Question about Linksys (NR041) Router
Additional computers & internet access
Main router has one of 4 wired port going to outlying building with one(1) computer. Connecting this one computer to internet, not a problem.
Two additional computes now being added to outlying bldg & do not want to bury addional cat-5 cable or go wyfi.
I have a Lynksys NR041 wired router. Can I use this to connect line coming from main source then connect computers via the "uplink" function? If so, how is this done?
Karl
Rural Retreat, VA
    Scholar:
  • 141 Answers
You can do this. Identify the ip address of your main router. EXAMPLE: If your main router has 192.168.1.1, you can connect the cat5 cable from your main router to the INTERNET PORT of the NR041. Set the NR041 ip to 192.168.2.1.
JUST MAKE SURE THAT THE IP ADDRESS OF THE TWO ROUTERS ARE DIFFERENT.
You can then connect the 3 computers to the NR041
Good Day
Posted on Mar 14, 2008
My linksys w/2phone ports cannot hook up with the ethernet
Most Cable Internet Service Providers (ISPs) use Media Access Control (MAC) Address authentication to establish Internet connection for end-users. MAC address is a unique identifier assigned to the network adapter/s of the computer.
To set up your Linksys router to work with a Cable ISP, you have to enable the MAC Clone feature of the router. MAC Cloning is a procedure which enables a router to copy the MAC address of the computer registered with the ISP.
To set up a Linksys router with Cable connection, you need to perform four steps using the computer that's been registered with the ISP:
i. Verifying Internet Connection
ii. Connecting the Devices Together
iii. Checking the Router's LEDs
iv. Setting Up a Linksys Router for Cable Internet Connection
Connect the computer to the Broadband modem using an Ethernet cable without the router installed. If you cannot get online, contact your ISP. If it's online, use the computer to set up the router.
NOTE: Some cable modems use the USB port. If the physical connection is via USB port, you may not be able to go online via Ethernet connection. Contact your ISP to have the Ethernet port of the modem configured.
kb17251-001_en.png NOTE: The image may vary depending on the computer and modem you're using.
After confirming the Internet connection through the modem, connect the modem to the Internet port of the router; connect the computer to any of the four Ethernet ports at the back of the router. For instructions, click here.
After connecting the devices together, check the lights on the front panel of the router. Ensure that the Internet light, as well as numbered light corresponding to the Ethernet port where the computer is connected, is lit. For further instructions, click here.
Step 1:
Access the router's web-based setup page. For instructions, click here.
NOTE: If you are using a Mac computer to access the router's web-based setup page, click here.
Step 2:
On the Setup tab, click the MAC Address Clone sub-tab.
Step 3:
Select Enabled then click Clone My PC's MAC.
Step 4:
Click Save Settings.
Step 5:
Click the Status tab.
Step 6:
Check the Internet IP Address. If the Internet IP Address has numbers, this means the router has been properly configured. You should now be able to access the Internet. If you're still unable to access the Internet, powercycle the modem, the router and then restart the computer.
NOTE: If the IP address is still 0.0.0.0, click IP Address Release then, click IP Address Renew. If this does not change the IP Address, powercycle the modem, the router and then restart the computer.
Nov 14, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
SkyLine Wireless Broadband Gateway (PN8584-1) Router: I do not have the instruction book for this router...
Your main computer should plug directly into the router. Just remember, your other two computers, if they are NOT laptops, have to be WIFI ready (additional hardware). Laptops come with this hardware.
Nov 30, 2017 | Proxim SkyLine Wireless Broadband Gateway...
I have a laptop that as access to the 2Wire router but cannot access the internet. The three other computers on the network have internet access. I changed the computer name and that did not work. I...
I dont understand "2 wire router" ... do you mean you have two cat 5 cables plugged into your router? You only have a 2 port router?
The name of your computer is of no consequence in this regard. Pleae check the cable before yo go much further.
XP is normally very good at connecting ...
I recommend Network Magic to solve all kinds of network issues, including connectivity, security and sharing. Get free eval copy by searching Network Magic.
Dec 30, 2009 | 2wire (1000-400108-001) Router
Dlink dir 300 internet problem
First you have to make sure that you connected it correctly. the cable coming out of the modem should be connected to the single port (Internet port) at the right when facing the back of the router.
All computers that are wired through it should be able to access the internet. if one of your computers cannot access the internet you may want to check the IP address that you are getting. (go to a command prompt and type ipconfig).
If you are connecting a wireless computer check the wireless security setting which you can find at the configuration (setup) page of the router. to access the configuration page check the owner's manual.
Oct 08, 2008 | D-Link / RangeBooster N 650 / DIR-635 /...
Wireless router to modem problems
Since it says network cable unplugged on the computer when wired to the router, you need to check these first:
â Make sure that the Ethernet cable is connected from the modem to the router’s Internet (WAN) port and the computer to the numbered port of the router. The computer should used to be connecting to the Ethernet port of the modem, if not; you should contact your ISP first.
â Make sure that the Ethernet adapter/LAN card on your computer is working properly. You can check that on the device manager of your computer.
â If those are all working fine that would mean the router is not yet configured for Internet access or we can say that the settings for the provider are not synchronized with the router.
To configure the router, you can do these general steps:
1. Connect the computer to the numbered port of the router and the modem to the router’s Internet (WAN) port.
2. Turn off the computer, router and modem.
3. Turn on the modem first, wait for the lights to stabilize then turn on the router. As soon as the lights are stabilized, you can turn on the computer and check for internet connection.
However, if the Internet connection still does not work. That means there are additional settings needed to be done. You can message me about the name of your ISP and I will provide you the specific steps you need.
