Question about Canon imageCLASS MF6530 Monochrome Laser Copier/Printer
PROBLEM WITH THE COPIER
OOUR COPIER AT THE OFFICE DOES NOT WANT TO COPI AT ALL
IT HAS A NEW INK BUT I DONT KNOW WHAT TO DO..WE REALLY NEED IT.
ARACELI
aesqueda76119@yahoo.com
  • Joecopier Apr 06, 2008
    Same problem
  • cali_100 Aug 29, 2008
    my copier is cannon image class 6530. It is 1 year old, and I have bought 4 new cartridges. All I get is blank paper or horizontal lines. What can I do? I really need it. I have turned it on/off, unplugged it. change cartridges, and nothing. My other canon copier 2 yrs old, did the same. the paper kept jamming, no matter what type of paper I used. That's why I bought this one. Is there a better brand to buy? because I am getting really tired of these copiers.
    Martha
The laser shutter is stuck closed. you can remove the cartridge and look nin the cartridge area above where the cartridge should be. you will see a long thin window.there is metal cover that is supposed to open when the cxartridge is inserted. try to manually open it with a small screwdriver
Posted on May 06, 2009
Prints blank copies
Posted on Mar 13, 2008
Mesin foto copi minolta cs pro ep 4000, setelah saya ganti sponge rol busa, toner tidak mau keuar melalui sponge rol dan keluar kode eror C0f030. mohon solusinya, thank
When was the last time the developer was replaced in the developer unit? If has been replaced, then you might have a bad ATDC (Automatic Toner Density Control) sensor Located right below the developer unit. If the developer was replaced when it was done was a vacuum cleaner used? IF so the static electricity from the vacuum clear destroyed the sensor, NEVER USE a VACUUM cleaner to remove the developer. Also when the developer was replaced, was counter cleared to tell the copier developer was replaced, the copier uses the counters to determine certain voltages for certain assemblies, if not image problems and codes can appear. Finally, was the F8 run after the developer was installed before ant prints or copies made? If not buy new developer and start over, counter is to be cleared first, then developer replaced, then F8 run.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 02, 2017 | Minolta Office Equipment & Supplies
Sir.mam,
Oour Lexmark 4600 copier/scanner copies just fine, but we can't get it to scan.
I've you have a manual, you can find it in there.
I've not?
Contact Lexmark for a online manual
Jun 12, 2011 | Lexmark Office Equipment & Supplies
I have a brand new kodak esp 3200 all in one printer. The ink cartridges do not last for the 400 or so sheets that is says but that is not the problem. The quality of the print is not good. I constantly...
Brand new ? take it back to the store ? ask for a replacement but pick a different brand ,maybe a small $ adjustment might be necessary depending if you pick a more or less expensive brand .
Oct 23, 2017 | Kodak ESP 3 Multifunction Printer/ Copier/...
I CAN'T PRINTING A DOCUMENT
I am glad to help. Magenta is a color...Please send the make and model of the printer.
Thanks!
May 27, 2009 | Brother Multi-Function Center MFC-240C...
Ar 5316 copy lamp off
You may have to replace the lamp unit...but ... I would first make sure all connectors have been re-seated.
Remove the main glass and make sure all ribbon/wire connectors are unplugged and re-inserted. (make sure copier is off). You could also remove the back cover of the copier and unplug/replug all connectors just to be sure.
You never know !
Apr 07, 2009 | Sharp AR-5316 Advanced Digital Imager...
Massage unsupport ink on lexmark X4270
Sadly, not all inks are created equal, and even inks that are claimed "compatable" are not allways safe. My HP photo printer worked great for 2 years, then I put in a "will fit" from a name brand office supply store, the printer nozzles plugged on the second print, never to print correctly again. My replacement printer is a Kodak 5300 all in one, chosen for low ink costs/ hi-output, and I get photo-lab quality, borderless prints day after day. (I'm a photographer/artist) I have run 6 color and 5 blacks for thousands of graphics, in a period of 2 months getting ready for a showing, with maybe 1 or 2 misprints.
Nov 20, 2007 | Lexmark X4270 All-In-One InkJet Printer
Canon imageCLASS MF6530 Monochrome Laser Copier/Printer Logo
177 people viewed this question
old marine
old marine
