible for 1.1 devices. The "enhanced" does indicate USB 2.0 controller. 30mins to backup 3GB to your external drive is a VERY long time. USB 2.0 transfers data up to 480mbps, but if you get an error message indicating that the device can perform faster on a 2.0 port, you maybe transferring data at 12mbps which is USB 1.1 speed
To speed up the transferring of data, identify which USB contoller in Device Manager is the USB port you're having a problem with, and delete it from Device Manager. Then, plug in your external drive into a USB port its never used before.
As for the naming of hard drives, Hitachi partners with several drive manufacturers including Dell and IBM.
Feb 22, 2010 | Philips Computers & Internet
My d610 does not recognize my cd drive
Is the USB-compatible drive recognized when connected to some other computer? If OK, then the drive is OK.
Is _ANY_ USB device (memory-stick, camera, mouse, keyboard, printer) recognized when connected to any of the USB ports on your computer?
If not, then the USB device-drivers for Windows have not been loaded.
Drastic: backup all your data files, bookmarks, and music, to an external hard-drive, and reinstall Windows from the Dell-provided "System Restore" set of CD-ROMs.
Nov 14, 2009 | Dell Latitude D610 Notebook
Low local disk space
get a external usb hard drive.you cant do anything to a computer like this chap its going to cost u a little someing.i hope this help u
Jul 18, 2009 | Compaq Evo D300 PC Desktop
Compacq presario 1200
compaq tend to have removable CD drives, just by undoing 1 screw on the underside you may be able to remove the drive, then you just order a replacement.
for an external CD drive any USB drive will do, it's not compatibility with your laptop that is the concern, you just have to make sure that it does what you want, make sure you get one with an external power supply as compaq usb ports tend to be low power ports, and bus powered drives try to draw too much power when burning disks
Sep 22, 2008 | Computers & Internet
Simpletech 500 gb external hard drive
There is a power consumption work-around untill a Y usb wire can be purchased; the main power cable must still be used at all times but this workaround should only remain temporary!!!
Simpletech should have included this so laptop users could use the drive as their capacity is better than the packaged slimmer simpletech portable backup drives for laptops, which does include the Y cable....
1) unplug usb while powered and unknown hardware is present on laptop...
2) turn power switch off from the external HDD...
3) return power switch to on from the external HDD...
4) plug in usb connection to laptop...
Autoplay should read from external HDD!!!
**** Save some $$$ and buy a Y shaped cable to provide sufficient amount of power from laptop usb
ports, cause it's necessary to use 2 of your ports to provide power in addition to the main power from HDD to wall****
ADONIS
Sep 04, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Computers & Internet Logo
67 people viewed this question
David Payne
David Payne
