Question about Mintek MDP-1020 Portable DVD Player
Stopped playing...all DVD/CD
After we have dvd/cd loaded....it spins stateing "Load Disc" then after a while it shows a "No Disc"
  • 1 more comment
  • Freelife Mar 16, 2008
    Tried LENS cleaner....same issue exist. Is this company still in business, the unit is under warrenty
  • Freelife Mar 17, 2008
    Tried with no success.....will try and return unit since mfg is out of business
  • bori21701 Jun 18, 2008
    all dvd/cd would not work (no disc)
TRY CLEANING THE LENS WITH A SPECIAL CD LENS CLEANER.. YOU CAN BUY IT WALGREENS OR WALMART
Posted on Mar 07, 2008
Have a panosonic dmr-ez485v dvd recorder that cycles 5/6x when tray is closed with/without a dvd, and get "no read' message.
1.The DVD Drive makes two-three times noise than stop spin the media CD
or DVD.
-Bad DVDRW Drive.
2 The drive does spin CD-DVD but doesn't load.
-. Bad NDMi PCB VEP79180 or VJB79180
3. Drive spinning but don't load CD or DVD
More chance Bad Drive or Problem with drive PCB.
Open top Cover of drive, open tray,
close tray.
If laser flashed but doesn't play CD-DVD more chance bad drive PCB
Check: avsystemparts.com
Feb 01, 2013 | Panasonic DMR-EZ485VK DVD Recorder/VCR
Disc shows loading then error on all dvd disc
Put a cd in the dvd player if it is marked that it plays cds... if it plays the cd your dvd laser is shot... cheaper to get a new unit. if it doesn't play a cd try cleaning the laser. and last but not the last thing try unplugging it for a short time then plug it back in... if nothing works get the one tool that fixs most everything...... take it to office depot and they can recycle the stuff inside and help keep the earth green...then onto wally world.
Nov 26, 2009 | Philips DVP5140 DVD Player
Discs won't play.
please change laser unite then solve your problem
Jul 16, 2009 | Sony DVP-NS575P DVD Player
Disc does not spin and shows on screen that there is no disc
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you. I hope this information helps you with your problem.
Mar 29, 2009 | Mintek MDP-1810 Portable DVD Player
Dvd player refuses to read any disc I load into the machine
Hello I was looking to try and help you with your DVD player, we will start by loading a music cd store purchased, no burned cds please, if the cd loads and plays then your dvd player is either out of adjustment or going bad, most dvd players, i have worked on, will load and play a music cd, but will show loading errors when trying DVD's. If the music cd dosen't load then there could be an issue with the drive or tray. If the music cd plays just fine, then your laser is either out of adjustment or going bad. You can call the manufacuter to see if there is a process for resetting the DVD player, not all DVD players have this option, if resetting the DVD player dosen't work, but music cd's do then your laser lens is dirty or going bad. At this point you have three options 1) Take it to a repair shop, 2) Get an new one, 3) Get your hands dirty if your really handy and know what your doing to clean and replace the laser. I hope I can be of further assitance and I look forward to helping in the future, Thank You and have a nice day.
Jan 14, 2009 | Televison & Video
Portable dvd player showing"no valid disc"
try to clean the lens using cd cleaner or cotton buds with drop of water on it. that really works.
Dec 03, 2008 | Venturer PVS177W Portable DVD Player
Playing dvd's
Inside the Control Panels, look for System. Double-click System and choose Device Manager. Inside Device Manager, find the CD/DVD and "Uninstall" the device. Restart the computer and let it re-load the driver. This might help. You can also try a CD/DVD laser lens cleaner.
Nov 12, 2007 | LG (GCC-4522BI) CD-RW/DVD-ROM (Combo)...
Check disc
Change your DVD player
May 23, 2007 | LG DE9523P DVD Player
Dvd does not load
clean the lens of your dvd if that does not work there is a strip connected to the lens have that replace or adjusted by a tech.good luck.
Apr 03, 2007 | Samsung HT-DS1000 System
Televison & Video Logo
228 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
