Question about D-Link DI-604 4-Port Cable/DSL Router (DI-604) Broadband (di-604 (dont quote)) Bridge
I have a problem with the router
I connect the DSL cable in the WAN port and i run the wizard but every time i try to setup the connection to automatically detect the ISP it requires the administrator password, i keep it blank as they tell me after i press next or apply it says unauthorized ,,, plzzzz help.
    New Friend:
  • 50 Answers
The PASSWORD is ADMIN
Aloha
Bob
Posted on Mar 31, 2008
Bought a d514-4 port,router @ a yard sale with no CD
There's no need for any CD-ROM.
Use an Ethernet cable to connect your cable-modem (or DSL-modem) to the WAN port on the router.
Use another Ethernet cable to connect your computer to one of the 4 'LAN' ports on the router.
Restart your computer.
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
Look for output like: Default Gateway .... 123.456.1.1
Start Internet Explorer
Type http://123.456.1.1
Press Enter
Login to the router's web-site (try 'admin' & "blank"; try 'admin' & 'admin'; try "blank" & 'admin')
Run the router's "Wireless Networking Setup Wizard" to configure the wireless adapter.
Done.
Jun 15, 2011 | D-Link DI 514 Wireless Router (DI-514)
Error 103
This may or may not be of help, but this is easy enough to try....
Power off computer, cable modem, and router.
Connect router to cable modem via WAN port, PC to router via LAN port
Power up cable mode first, wait until for connection light
Power up the router, wait about a minute
Power up the PC
I have Cablevision and have had an issue when you are going to connect a different device directly to the cable modem (eg router instead of PC), you need to reset the cable modem first or it will not work.
The following link shows you how to log directly into the router and run the setup Wizard from the router.
http://www.trendnet.com/kb/kbp_viewquestion.asp?ToDo=view&questId=1442&catId=524
Apr 09, 2011 | Trendware TRENDnet TEW-432BRP Cable/DSL...
I cannot connect my Belkin 54g to the internet at all. I followed the wizard and got the information from my ISP - user name and password. The wireless light works, the port shows that it working but the...
ghost2233_6.jpg Did you connect the lan cable to the right port ????
1. Shut down any programs that are running on your computer at
this time.
2. Make sure you have the following items at the computer that is now
directly connected to the cable or DSL modem. DO NOT CONNECT THE
ROUTER AT THIS TIME.
• The Easy Install Wizard CD-ROM
• The Router
• The Router power supply
• Category 5 networking cable
• This Quick Installation Guide
3. Turn off any firewall or Internet connection sharing software on
your computer.
4. Insert the Easy Install Wizard software CD into your CD-ROM drive.
The Easy Install Wizard screen will automatically appear on your
screen within 15 seconds. If it does not, select your CD-ROM drive
from "My Computer" and double-click on the file named "Setup" on
the CD-ROM.
5. Turn on your cable or DSL modem by reconnecting the power supply to The Wizard will take you through the completion of the process.
the modem.
6. Before plugging the power cord into the Router, plug the cord into the
wall, then plug the cord into the Router's power jack.
7. Verify that your modem is connected to the Router by checking the
lights on the front of the Router. The green light labeled "WAN" should
be ON if your modem is connected correctly to the Router. If it is not,
recheck your connections.
8. Verify that your computer is connected properly to the Router by
checking the lights labeled "LAN 1,2,3,4". The light which corresponds
to the numbered port that you connected your computer to should
to the numbered port that you connected your computer to should be
ON if your computer is connected properly.
Good luck
Mar 12, 2011 | Gateway Belkin 54g Wireless DSL/Cable...
It was working fine until ive reset my linksys wrt54g, and i did my setup again, but i dont get any internet connection, my linksys is using a cable to my pc. please help
When you resetted your linksys router, chances are, the setup for WAN connection was lost. You can try these steps:
1. Connect the internet directly to your pc. If your pc was able to browse the internet, move on to the next step. If not, you'll have to contact your ISP for the settings of your internet connectivity.
2. Connect back the internet to the WAN port of the router, and connect your pc to the router's LAN port.
3. Open the router's page in a browser (the address usually is 192.168.1.1, username is admin and password is admin)
4. If your router has a setup wizard, run the setup wizard, because it usually clones your pc's mac address.
Hope this helps.
Mar 06, 2011 | Linksys Wireless-G WRT54G Router
Hi! im having a problem on connecting via wi-fi using this router, my iphone3gs is connecting but theres no internet connection. please help me...
The main problem is with the Internet port connection on this router.
Make sure that the internet port is connected to your DSL modem, or Cable modem. The 3rd light from the left on the front panel is the WAN (Internet) light. It should be solid green or blinking.
You should also be able to connect into the router using a web browser.
http://192.168.0.1
enter the username and password.
If it has never been configured before: username (admin) / password (leave it blank)
Try running the setup wizard in the web browser.