Sep 23, 2008 | Belkin (F5D7230-4) Router (587009)
DI-714P+
Generally for your wired machines assuming your internet connection starts at the
phone wire coming out of a jack or the
cable company's cable.
Either of those connect to a modem device
An ethernet cable from the modem device connects to either
a computer as you have not
or
the WAN port of the router (very seldon the LAN side)
additional computers can connect to the
LAN ports of the router (often a block of 4)
Let me know if you need additional assistance by adding a comment to this message
Dec 23, 2007 | D-Link AirPlus DI-714P+ (DI714P) 802.11b
How To Make a DMZ
A router normally stops incoming Internet traffic from getting on your network, unless the traffic is in response to one of your computers or when using port forwarding. But instead of discarding the incoming traffic or using port forwarding, you can send incoming traffic to one computer on your network by establishing a "Default DMZ Server". (DMZ = humorous reference to "Demilitarized Zone".) This avoids you having to figure out what ports an Internet application wants ? by throwing all ports open for that computer. For regular network operation, NETGEAR recommends you do not use a DMZ. A computer with DMZ loses firewall protection, and is exposed to exploits from the Internet. If compromised, your own computer can attack the rest your network. Instead of DMZ, use port forwarding, as described in How is Port Forwarding Configured? However, the DMZ server feature is helpful: * When you have a problem connecting to an Internet service. Setting up a DMZ will determine whether a closed port is responsible for the problem. * With some online games and videoconferencing applications that are incompatible with NAT. Follow the procedure under your router model to create a DMZ To Create a DMZ for RP614, MR814, FVS318, FVM318, WGR614 1. Open a Web browser, and type the router's IP address (The router's default IP address is 192.168.0.1). Click Go. 2. Enter the username and password for the router (Default username is admin and password is password). 3. From the browser Main Menu select Advanced > Security. Some routers, such as the MR814, use the WAN Setup Options, page, instead. 4. Enter the server's IP address. 5. Click Apply. To Create a DMZ for FR114P, FR114W, FM114P, FR328S, FVL328 1. Open a Web browser, and type the router's IP address (The router's default IP address is 192.168.0.1). Click Go. 2. Enter the router's username and password (Default username is admin and password is password). 3. From the browser Main Menu select Advanced > Security. 4. Click Rules. 5. Check the box for Default DMZ Server, and enter the server's IP address the corresponding box for the IP Address. 6. Click Apply. To Create a DMZ for RH340, RH348, RT328, RT338, RT311, RT314, RP114, RO318, MR314, DG814 * Going through the GUI and going to Port Forward in the left menu bar. * For RM356: Going through telnet and from the main menu go to menu #15. 1. Open a Web browser, and type the router's IP address (The router's default IP address is 192.168.0.1). Click Go. 2. Enter the router's username and password (Default username admin, password 1234). 3. From the Main Menu of the browser interface, under Advanced, click Port Forwarding to view the port forwarding menu. 4. Enter the IP address of the DMZ server in the corresponding Server IP Address box. 5. Click Apply at the bottom of the menu.
Feb 19, 2006 | NetGear RO318 Router
How To Make a DMZ
Feb 19, 2006 | NetGear MR314 (MR314NA) Wireless Router
How To Make a DMZ
Feb 19, 2006 | NetGear MR314 802.11b
How To Make a DMZ?
A router normally stops incoming Internet traffic from getting on your network, unless the traffic is in response to one of your computers or when using port forwarding. But instead of discarding the incoming traffic or using port forwarding, you can send incoming traffic to one computer on your network by establishing a "Default DMZ Server". (DMZ = humorous reference to "Demilitarized Zone".) This avoids you having to figure out what ports an Internet application wants ? by throwing all ports open for that computer. For regular network operation, NETGEAR recommends you do not use a DMZ. A computer with DMZ loses firewall protection, and is exposed to exploits from the Internet. If compromised, your own computer can attack the rest your network. Instead of DMZ, use port forwarding. However, the DMZ server feature is helpful: * When you have a problem connecting to an Internet service. Setting up a DMZ will determine whether a closed port is responsible for the problem. * With some online games and videoconferencing applications that are incompatible with NAT. Follow the procedure under your router model to create a DMZ To Create a DMZ for RP614, MR814, FVS318, FVM318, WGR614 1. Open a Web browser, and type the router's IP address (The router's default IP address is 192.168.0.1). Click Go. 2. Enter the username and password for the router (Default username is admin and password is password). 3. From the browser Main Menu select Advanced > Security. Some routers, such as the MR814, use the WAN Setup Options, page, instead. 4. Enter the server's IP address. 5. Click Apply. To Create a DMZ for FR114P, FR114W, FM114P, FR328S, FVL328 1. Open a Web browser, and type the router's IP address (The router's default IP address is 192.168.0.1). Click Go. 2. Enter the router's username and password (Default username is admin and password is password). 3. From the browser Main Menu select Advanced > Security. 4. Click Rules. 5. Check the box for Default DMZ Server, and enter the server's IP address the corresponding box for the IP Address. 6. Click Apply. To Create a DMZ for RH340, RH348, RT328, RT338, RT311, RT314, RP114, RO318, MR314, DG814 * Going through the GUI and going to Port Forward in the left menu bar. * For RM356: Going through telnet and from the main menu go to menu #15. 1. Open a Web browser, and type the router's IP address (The router's default IP address is 192.168.0.1). Click Go. 2. Enter the router's username and password (Default username admin, password 1234). 3. From the Main Menu of the browser interface, under Advanced, click Port Forwarding to view the port forwarding menu. 4. Enter the IP address of the DMZ server in the corresponding Server IP Address box. 5. Click Apply at the bottom of the menu.
Feb 19, 2006 | NetGear RP114 Router
Linksys (NR041) Router Logo
207 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
