Question about Masterbuilt ESBMPG Grill
Masterbuilt Veranda gas leak
Gas is leaking from under the control panel area and igniting there. At the place of ignition, there are pre-made holes in the brass coupling and holes on a plastic part within. The gas is not getting to the inside of the kettle where it should ignite. What can I do?
  • Anonymous Mar 31, 2008
    I have the same problem with an older model. The posted solution was not helpful at all! Seek professional help? You could say that for every problem! Should I take it apart and clean it? What would a professional do?
  • 833 Answers
It is strongly recommended that if you cannot see a blockage in the assemblies leading to the burner or damage to the burner itself, that you get professional help before you have a fire or worse.
Posted on Mar 16, 2008
The line to the pilot leaks out propane right before the pilot burner.
Even the smallest pressure drop caused by this "leak" would prevent the pilot from igniting. If the pilot remains lit you may be confusing the leak with the gas control valve opening. The valve opens a few seconds before the igniter ignites the gas to create a flame. This is normal. If you have a gas grille you would know that you need the gas valves open to start a flame. Unfortunately, they have no safety mechanisms like a flame safety sensor that would be typical to indoor gas appliances.
Aug 23, 2014 | Heating & Cooling
Gasolne smell around the car
Do not start car. Check fuel line at rear and gas fill tube. There is a high pressure gas line which can rust out. Your gas tank can be leaking.
Have someone use a flashlight, not a lightbulb fixture, to inspect the area for leaks. Lightbulbs produce heat and can shatter and spark to ignite the fuel.
Jan 21, 2014 | 2003 Lincoln Town Car
I purchased a used Masterbuilt veranda gas grill. The gas regulator fits a small propane tank. Is it possible to replace the regulator so it will fit a large sized propane tank?
Yes, it can be converted to accept a 20 Lb LP grill tan. Contact Masterbuilt Customer Service
1.800.489.1581 to obtain the new hose/regulator assembly.
Hope this helped you and Happy Grilling!
Jul 22, 2011 | Masterbuilt SBMPG3 Veranda Steel Grill
Where I can buy new heaating element and regulator, one is leaking current.
For replacement parts contact Masterbuilt Consumer Support 1.800.489.1581
Jul 13, 2011 | Masterbuilt SBMPG3 Veranda Steel Grill
Flame appearing from in back of front panel
This is usually a regulator problem, or a gas leak where the regulator line attaches to the back side of the knobs. Test for a gas leak first. You can use a mixture of water and liquid dish/hand soap. Saturate the area where the hose connection is, turn on the tank, but leave the knobs in the off position and do not hit the igniter. If there is a leak, you should see some bubbling where it is. If there is no leak, turn the tank off, open the valves (turn the grill knobs on) and bleed the gas out of the lines. Once it has sat for a few minutes with the knobs in the "high" position, turn them off. Then leave them off and turn on the tank, followed by one of the knobs and ignite the grill. see if the flame went away. I've seen this happen where there is not enough pressure in the line. Turning the tank off, the knobs on, bleeding the line, then closing the knobs and opening the tank and letting the gas build up pressure in the line before turning the knobs back on or trying to light the grill should resolve it.
May 11, 2010 | Char-Broil CharBroil Master Flame Gas...
Model 141.163211 Kenmore BBQ Grill. Burner tube ignites then after a few seconds flames ignite behind control panel - melted knobs. A year ago same problem. Removed all parts and cleaned, installed new...
It sounds like sealant may need to be used on connections. Use appropriate one for gas fittings.
Noting where the leak is occuring is important. Another possibility is the fuel is being somehow "jetted" from a hole or orifice in a burner tube to the area behind the control panel. These are hard to see what happens first when it does happen.
Nov 07, 2009 | Kenmore 16322
My Veranda grill sends fire out from under the control know panel. Yikes!
SOUNDS LIKE THE BURNER TUBE MAY HAVE A SPIDER WEB INSIDE IT YOU MAY NEED TO HAVE A LOCAL PROPANE CO.CHECK IT .
Nov 01, 2009 | Masterbuilt SBMPG3 Veranda Steel Grill
Veranda gas grill - won't light or low flame
One of the major problems with propane gas grills, including the Masterbuilt Veranda, is the pressure regulator. They get to where they do not release enough propane. Some, most, have an adjustment screw that will let you correct these problems. I think I replaced my Veranda regulator with another older pressure regulator from an old grill. Makes you crazy if you don't know this.
Mar 08, 2009 | Masterbuilt SBMPG3 Veranda Steel Grill
Gas leak in my GE profile JGP336
Contact your local gas company and turn off the gas to the unit.
May 01, 2017 | GE 30 in.Profile JGP940 Gas Cooktop
Masterbuilt ESBMPG Grill Logo
318 people viewed this question
Top Masterbuilt Grilling Experts
Paul Carew
Simon Flummox
Simon Flummox
Are you a Masterbuilt Grilling Expert? Answer questions, earn points and help others
