Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Garage door opener light bulbs burning out
I have a new craftsman model #139.53985d Garage door opener. I have to keep replacing the light bulb on one of the 2 sided opener continually. It keeps going out. I have tried normal to heavy duty bulbs. Only burning out on one side. What could cause this. It worked for a while when we first had it installed. Now it is continually burning out.
Thank you
    Scholar:
  • 143 Answers
You can replace the socket itself. Unless there is extreme vibration this will be your best bet. If there is vibration then use some rubber washers to lessen this. You can get replacement parts at chamberlain.com. Thanks BB
Posted on Sep 03, 2010
I had that problem also. I even tried the bulbs designed for rugged use, but they too burned out quickly. I eventually chnaged to the CFL florescent screw in bulbs, and they have worked well.
Posted on Jan 04, 2011
2 Suggested Answers
blanchettohd
  • 143 Answers
SOURCE: My light bulbs keep burning out prematurely on my garage door opener.
This is a logic board issue. You can purchase a replacement one at searspartsdirect.com. Enter in your model number and a parts list will come up. This is a fairly easy install, make sure and unplug the unit first. You will have to reprogram the remotes. Thanks BB
Posted on Sep 17, 2010
Garage door like keeps burning out
Usually a new light bulb will help this problem.
Jun 21, 2011 | Sears Craftsman LiftMaster Chamberlain...
The lightbulb in the unit burns out quickly, every 4-6 weeks. I have Lift Master 1/3 H.P. FCC ID #HBW1127, Part #41A4252-7D
You can buy bulbs designed for garage door openers. They are heavier duty. Also you should unplug the unit and remove the light bulb. Pull out on the center contact of the socket. Replace the bulb and plug the unit in.
Oct 17, 2010 | Sears Craftsman LiftMaster Chamberlain...
Replacement bulb only lights for a day and then burns out again
There are heavy duty/rough service bulbs you can buy at the hardware store that are made to withstand the vibrations. You might also try unplugging the opener and removing the light bulb. Use a screwdriver to reach down to the center contact in the light socket and pull out. That will increase the tension on the bulb somewhat.
Jul 09, 2010 | Sears Craftsman LiftMaster Chamberlain...
My Crafstman garage opener is melting my light bulbs!
Rather than new bulbs I suggest you unplug the unit and use a small screwdriver to pull out on the center contact of the light socket.
Nov 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Light bulbs burn out constantly on Chamberlain garage door opener
Get an electrician to measure voltage where the light is plugged in. It sounds like you have too high a voltage.
Aug 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Light bulbs constantly burn out in Chamberlain Garage Door Opener
Unplug the unit from the power and take a screwdriver and pull out on the center contact of the socket.
Jul 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
1/2hp Craftsman Garage door opener light bulb
If you are getting a click the relay on the board sounds like it is working. Sometimes the contacts in the light socket gets burn spots on them. Try unplugging the unit, unscrewing the bulb and with a small scrapping tool (small flat screwdriver) scrap the bottom contact and the contact on the threads. Bend the contact on the threads a little too make better contact with the bulb. Screw the bulb the bulb in completely. If this does not solve your problem the only the left to do is to replace the logic board.
Jan 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
Feb 18, 2008 | Sears Craftsman LiftMaster Chamberlain...
I tried a REVEAL(brand) 40 WATT DOUBLE LIFE CEILING FAN LIGHT BULB , and almost two months later it still works. It is sold at Home Depot in Illinois. The filament is much thicker than any of the other heavy-duty bulbs I have tried, and that seems to be the difference. The REVEAL bulb is the only one I have tried that has lasted this long.
Feb 01, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
1,080 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