Dec 10, 2010 | D-Link DIR-300 Wireless Router
I bought belkin g wireless modem ruter but they didn't give me CD . How can i install this and how can i use my wireless ruter please. Thank you.
Power-off your cable-modem (or DSL-modem).
Use an Ethernet cable to connect from the modem to the WAN port on your router.
Use another Ethernet cable to connect from one LAN port on your router to the network-port on your computer (desktop/laptop).
Turn the modem on.
Turn the router on.
Turn the computer on.
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
Default Gateway . . . . . . . . . : 1234.678.0.1
Type http://1234.678.0.1
to access the web-server "inside" the router.
Run the Network Setup Wizard.
Run the Wireless Networking Setup Wizard,
to pick an SSID, an encryption-level (use 'WPA')
and to pick a network-password.
Now, you can disconnect the Ethernet cable from the computer, and try using the wireless-adapter inside your computer.
Sep 20, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How to set up wbr-3406 tx router with dsl modem
Take an Ethernet cable, and connect the Ethernet port on the DSL modem to the WAN port on the router.
Take another Ethernet cable, and connect one of the LAN ports on the router to the network-port on your computer.
Now, you should be able to web-surf.
Access the web-server inside the router, and run the "Wireless Network Setup Wizard", to configure your wireless networking.
Jun 24, 2010 | CP International WBR-3406TX Wireless...
How tinstall modeldir-615
Thank you for posting your question.
To setup this wireless router on your network follow these instructions:
Step 1. Plug in your D-link router to the wall outlet to power on.
Step 2. Connect the ethernet cable on your DSL or Cable modem to the WAN PORT on the D-link router
Step 3. Power on your DSL or Cable modem
Step 4. Connect an Ethernet cable from your computer to LAN Port 1 on the D-link router (if you have a wireless card on your computer, you may be able to connect to the router without using the Ethernet cable)
Step 5. Open Internet Explorer and type 192.168.0.1 then press Enter
Step 6. You should be prompted for a username and password, type admin for the username and leave the password blank, hit OK
Step 7. You will be brought to the Home Screen
Step 8. Click the Run Wizard button
Step 9. You will then input information regarding a new password, your time zone.
Step 10. After that the Wizard will try to detect what type of internet connection you have with your Service Provider
Step 11. If it cannot auto detect, you will be asked to select a type of connection
Step 12. If you have a DSL modem, you will select PPPoE, if you have a cable modem, you will select Dynamic IP Address
Step 13. If you selected PPPoE you will have to enter the username and password that your ISP has given to you for your connection.
Step 14. You will then be taken to the Wireless Lan connection screen, you can change the SSID or leave it default. Also leave the Channel at 6
Step 15. You are then brought to the Encryption Screen. To enable encryption, select Enabled
Step 16. Select your WEP encryption 64-bit or 128-bit
Step 17. Enter the Hex key (up to 10 characters)
Step 18. You setup is complete, you will be asked to retart the router through the Wizard, click restart
Be sure to rate/vot
Apr 27, 2010 | D-Link DI 514 Wireless Router (DI-514)
How do I hook up a Berklin wireless router to my comcast internet
Use an Ethernet cable to connect the port on the Comcast modem to the WAN port on the Berklin (Belkin????) router.
Use another Ethernet cable to connect one of the LAN ports on the router to the Ethernet port on your computer.
Start Internet Explorer on your computer.
Connect to the web-interface inside the router.
Run the "network setup wizard".
Run the "wireless setup wizard".
Nov 17, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Asus WL 520gu can't connect internet
1, connect your wireless router with cable to your laptop,
2. Login into your Asus-WL520gu and setup your wireless how you want it to run." do not bother with putting your username settings in there"
3. In your Asus-WL-520gu after setting up your wireless turn the DHCP off in it.
4. Now connect the cable that you have connected to your laptop to your router instead of your laptop.
""You should now be able to connect to the wireless with your settings. and connect anything ells you want to the other 4 ports on the back of you wireless router"" note: do not connect anything to the WAN port as it is used for DSL modems; and not Routers with ADSL modem.
when connecting a router to a router - the one that is connecting you to the internet needs DHCP turned on because it is the one that will be giving you IPs and Gateway settings - the other router such as wireless router after setting it up needs its DHCP turned off - other wise you will have 2 routers trying to do the same thing with ip's and gateways. And you should never connect a modem router to the WAN port as it is a modem router and NOT just a DSL-modem. The WAN port is intended for DSL-modems only. Not only consumers but also many technicians make that mistake
Aug 23, 2009 | ASUS WIRELESS ROUTER |WL-520G - RT...
Open Questions:
See all D-Link DI-604 4-Port Cable/DSL Router (DI-604) Questions
D-Link DI-604 4-Port Cable/DSL Router (DI-604) Broadband (di-604 (dont quote)) Bridge Logo
143 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
