Question about Acer NSK8458AN Keyboard
Types in upper case only (without caps lock/shift key locked)
The caps lock light is not illuminated - I have tried to clean the keyboard but it still types in upper case only....... I don't want to remove the keys (yet) as I may have problems getting them back on. My external keyboard works just fine so I'm guessing it's 'dirt' under they keys?
Doo you have ideas of what the problem may be
Thanks, Ann
  • 2 more comments
  • Ann Tasker Mar 08, 2008
    I don't know what a P.O.T. is, would you please explain. Yes it is an Acer laptop.
    I certainly appreciate your suggestion
  • Anonymous Mar 10, 2008
    I HAVE TRIED DEACTIVATING STICKY KEYS BUT I AM STILL HAVING A PROBLEM WITH MY KEYBOARD I CANT USE ANY OF THE LOWER CASE SYMBOLS PUNCTUATION AND NUMBERS ARE NOT WORKING
    THANKS
    JAN
  • Anonymous Jun 07, 2008
    MY NEW DELL LAPTOP ONLY TYPES IN CAPS EVEN THOUGHTHE CAPS LOCK IS NOT SELECTED
  • Anonymous Mar 22, 2014
    Problem is a reversed function in the CAPS LOCK light. When CAPS are ON, light is off. When CAPS are off, light is on. Was reversed yesterday, and my preference (LIGHT ON WHEN CAPS ARE ON). Suggestions to change it back?
  • 46 Answers
In most cases yes, BUT since the light for caps lock is not comming on you might have a bad P.O.T. on the keyboard layer.. Since im assuming we are talking about a laptop..
Posted on Mar 07, 2008
How to tell if caps lock is on
Some keyboards will have a light that goes on when caps lock is turned on
Unlock the Caps on Computers
The All-Caps or "Caps Lock" function causes all letters to appear as capital letters when typing into word processing documents, emails or other files.
This is convenient when needing to type numerous capital letters or All-Caps phrases, as you do not have to hold down the "Shift" button with one finger as you type the words.
When All-Caps is stuck and does not respond to the "Caps Lock" keyboard button, a simple procedure overrides and shuts down the function.
Open a word processing program.
Press the "Caps Lock" button located on the left side of the keyboard to turn Caps Lock off. Type inside the document.
If lower case letters appear in the document, Caps are successfully unlocked.
Proceed if the text is in All-Caps.
Hold down "Shift" on the keyboard. Press the letter "P."
A lower case "p" appears in the document. Release the "Shift" button.
Type the phrase "rint" directly after the lower case "P." The word "pRINT" is now in the document, and the document cursor is after the phrase's "T."
Press "Enter" on the keyboard.
The cursor goes down one line and "pRINT" becomes "Print." The "Caps Lock" function is turned off.
Restart the computer to save the setting.
Enable the Caps Lock Key
The "Caps Lock" key is loved by some and disliked by others.
The key turns all letters into capitals as you type.
While this feature is useful in some situations, a more common occurrence is that the key is accidentally hit and all the text typed is capitalized.
The person typing must then delete the capitalized type and rehit the key to turn off "Caps Lock."
If the "Caps Lock" key needs to be enabled, it indicates that someone has disabled or remapped the key.
If a user wanted to, the "Caps Lock" key can be disabled and enabled through the registry or remapped through the control panels.
Updating the registry for the keyboard will enable the "Caps Lock" key.
Open the Notepad program.
Type the following:
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout]
"Scancode Map"=-
Select "Save As" from the "File" drop down menu.
Navigate to the computer desktop as the save file location and choose "All Files" from the "Save as type:" drop-down menu at the bottom of the Save As window.
Type "enable.reg" without quotes in the "File name:" field and click "Save."
Minimize all open windows to view the desktop.
Double-click on the "enable.reg" file. A box will pop up asking if you are sure you want to run the file. Select "Run" or "Yes" and then click "Yes" for the Registry Editor warning.
Reboot the computer. The registry will be updated and the "Caps Lock" key will be enabled.
Manually Update the Registry
Click the "Start" menu, type "regedit" without the quotes and press "Enter." In older versions of Windows, Click the "Start" menu, select "Run," type "regedit" without the quotes and press "Enter." This will launch the Registry Editor.
Navigate to "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout" to view the settings.
Right click on the "Scancode Map" setting and choose "Delete." Click "Yes" to confirm the deletion.
Disable the Caps Lock Key in Windows
Your computer's Caps Lock key has likely only collected dust since you first brought the machine home.
The Caps Lock key is beneficial if you want to type a long string of words entirely in capital letters, but this form of typing is not needed often.
Consider disabling your Caps Lock key if you do not need it, or if you are tired of hitting the key accidentally while rapidly typing.
Restart your computer before beginning the process of disabling your Caps Lock key.
Download the registry file necessary to disable your Caps Lock key.
You have the option to disable your Caps Lock key or change the key to a number of different keystrokes.
For example, you may choose to use the "ChangeCapsToShift" registry file if you want the Caps Lock button to function as a shift key.
