Question about Philips Magnavox 51MP392H Rear Projection Television
MAGNAVOX 51MP392H/17 CONCAVED PICTURE
ABOUT THREE YEAR OLD SET JUST STARTED , THE PICTURE IS SMALLER IN THE MIDDLE THAN ON EDGE , ANY ADJUSTMENT I CAN TRY?---THANKS
  • 1 more comment
  • TORQ38 Mar 08, 2008
    It has the same problem in all modes , I have been able to watch by adjusting field red and blues , but the main picture is still concaved. "SCROLLING BANNERS ROLL IN A ARCH "
  • Anonymous Mar 18, 2008
    Mine is having the same problem.
    the green is concaved.
  • eddie500 Mar 19, 2008
    my picture is arched on the bottom and the top is there a way to adjust this
Hi there I hope you already have a solution. If not here's what I did to the same model set. I replaced 2 STK392-120 Chips and all 12 6.8 5% metal film resistors. Was about a 1 hour fix from start to finish.
the parts are located on the SSM panel inside the tv.
Posted on Dec 06, 2008
    Champion:
  • 206 Answers
There is a mode these set run in that stretches the side so the screen is completely filled, this is so the people do not seem all fat and short, this mode is known as Panoramic, this is one of the screen settings you can choose, I believe your set has a 4X5 or normal mode, 16X9 and maby a 16X9 zoom, the panoramic and maybe one more, find the format button on the remote and cycle through them
Posted on Mar 07, 2008
My 48 inch Magnavox HD is showing double Model #: 51mp392h/17
If it looks anything like the picture (3D etc) it will need the "Convergence circuit" repaired.
Let me know if you have questions.
Feb 26, 2012 | Philips Magnavox 51MP392H Rear Projection...
I have a Magnovox HD TV Progressive Scan (Floor Model) TV
You can find a replacement Philips/Magnavox fresnel screen, in stock, for this model (51MP392H/17) at this following link from a major parts distributor:
Philips / Magnavox 51MP392H Replacement Part Fresnel Screen
And here's a link for the Lenticular (middle) Screen, if needed:
Philips / Magnavox 51MP392H Replacement Part Lenticular Screen
Jan 16, 2009 | Philips Magnavox 9P6034C 60" Rear...
Magnavox 51MP392H/17 picture is washed out
no the best thing to do is call a repairman to fix the set so you arent 2nd guessing the parts you may or may not need
Jan 13, 2009 | Philips Magnavox 51MP392H Rear Projection...
60" Rear Projection TV
sounds like a convergence chip problem...
here is my general post for the 51 inch you'll have to look at the link for the manual and check to see if you have the STK392-120 chips or somthing bigger in the 60"
51MP392H/17
you need 2 Convergence IC's STK392-120's (120's and 150's will work) of course order 2 of the same type I'm using replacement 150's they allow for a little higher heat and were cheaper ALSO you need to replace the 12 resistors with 6.8 ohm metal film resistors, make sure they are metal film! don’t skimp out here I did and then they blew and fried my IC's and I had to replace everything again!
Great reference link that I posted
pictures on, check out page 3
http://www.techlore.com/forum/thread/16736/Magnavox-51MP392H-17-51-quot--TV-has-double-vision/
Where I got my parts that worked:
Suburban Electronics
http://www.suburban-elect.com/
Manual Library you should find all you need here:
http://www.techlore.com/group/2/list_downloads
What you need:
(2) STK392-120 OR STK392-150 IC
chips
(12) 6.8 Ohm Metal Film resistors
set of star screw drivers
15 watt pencil solder pencil, DO NOT use a high watt iron you will fry the surface mounted item.
good leaded solder, and flux
Aug 21, 2008 | Philips Magnavox 51MP392H Rear Projection...
Magnavox 51mp392H/17 convergetnt problems
When I turn on my magnavox 51mp392h/17 the sound and picture works but there is a sizzling sound coming from inside of the tv I looked and the sound is coming from what looks like a coil it has 4 lines coming from it 3 of which go to the color projectors and one to what looks like a transformer. Can you help me out?
Jun 06, 2008 | Televison & Video
51mp392h/17 model number magnavox
try resoldering the vertical output IC. That may be the problem bad solder has been known to cause that symptom in the chassis
Mar 20, 2008 | Philips Magnavox 51MP392H Rear Projection...
51mp392h/17
HAVE RED BOW . BLUE IS GOOD . RED I CANT AJUST JOESTV2003@YAHOO.COM
Nov 14, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
105 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
