Ownersw manual does not list fuse for horn do not hear the relay engage or i do not know location of relay i assume it is with the fuse block under hood need wiring schmatic please.
Here is a link to the wiring schmatics. The horn circuit is on page 27. http://www.pswired.com/misc/pacaudio/syswire.pdf
Testimonial: "trace circuit and found horn buuton in the steering wheel malfunctioned Thank you"
YOU HAVE RELAYS IN ENGINE COMPARTMENT AND SOME UNDER LEFT END OF INSTRUMENT PANEL CHECK FUSE AT THE LEFT END OF INSTRUMENT PANEL.THE FUSE COVER SHOULD SHOW WHAT NUMBER FUSE IS HORN FUSE.IF HORN FUSE GOOD.REMOVE HORN HOT WIRE IT IF WORKS.YOU COULD HAVE A FAULTY HORN PAD.IF HORN DONT BLOW WHEN HOT WIRED IT NEED REPLACING.