Double-click the registry file you have downloaded.
A prompt will appear on your screen asking if you would like to add the registry file to your computer's registry.
Select "Yes" to install the registry file.
Restart your computer, once again, to complete the registry change.
Upon reboot, your Caps Lock key will no longer function as a traditional Caps Lock key.
Disable the Caps Lock Key on a Computer
The Caps Lock is an easy key to hit by accident, and often the user does not realize it immediately.
When this mistake occurs, usually you must correct some text errors and your time is wasted.
If you think the Caps Lock key is more of an aggravation than it is good, follow these steps to disable your Caps Lock key.
Click on "Start" and select "Run". Type "regedit" into the textbox and hit "OK". This command will open the "Registry Editor" window.
Select "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control".
Double click on "Keyboard Layout" to open the folder.
Open the "Edit" menu and choose "New" then "Binary Value".
A new file will appear on the right side of your screen with the file name highlighted.
Type "Scancode Map" for the new file name.
Double click to open and type in "00000000 00000000 0200000000 003A00 00000000" into the Value data box. Hit the "OK" button.
Close the "Registry Editor" by selecting "Exit" from the "File" menu.
Restart your computer for the change to go into effect and enjoy life without the Caps Lock Key.
Hope this helps
Nov 05, 2012 | Computers & Internet
How i can unlock shift
If you are printing all CAPS then it is the Caps Locks key. It is located just above the shift key on the left side of the keyboard. There should also be a light on the laptop indicating the Caps lock is on.
Hope this helps
Jun 11, 2012 | HP Computers & Internet
I can`t get any upper case functions to work on hp 2011 keyboard what key do i press
1.Make sure the "Caps Lock" key is not on. Though this will be obvious to most people, if your keyboard is typing in only upper-case letters it can't hurt to check. Look at the "Caps Lock" indicator light on the top right corner of your HP keyboard. If the light is on, strike the "Caps Lock" key on the left side of your keyboard. This will turn the "Caps Lock" off, allowing you to type in lower case letters again.
2.Make sure the "SHIFT" keys on your HP keyboard are not stuck. Dust and dirt can build up on a keyboard over time, which can cause certain keys to stick. If either of your keyboard's "SHIFT" keys get stuck, your computer will type in only capital letters. Use a toothpick or cotton swab to remove the gunk from the key, which should help it return to its normal position.
3.Unplug your HP keyboard and then plug it back it. This will remove the device from your operating system and then automatically add it back in. This can have the same effect, essentially, as restarting your computer. If your keyboard was typing in capital letters due to an error being stored in your operating system's memory, that error will now be cleared and the HP keyboard will function as normal again.
4.Update your HP keyboard driver. Click "Start" and then right click on "Computer." Click "Properties" and then "Device Manager." Right click on the listing for your keyboard and then click "Update Driver." This will update the computer software that is associated with your HP keyboard. If your keyboard was typing in all capital letters as a result of an error with this driver, the error will now be fixed and you can use your keyboard normally again
Mar 01, 2011 | HP D8597A Keyboard
My upper case S KEY WILLL only work if I have cap locks on. can you help me? ' Im using the MX5500 keyboard. thank you. Greg
Have you tried cleaning the keyboard, especially blowing it out with compressed air. Have you tried to use both shift button to see whether or not the problem is isolated to one shift button or both.Have you tried other letter with the same shift button that the letter "s" is having problems with. If this is islolated to just the letter "s" with the shift buttons then more than likely you will just have to use caps lock or buy another keyboard.
Nov 18, 2010 | Logitech MX5500 Keyboard/Mouse
MY KEYBOARD DOES NOT WORK WELL. FOR INSTANCE, I CAN NOT TYPE M WIthout holding the right side shift.
brand new Compaq 620 the keys stopped working. FIrst with 6,7, "_", then some other character keys also stopped working. Please let me know how to fix it.
Jun 20, 2009 | Computers & Internet
Cannot find the upper case indicator (light) on the keyboard
More than likely you have purchased a keyboard without the lights. There is such a thing. I would try pressing the Num Lock, Caps Lock, and Scroll lock keys. If the keyboard has lights, you should easily be able to see three lights lit up. If not it is pretty safe to assume that the keyboard has no lights. Next time if you were to list the name and model of keyboard it would be easier to diagnose problems. More info is almost always more helpful. Hope this helps.
Mar 23, 2009 | Computers & Internet
Status light on upper right illuminated - how to turn it off?
Initially, have you checked/pressed on the "Scroll Lock" key (between Print Screen & Pause). To my knowledge, on most keyboards, the three common indicator lights are: Num Lock, Caps Lock and Scroll Lock.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 13, 2008 | Ingram BTC-5199 Keyboard
Keyboard stuck in upper case
Is the caps lock light illuminated? If so, you might have to hold shift and hit caps lock to turn off the caps lock. This is an option for old typists who came from manual typewriters that you might have turned on by mistake.
Mar 05, 2008 | Acer NSK8458AN Keyboard
Acer NSK8458AN Keyboard Logo
1,195 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
