Question about OKI MICROLINE 591 Matrix Printer
Changing default settings
I have a oki microline 591 Matrix printer. It is printing at too high quality and taking forever to print. Keep trying to change settings but it keeps defaulting back. What is correct procedure to change the default.
    President:
  • 1,944 Answers
There should be a button on the front panel that lowers the quality.
Posted on Mar 07, 2008
  • 818 Answers
Http://www.oki.es/binaryData/2313/590uGB.pdf
please check this.
Sergio
    Genius:
  • 3,587 Answers
It's in the print settings..open up your print manager, and you'll see a button..for that..my profile has contact info if this doesn't get you there.
  • 1 more comment
  • Patrick Michaels
    Patrick Michaels Mar 07, 2008
    if you're on win xp, then it's under control panel..
    also, the oki has some default options..
  • Patrick Michaels
    here's a link to the manual, in case you don't have one hand.
  • Patrick Michaels
    looks like it's on page 42, section 5 there's a panel button for lo and hi quality. if that's not working, then the panel will need to be replaced, eh?
Print quality - what is hsd, nlq, utl, ssd mean on the printer
Hi Teresa,
These are just print quality settings
Super Speed Draft (SSD) - 435 cps. High Speed Draft (HSD) - 390 cps. Utility ( UTL) - 300 cps. Near Letter Quality (NLQ) - 75 cps
Hope this helps!
Please don't forget to rate
Jan 21, 2011 | OKI MICROLINE 320 Turbo Matrix Printer
My OKI 591 is only printing going one direction, not backwards and forwards like before so it's very very slow. Is there a setting that causes this? Thank you
Usually when this printer prints in HIGH QUALITY, it will only print one way, to avoid misalignment issues between the one pass one way and the next pass coming from the opposite direction.
If I am right, lowering the quality of your print to "normal" or "draft" should give you back the "2-way printing"
Apr 01, 2010 | OKI MICROLINE 591 Matrix Printer
How i can copy the custom paper size for oki 591 to other computer
you can not copy the custom paper size to other computer ....you ca nconfigure same paper size in other computer..........
  1. open printers and faxes
  2. From the File menu select "Server Properties" (Print server properties)
  3. Forms tab
  4. Click "Create a New Form" and add information that you want
  5. Click OK
Oct 08, 2009 | OKI MICROLINE 591 Matrix Printer
OKI Microline 591 prints extra page of paper everytime
There is a setting on most printers to print a separator page at the end of print jobs. You can check the settings of your printer by going to the control panel and clicking on printers. Select your printer, right click and go into properties. The setting for this is usually located in the advanced settings. See if the printer is set up to print a separator page, if it is, uncheck it, press apply/ok button and close out printer window.
Jul 10, 2009 | OKI MICROLINE 591 Matrix Printer
Microline 320 Turbo Print Quality Settings
You need to set it in Menu Mode -
Press MODE - the SEL light will go out. The menu light goes on. Press Group and the first line of the menu prints.
Gropu of related items keep pressing group until you see the print mode menu printed - once on the line press SET - keep until the printer prints the setting you want.
After you are finished press MODE to save the changes
Jun 19, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Rolling halfway down the page
is the form tear off on?
if it is try changing it to off
Dec 03, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
I am trying to hook my printer up to my new computer and the disk I have is not working. i do not have a cd for microline 590 elite dot matrix drivers
The drivers should be on the company website, if these are not working for you the generic text driver in Windows will work for text only printing. If you do graphics or formatted invoices, etc. on the printer Epson and Okidata both make pretty generic print drivers that should work for a microline printer.
Jul 31, 2008 | OKI MICROLINE 591 Matrix Printer
Help!! Troubleshooting
First thing to try is turning the printer off and back on again. If it still continues, replace the printer cable.
Jun 16, 2008 | OKI MICROLINE 591 Matrix Printer
OKI MICROLINE 591
You need to set and store paper size, width etc in printers internal menu and on print driver on pc.
See Oki manual for printer settings its written on the front of the machine i think menu and set power on, then print to see settings then read manual...
Jan 04, 2008 | OKI MICROLINE 591 Matrix Printer
Page advance problem
print out your menu of the printer and load the IBM Proprinter driver in windows ,your printer default driver is IBM Proprinter this will sort out the problem.you have probably loaded a OKI driver while the printer is set for IBM.Hope this helps.
Dezzi
Oct 16, 2007 | OKI MICROLINE 320 Turbo Matrix Printer
OKI MICROLINE 591 Matrix Printer Logo
291 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
