Question about Lexmark X5150 All-In-One InkJet Printer
Erorr 0502 - Lexmark X5150 All-In-One InkJet Printer
    Genius:
  • 2,035 Answers
The encoder strip may have gone out of range of the sensor, or it might be dirty .
Resolution
You need to check the encoder strip on the printer. This is a clear strip running the length of the printer, above or behind the cartridge carrier.
Encoder strip is a transparent strip which is behind the cartridge carrier ,This strip is very delicate handle with care please do not apply to much stress as this may break the strip and make ur printer useless
Check the encoder strip
Switch off the printer using the power button.
Disconnect the power cable from the back of the X5100
Leave the power cable disconnected for 30 seconds.
Slide the cartridge carrier to the middle of the printer by taking the top part of the belt and moving it gently to the right.
Take out both cartridges.
Place an index finger on the encoder strip on either side of the cartridge carrier.
The red arrow points to the encoder strip. Click here for an enlarged view.
On the back of the cartridge carrier, there is a small slot that the encoder strip fits into. Slightly push the encoder strip down and then back up to get it into the slot.
Lightly press the strip first to the rear and then forward, if necessary.
Clean the encoder strip with a dry tissue. Also clean the contacts of the printer.
Perform the hardware test first without cartridges and then with both cartridges.
Using the operator panel on the printer:
Press the Option button 10 times until Cartridges appears on the LED display.
Press the + button four times or until Self test appears on the LED Display.
Press Select. The printer should print a sheet of paper with one black bar and one grey bar.
If the printer fails to print, remove both cartridges and try the test again. It will feed the paper through and print a blank page.
If the test works with no cartridges in the printer, run it again with one cartridge at a time installed.
Make a standalone copy.
If the copy is satisfactory, repeat the test once to confirm that the error is gone.
Posted on Mar 09, 2008
My Lexmark X6170 won't print or partially prints e-mail. Also it won't copy in black but will copy in color? When this happens I get the 0502 error message. Any idea as to what is wrong and how to...
The 0502 error code indicates either a faulty cartridge is detected or the encoder strip (transparent strip) is dislodged from its position. Refer to this article in the Lexmark website on Error 0502 on the Lexmark X6150/X6170 Printer LCD Display to determine and resolve the problem. Thanks.
Feb 16, 2011 | Lexmark X6170 All-In-One InkJet Printer
Only prints to four lines of page. error 0502 comes up on screen. thanks
The 0502 error indicates either a problem with the encoder strip or a faulty black/color cartridge. Refer to this article from the Lexmark website on Error 0502 on the Lexmark X6150/X6170 Printer LCD Display to determine the cause of the problem and resolve the issue. If error continues even after following the steps, please contact Lexmark technical support for additional assistance. Thanks.
Jan 07, 2011 | Lexmark X6150 All-In-One InkJet Printer
Printer error 0502
The 0502 error code could be caused by an unseated encoder strip or a faulty cartridge. Please refer to this article Error 0502 on the Lexmark X5130/X5150/X5190 Pro LCD Display for the troubleshooting steps. Let me know if you need further assistance. You can also contact Lexmark technical support for additional assistance. Thanks.
Nov 11, 2010 | Lexmark X5150 All-In-One InkJet Printer
Hardware error 0502?
Error 0502 can either be caused by a faulty cartridge or the encoder strip. Here's an article on Error 0502 on the Lexmark X6150/X6170 Printer LCD Display. Just click on this link: http://bit.ly/b6uHJp. This should guide you on what to do when having this error. If error continues after following all the steps, don't hesitate to contact Lexmark technical support to further investigate the problem. Thank you for choosing Lexmark.
Aug 31, 2010 | Lexmark X6170 All-In-One InkJet Printer
Printer displays hardware error 0502 wont print " HELP "
The 0502 error can have any of four possible causes:
- A faulty black/photo cartridge
- A faulty color photo cartridge
- A dirty encoder strip
- The encoder strip being out of position
.... most of the time, it's the encoder strip that is giving the problem..
goto
http://support.lexmark.com/index?userlocale=EN_US&locale=EN&page=content&segment=SUPPORT&productCode=LEXMARK_X5150&id=HO2707
May 24, 2010 | Lexmark X5150 All-In-One InkJet Printer
Getting hardware error 0502
Hardware Error: 0502. On the multi function machine seems to be a coating on the metal rod that the cartridges travel on. Just wipe this rod with a kleenex and the problem seems to go away. Somehow it presents a drag on the cartridges and causes an error.
send you the link where you can figured out
http://blog.forret.com/2006/02/lexmark-printers-with-hardware-error-0502/
Thank you for using FixYa!
Do have a nice day and please remember to rate this solution.
Best regards,
sourav
Jan 05, 2010 | Lexmark X6170 All-In-One InkJet Printer
Lexmark X160 is not printing at all or receiving Faxes. The error that keeps coming up is Hardware Error 0502. Please Advise.
ok sir pls see the link this is the helpfull for the error 0502 in lexmark x160 all in one inkjet printer...ok
Apr 07, 2009 | Lexmark X6170 All-In-One InkJet Printer
Error 0502
Please click on this link:
then type in the printer model in the selection X6170 and then choose Lexmark X6170 and support page will open then you need Error type 0502 and you will get it trouble shooting steps...
http://support.lexmark.com/perl/support/support.cgi
Good luck...
Aug 12, 2008 | Lexmark X6170 All-In-One InkJet Printer
Error 0502
I did as suggested by another poster, clean the area of travel(ribbon,travel bar, etc) with a clean damp cloth and now it seems the problem has corrected it self
so far anyways ........
Dec 10, 2007 | Dell A940 All-In-One InkJet Printer
Lexmark X5150 All-In-One InkJet Printer Logo
114 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
