Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
V-Belt Is contantly Worn
V Belt gets stretched after one use. Boggled.
I aslo need a detailed drawing of how to belt should be placed, in case I may have placed it incorrectly.
  • John1269 Mar 07, 2008
    nvm Solved :-)
  • 30 Answers
If you still need a diagram of the unit please refer to our database at http://www3.sears.com. Have your model number handy as that is necessary to pull up your specific model. Parts and part numbers are also available through that website.
Posted on Mar 07, 2008
How do i change the belt on a hoover model #U4509
Lay the unplugged vacuum upside down and remove the bottom plate covering the brushroll to remove the brushroll and belt. Make sure brushroll bristles aren't worn, replace it also if needed. Make sure brushroll will spin freely. Put new belt around motor shaft then around brushroll. Pull on brushroll with both hands to get enough leverage to stretch the belt far enough to drop the brushroll in place. Put bottom plate back on and insure brushroll will turn by hand before you turn it back on..
Nov 12, 2016 | Hoover Vacuums
The roller for my dyson does not turn and it does not pick up anything. Howevever, the hose suction is fine and I have checked all the places for dust blockages.
That means that the belt is stretched, worn or broken. You need to replace the belt. You can get replacement belts and view the manual with instructions here:
Dyson DC07 Belts and Manual
Dec 07, 2009 | Dyson DC07 All Floors Bagless Upright...
My roller bar wont spin the belt is on though
even though the belt is on and intact it still can be stretched and worn. If that is the case it won't be able to turn against the resistance of the carpet. Your particular model has (2) belts, a clutch belt and a drive belt. Both should be replaced yearly. You can get them here:
Dyson DC14 Replacement Belts
Nov 30, 2009 | Dyson DC14 All floors Bagless Upright...
Not picking up cleaned all of filters is there a belt for this
It might be because the belt is broken, stretched or worn. In all of these cases the vacuum won't pick up well. You can get the replacement belts for this model and download the manual which has instructions on how to change the belt here:
Bissell Lift-Off 37604 Replacement Belts and Manual
Nov 05, 2009 | Bissell 37604 Lift-Off Pet Bagless Upright...
The powerhead is weak, the brush turns until it is placed on carpet.
Empty the dirt collector. If there is insufficient air flow, the brushes will not spin.
-=/ Daft Tech /=-
Oct 25, 2009 | GE 106766 Bagged Canister Vacuum
My Hoover U6439-900 also losing belts
When upside down there is no resistance,on carpet there is.
You need to try a a fresh, genuine hoover belt and buy a spare, belts stretch and slip after 30 -90 a days of normal use, often to 25-30% oversize Hoover belts generally fit very snug. If your belt looks shiny inside, that is likely the issue. Try that and post results
Sep 28, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Majestic filter queen vacums
Your belt is either stretched or the wrong size or the brush bushings are worn and allowing the brush to wobble or the motor is loose in its housing. You need to check all.
Rotate the brush and try to wobble it from the pulley end.
Flip the belt inside out, it if appears cupped, cracked or shiney and slips easily on and off the brush it is stretched. Generally this unit needs anew belt evrey 6 months, broken or not, they get hot and stretch. Do not buy a new belt by matching size, a worn belt can be 20-30% oversized and not broken but totally useless.
The motor shaft should be cleaned with W/D 600 grit sand paper. Motor should have no wobble in the shaft
Sep 09, 2009 | Vacuums
Kirby g4 brush wont turn belt ok
your belt has probably been stretched to the point where it will not work so good.
Jul 02, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Hoover mach 4 burning smell
There are two reason you could be smelling a burning smell-
1. The belt is too stretched out and needs to be replaced. This causes it to slip when the vacuum is on and will create that type smell. You can avoid stretching and having to replace the belt to often by releasing the belt after each vacuum.
2. There may be hair or other debris stuck around the rod that the belt is attached to. Can be avoided by checking after vacuuming.
Hope this helps
Nov 12, 2008 | Hoover Vacuums
Oreck belts keep coming off
If the pulley on the brush roll is worn, then I would replace the brushroll. Look at the ends where the brush roll sits in to make sure the casing hasn't over heated and not holding the brush in place. Also make sure the motor is shifting and causing the belt to come off. Another is if you are catching a rug or towel, that also will cause the belt to come off. I am assuming you using a new belt and not a worn one. After only a short time, belts stretch and need to be replaced.
Jan 22, 2008 | Kirby G5 Bagged Upright Vacuum
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
