Question about KitchenAid Architect Series II KBCS24S 24" Beverage Center with Two Glass Shelves, 22 Bottle Capacit...
KitchenAid KBCS24LSBS Beverage Center install instructions
I have a space that is 34" H x 24"W x 25"D and the "approximate dimensions" for this item are listed as 34.5"H x 23.875"W x 26.625 D. The product description says to consult the installation instructions packed with the product. How can I view the installation instructions before buying the procduct? Specifically, can I remove the leveling feet and gain enough height (0.5") to fit my space?
2 Suggested Answers
  • 3247 Answers
SOURCE: I need the length, width height dimensions for a
if you cannot view this picture then go to kitchenaid site and type model number kuds02frss and select installation guide from the list. Please rate this solution if helpful or else post a comment.
Posted on Feb 25, 2011
I need the dimensions for Kitchen Aid Refrigerator model # KSRS25IKSS01
http://www.dostami.ru/KITCHENAID-Superba-KSRS25IKSS01-25-cu-ft/ebay-item/120871216158/description
Jan 12, 2013 | KitchenAid Superba Architect KSCS25INSS...
What are the dimensions?
You are missing a digit in the model number. KitchenAid Dishwashers have a number (0-6) after the SS.
The KUDI01FLSS0 installation guide gives the dimensions of the dishwasher opening and the unit itself on various pages. See http://www.kitchenaid.ca/assets/pdfs/literature/Installation%20Instructions%20-%208524480.pdf . The top vent and the front vent KUDI01FLSS model washers are slightly different. The front vent dishwasher dimensions are 33 7/8" H (with the wheels removed) x 23 7/8" W x 24 7/8" D (including the handle). The top vent model is only 24 1/2" deep. With the wheels in their lowest position, the opening for the dishwasher must be 34 1/2" high (from floor to the bottom of the counter top).
I hope this helps. Other KitchenAid appliance manuals are available here: http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=KAD . Use the search box to enter the model number and use the drop down menu to select Consumer.
Aug 14, 2012 | KitchenAid 24 in. KUDI01FLSS Stainless...
I purchased a 52 bottle kitchen aid wine cooler. No matter where I set the thermostat, it is always 45 degrees and readouts are sideways "T's" instead of numbers.
You will need Adobe Acrobat Reader to view these documents. The Adobe Acrobat Reader is available as a free download. arrow_results_summary.gif Get Adobe Acrobat Reader Click Here=> KUWA244PBS Parts List
and here=> KUWA244PBS User and Care Guide
If you should need the service manual you will need to cant me here=> HERE Reason is Whirlpool does not allow me to publish the SM here.
The beverage center and wine cellars have a temperature display for each zone. 12 volts
AC is supplied to the display board from a transformer in the unit compartment. The displays are only temperature displays and have nothing to do with any cooling function. A thermistor is used to sense temperature for each zone. The thermistor for the bottom zone is located inside the lower portion of the separator. The thermistor for the top zone on the wine cellar, (mid zone on beverage
center), is located in the upper portion of the separator. The thermistor for the beverage center upper zone is located on the inside of the 2-piece evaporator cover. It is on the right-hand side.
The mid temperature for the bottom zones on either unit are 60? Fahrenheit plus or minus 5 degrees. The mid temperature for the mid zone on the beverage center and the top zone
on the wine cellar is 45? Fahrenheit plus or minus 5 degrees. The mid temperature for the
top zone on the beverage center is 38? Fahrenheit plus or minus 5 degrees. I think at tis time you should check each section with a pocket size digital thermometer to cofirm tha the mechanical thermostat is within calibration. Click Here=> 4344690 Temperature Control
Click here for a=> KUWA244PBS Beverage Center Wiring Diagram
I believe the problem may be in the PCB transformer shown at the bottom right corner of the wiring diagram. It is possible o change the transformer but I have not been able to find the board that powers the LED temperature readouts. If needed let me know and I will call Whirlpool mfor you, Thanks, Sea Breeze
Oct 09, 2011 | KitchenAid KUWA244PBS Wine Cooler
Frigidaire ffbc46fsls beverage center refrigerator does not resume "on" condition after power glitch. If the unit is unplugged while running, then plugged back in, it resumes normal function,...
Wow if you have lost that much because the memory dumps during a power failure then we are going to need do something serious about that! May take me a while to come up with a solution but being the case I think you have a serious point to make. Acording to The
Frigidaire FFBC46F5LS Beverage Center User Manual
and on page 7 of the PDF
The default temperature for the beverage cooler is 41°F (5°C). The temperature after power failure will be the temperature set before the power failure. So something is wrong with the control board part=> Pc board,input ,display I believe I would call USA 1-800-944-9044 and ask why that may be happening. Below is a parts list.
Frigidaire FFBC46F5LS Beverage Center Parts
Hope this helps, Thanks, Sea Breeze
Sep 03, 2011 | Frigidaire FFBC46F5LS
Have not used the kegerator for several years. Plugged it in and it immediately started getting cold. Then I unplugged it to move it and when I plugged it back in it does not get cold.
Check to see if any of the compressor electrical items came loose when moving.
I had this happen to a customer and he called someone else in who tried to sell him a new compressor.
Apr 30, 2010 | Beverage-Air Kegerator - Beer Keg Cooler...
Center console disasembly instructions . we are trying to remove the center console
Base Console, Floor, Ranger, Explorer Removal and Installation
  1. Remove the two oval covers from the sides of the floor console. Remove the four (two on each side) retaining bolts. Lift or remove the front seat center armrest (644A22) from the floor console.
  1. Remove one screw from the top rear end of the floor console (directly under the front seat center armrest.
  1. Remove four screws retaining the utility tray beverage holder to floor console. Lift or remove the utility tray beverage holder from the console.
  1. Remove two screws (directly under the utility tray beverage holder) retaining the front end of the floor console to the console panel front mounting bracket.
  1. Lift the floor console from the front and rear console panel mounting brackets.
Apr 01, 2010 | 1996 Ford Explorer
When we plugged in our kitchenaid beverage center for the first time it is really, really noisy. It has a loud motor noise with a rattle? is this normal, will it go away when it is cooled down?
Did you lay it on it's side? If you did the oil in the compressor may have made it's way down the system. And when you plug in a fridge with no oil in the compressor it will make alot of noise and could damage the compressor. They say if you lay a fridge on it's side you should have it standing up for 24 hours before plugging in so the oil can make it's way back down to the compressor.
Sep 05, 2009 | KitchenAid Architect Series II KBCS24S 24"...
I need to add storage to my older dell dimension 3000. The 80 g hd is full and I am looking for a simple solution to add more space.
first remove any extraneous applications, and archive old data to a cd. Then run "Disk cleanup" and defrag drive. after that and if still not enough space, buy an external drive and follow installation instructions. Cheap fix.
Aug 29, 2009 | Dell Dimension 3100 PC Desktop
KitchenAid Architect Series II KBCS24S 24" Beverage Center with Two Glass Shelves, 22 Bottle Capacit... Logo
146 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
