Question about OKI C5300n Led Printer
Fatal error 172
I have been having no luck finding out what a fatal error 172 on a oki 5300 indicates. Using oki tech support UK I found that a fatal error 171 is a fuser error. But have not hear back on a 172. IF you bcan help me please e-mail me at aalcomp@gmail .com Thank you JD Watson.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 97 Answers
From OKI error list:
Error 172 - Upper Heater Temp State: High
Heat Roller Thermistor indicates high temp
Solution:
Turn off printer, let cool down.
If problem still exists seek service
Posted on Dec 08, 2008
I have an OKI 5650 printer and am getting a 172: Fatal Error - how do I fix this?
Abnormal temperature
detected by
fuser thermistor
(high-temp or low
temp.)
Turn power ON again.
Replace fuser unit.
Feb 12, 2010 | OKI C9300 Led Printer
Oki C3200 message on screen says '171 Fatal
Yes it can be saved, it is indicating the fuser thermister is open or below temperature. Try opening the printer and restarting it. If that does not fix it you may have to replace the thermister or the fuser
Jan 18, 2010 | OKI C3200n Led Printer
Our OKI C5100 is showing 171:Fatal error. What should we do?
The 171 Fatal error:
Upper Thermistor, State:Open
When an open circuit has been detected in the heat roller thermistor (low temperature)
Check the heater connector and the thermistor connector to make sure they are seated properly. If OK you probably need to replace the fuser.
Hope this helps.
Sep 03, 2009 | OKI C5100n Laser Printer
Oki c5200 fatal error 121
We had a similar problem with an Oki C7300. It was reading "Fatal Error 121" on the display.
We fixed it by simply unplugging the printer from a surge strip and plugging it into the wall directly. After that, the error went away and has not come back.
Apr 16, 2009 | OKI C5200n Laser Printer
Fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Mar 15, 2009 | OKI C5100n Laser Printer
Oki C5800 constant 172 fatal error
This error code means that the fuser temperature is low. You need to replace either the fuser or the thermistor inside the fuser.
Apr 15, 2008 | OKI C5100n Laser Printer
OKI C5500 Fatal Error 177
From OKI error log:
Lower heater temp state - Low
backup roller thermistor indicates low temp
seek service if turning off/on printer does not solve problem
Apr 15, 2008 | OKI C5500n Printer
Service Call 020 Fatal Error
Error 020 is a ROM dimm error, could be as simple as reseating/replacing Rom Dimm or a expensive main PCB, you need to get hold of a oki dealer, contact oki to find closest OKI repair agent.
www.oki.com
Jan 08, 2008 | OKI C9300 Led Printer
Service Call: 173: Fatal Error
That is a fuser erron code. Abnormal temperature. You will need to replace the fuser. Sometimes I have sen a buildup of toner on the thermistor. If you can get to it. You can try to clean the toner off. Be careful. Very hot.
Aug 10, 2007 | OKI C5150n Led Printer
Error number 172
the problem is on the fuser unit, ther thermistor on it is damaged.
Jun 02, 2006 | OKI C9300 Led Printer
OKI C5300n Led Printer Logo
1,624 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
