Question about Toshiba Satellite M45-S169 Notebook
Shuts down unexpected,
Bought M 45 S169 for my hubby's promotion. Worked fine until a few weeks ago, started to shut down just like that. power button started flashing. Temp runs at 117 - 125 F. Need info quickly, hubby to deploy. Thx
  • cattalaya Mar 08, 2008
    the kids bought him one a while back, but that does not solve the problem. Interior is clean and dustfree. Just shut down again and trys to restart to no avail. HD is fine checked the complete laptop. Still shutting down, having a mind on its own. Noticed that pages visited in IE are not there anymore along with the history. Need help, hubby deploying soon.
  • 405 Answers
Sounds like an overheating issue, I would suggest using a cooling pad.
shuts down unexpected, - 325aed8.jpg It's a simple device, you just rest your laptop on it and the fans do the work.
Sometime they overheat when working in a confined space, make sure you have ample room aroung the laptop for ventialtion.
Hope this helps
Posted on Mar 07, 2008
When I press the power on button, why does it just beep and won't turn on?
There is an interlock that shuts down the dehumidifier when the bucket is not in place or not seated correctly. There also may be a "bucket full" sensor that shuts it down mistakenly. Another possibility is that the compressor has failed.
Dec 18, 2015 | Dehumidifiers
Samsung Laptop Shuts Down Unexpectedly
CHECK THE FANS! The biggest enemy to your laptop is HEAT! You just replaced the display it's very possible you inadvertently disconnected the cooling fan. Clean it while you have it apart dirt and dust prevent proper cooling
Jun 28, 2017 | Samsung Computers & Internet
Lenovo unexpected shut down
I suggest you return it to the supplier for an exchange or repair or refund as it would be still under warranty.
If you try to fix it yourself you will void your warranty.
Mar 07, 2013 | Lenovo IdeaPad U410 437689U Graphite Gray...
Asus u52 shut down unexpectedly
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Jun 17, 2012 | ASUS U52F-BBL9 Laptop
Paloma PTG-74PVN power turns off by itself
turn the water flow off and control off and hold the two arrow buttons together
then use the up arrow to get to e and the down arrow to get to 1 what do you see?
Sep 09, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Buttons no longer work--power and OSD menu buttons don't work
I had the same problem. In frustration after trying everything else as I couldn't shut the monitor off, I shut the computer down, unplugged the power to all, and left it until this morning (12 hours). Now it works, so it must reset itself. I am waiting for feedback from their support as well but imagine they will tell me the same, good luck.
Jan 18, 2009 | Westinghouse 22" Widescreen LCD Flat Panel...
Samsung HLP6163W Problem- TV keeps turning off!
Well, I have had the same exact problem and since my hlp6163w is still under warranty, I had a technician come out to repair it. And...the winner is a bad ballast. The Ballast has also affected the bulb. So, the answer is you need to change the Ballast and the lamp to get the problem resolved. A faulty Ballast will always destroy a a lamp. Sorry for the bad news as this will cost you a total of $400.00 to replace. It sounds like there is a defect in the ballasts that were made for this particular set and a recall should be made. Hope this helps!
Jun 11, 2008 | Televison & Video
Shutting down without warning
shutting down this way is usually loose or ill fitted hd,sometimes mem or conflicting software.
take out hd refit making sure housed properly.start up pc and see how it goes.
check mem.take them /it out of housing check for dust.. refit.
some tech's suggest taking mem out and swapping them around ..this has no impact the mere fact thet you remove clean and refit is all thats required.
Mar 08, 2008 | Toshiba Satellite M45-S169 Notebook
Toshiba Satellite M45-S169 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
