Question about Creative Labs Zen V MP3 Player
Zen v plus
My computer wont reconize my zen v plus mp3
  • animal418 Mar 24, 2008
    my player isn't recognised by the computer. the player is still charging fine and it plays alright but i cant put anymore musiconto it.
  • jeetu123 Nov 16, 2008
    xxxxxxxxxxxxx
    President:
  • 4,402 Answers
Make sure you have media player 11
If you can, the best test is to try your player with another PC, to see if you still have the problem. This localises whether the problem is with the PC (most likely the USB) or the player. See the link below (search on "connection problems") for a lot more troubleshooting on this.
Download recovery tool off creative's website.
go to my computer > click on hardware tab >
click on device manager button > in the is next screen on the bottom should have>>universal serial bus controllers
(write these down just in case it cant find them)
right click on them and uninstall
reboot let windows reinstall them
Also told Microsoft hotfix causes this problem try uninstalling the last hotfix
If that doesn't fix it try the USB cable
good luck
please mark the post with a fixya
Posted on Mar 17, 2008
My player wont turn on even when i try reset it ,when charge, it wont reconize and the mp3 led stays lighting when charge
Figured it out myself. Had to reset it and reformat. Now it needs to convert the files (I have no idea why) before installing them.
Jun 11, 2009 | Creative Labs Zen Stone Plus MP3 Player
It wont Work :(
I would try to get into the recovery menu and see if you can run a clean up first (a clean up will not erase anything on the player).
To access the recovery menu
1. Detach the Zen player from your PC , and ensure that the Zen Sleek is turned off.
2. Connect the power supply to the player.
3. Hold down the Play/Pause button while inserting a paper clip into the Reset hole underneath your player, beside the data/power connector. Keep on holding the Play/Pause button while you release the Reset button. The Rescue Mode screen will then appear.
4. After the recovery mode has started, release the Play/Pause button.
Again if you can get into this menu, try a clean up first to see if that resolves the problem. Clean up should be the first option in the menu.
Apr 08, 2009 | Creative Labs ZEN SLEEK MP3 Player
My Zen V Plus is really screwed up
Sounds like a similar problem I had today.
My Creative Zen V Plus wasn't recognised by my PC, then it wouldn't even switch on.
Following the solution of another similar problem on here I fixed it. Connect your Zen via USB to your computer and press the reset button. Should spring to life and start re-building your library. I am as I type adding new tracks to mine :))
Apr 04, 2009 | Creative Labs ZEN V Plus MP3 Player
Help WIth ZEN V PLUS 2GB
mine too it wont reconize it because it frezzes I need help so it dosent freeze
Jul 11, 2008 | Creative Labs ZEN V Plus MP3 Player
Wont detect Zev V plus
ok... i found a fix...
insert zen v plus install cd
exit out of autorun for cd
go to control panel
click on system
click on the hardware tab
click on portable devices
right click on your USB device with the yellow warning sign
go to properties
when it tells you that the drivers arent installed... go to the browse button and select your zen v plus install disk
hit ok and it will find the drivers that way...
Apr 04, 2008 | Creative Labs ZEN V Plus MP3 Player
Help with zen problem
Push the reset button. This worked for me.
Mar 09, 2008 | Creative Labs Zen Stone Plus MP3 Player
My zen v plus wont turn on
Zen V is dead
"If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
Dec 26, 2007 | Creative Labs ZEN V Plus MP3 Player
Stuck on second screen where it says zen v plus
How to reset Zen v +
http://www.youtube.com/watch?v=22T_gkkZjmM&feature=related
Dec 25, 2007 | Creative Labs ZEN V Plus MP3 Player
Zen nano plus mp3 player 1gb
I`ve had the same problem twice, it seems the player erases the whole firmware when this happens. You can fix this by plugging it to your computer in recovery mode, this will allow you to reinstall firmware.(Search google for zen nano plus recovery mode to find instructions.)
Sep 10, 2007 | Creative Labs Zen Nano Plus MP3 Player
Creative Labs Zen V MP3 Player Logo
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
