Question about Dryers
Maytag Dryer Model DG312 gas
My 20 year old dryer started to make a low rumbling sound like it was very labored. I have dried two loads with this sound but it sounds like it go stop at any minute. Do you know what this might be? Also given the age of the dryer do you think it is worth fixing as it is not an energy effiecient model
  • 30 Answers
Honestly, I must advise on getting a new dryer. A new dryer will run about $200-500 depending on which kind and where you get it. Repair on a dryer will cost roughly $125-$200 pending parts and labor rates if you decide not to do the repair yourself. But there is a way around those two options. Depending on your area, a Sears technician can come out to the home for $65 (pending location) and diagnose the problem and give you his/her estimate on how much the repair will cost. If you decline the repair, you may ask the technician for a voucher coupon for the trip charge that may be applied towards a new dryer from a Sears store priced at $399 or higher.
Posted on Mar 08, 2008
I have a stackable washer/dryer gas maytag. Purchased around 17 years ago. The dryer is not drying clothes. Gas is powered fine and it is heating up. The cycle seems shorter than normal
The problem with it not drying is most likely going to be a worn out blower wheel thats slipping and not moving the warm air through the clothes to dry them properly. Always a pretty good sign the blower is slipping is,if you hear a rumble noise from the dryer at start up and also that same rumbling noise when the power stops. So if you hear it at start up...wait 30 seconds and open the door and listen for the rumble noise as drum stops. also you can check where the vent exits the house and see if their is air flow when the dryer is running.
GENE
Aug 19, 2011 | Maytag LSE7806A Top Load Stacked...
Broken wire from the igniter on a maytag dg312 gas dryer
Hello Randy,
If the wire it broken on the actual ignitor with the ceramic base and the gray filiment,you could just replace that ignitor and keep that glorious 20 year old plus dryer going for years to come.The ignitor could be purchased at your local applince parts store for under $30 the part number is 279311 it also could be ordered online at;
assuredparts.com
apdepot.com
appliancepartspros.com
repairclinic.com
Gene
Aug 09, 2011 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag dryer makes rumbling noise when drum starts and again when
Sounds like a broken spring or a spring mount.
Jan 17, 2010 | Maytag Dryers
Maytag Model DG312 not drying
Firstly, ascertain that you have made a positive heat selection on the control panel temperature switch, If available.
Below are some links, courtesy of www.repairclinic.com, that will assist you in diagnosing/repair of your dryer. You may have to enter your model number in the search box to access some of the information.
Below is a parts breakdown/disassembly procedure for your dryer.
http://www.repairclinic.com/Dryer-Gas-Maytag-Style-Appliance-Diagram
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Igniter http://www.repairclinic.com/SSPartDetail.aspx?s=t-dg312-%3d%3di3018&PartID=3018 Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils http://www.repairclinic.com/SSPartDetail.aspx?s=t-dg312-%3d%3di3479&PartID=3479 Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse http://www.repairclinic.com/SSPartDetail.aspx?s=t-dg312-%3d%3di483890&PartID=483890 On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Other components that could keep it from drying.
Washer not spinning dry enough
Restricted Venting
Make certain that unrestricted airflow is available.
Blower: must be tightly attached to motor shaft.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-dg312-%3d%3di1245880&PartID=1245880
Cycling Thermostat
http://www.repairclinic.com/SSPartDetail.aspx?s=t-dg312-%3d%3di484074&PartID=484074
Gas Valve
http://www.repairclinic.com/SSPartDetail.aspx?s=t-dg312-%3d%3di1689&PartID=1689
Motor Centrifugal Switch
http://www.repairclinic.com/SSPartDetail.aspx?s=t-dg312-%3d%3di1245851&PartID=1245851
Sep 06, 2009 | Maytag Dryers
Need a wiring diagram for a maytag gas dryer dg312
If the old motor is still installed simply change wire for wire.
Jul 27, 2009 | Dryers
Dryer makes rumbling noise intermittently
It sounds like a faulty roller under the drum. Need to pop the top of the dryer, then remove the front -- you'll probably easily spot the faulty part.
May 06, 2009 | Maytag Dryers
Dryer makes rumbling sound when starting
If you remove the front cover and access the blower fan and see if it is still tight on the shaft. if it isn't it makes a rumble sound when started due to vibrating and after a while it makes more noise as it goes. Now I removed the fan and placed a shim in the flat area and matched the flat area of the shaft and replace it back on the shaft and it should solve it.
Mar 21, 2009 | Maytag MDE2600 Electric Dryer
Rumbling in dryer
Replace your blower wheel. (This is fairly common repair for some Maytag dryers) It is not too hard to do. If you can confirm your model number I can give you a part number and tell you how to get to it if needed.
Feb 09, 2009 | Maytag LSE7806A Top Load Stacked...
Electric dryer makes a rumbling when tumbler is turning.
Check the drum bearing, a load noise, and often spinning problems are symptoms of a bad drum bearing.The bearing is at the base of the drum and accessing it is not easy.
You can find diagrams and replacement parts entering model number here.
Jan 06, 2009 | Maytag PYE2300AY Electric Dryer
Dryers Logo
263 people viewed this question
Top Dryers Experts
Marvin
Marvin
