Question about Thane Q-BBQ Grill
Burners not working
I have a 3 yr old - 2 burner Q Grill. The push-button igniters spark and gas is on (tried 2 new canisters) but burners will not ignite. I can push the valve located above the canister with my finger and hear gas and burners will ingnite, but when release my finger the burners go out.
  • dstearno Apr 02, 2008
    Thanks - I think you're right on...I checked the valve mount (2 screws) and they are very tight and the valve assembly really doesn't move. However, the canister screws on sort of "warbly" - the threads are not stripped on the canister or the valve piece. It does screw on tight, though. I even tried to tighten the nut inside the valve it was already secure. Other thoughts? It is a few years old, has been stored well, clean, no rust and has been used very little. I hate to scrap it...
  • 552 Answers
The quickest way to solve this problem would be to visit the Thane website.
Posted on Apr 02, 2008
    Genius:
  • 3,422 Answers
HI,
First of all let me say that if your grill is getting on in years, has been experiencing increasing problems for a while or shows signs of rust, wear or age in its internal parts (burners, etc.) then it is probably in need of repair. Gas grills generally don't last for ever and many lower quality models only last a few years. However, if your grill is relatively new and in good shape and if it has suddenly started acting up, then you can probably get it back to good working order quickly and easily.
Safety First: Always make sure that you have turned off your tank valve and disconnected your grill from its fuel source before you do any work on your grill. If you have had your grill on, make sure it has cooled down. If you have had the gas on, give the grill five minutes for the gas to dissipate.
1. Low flame, low temperature, yellow flame: This has become the biggest problem with many grills these days and it's almost always because of the regulator (the funny UFO shaped thing on the gas hose). Regulators seem to be stickier these days and when they stick you don't get enough gas to generate a good grilling temperature. To get your regulator unstuck you need to release the pressure on it. Follow these steps exactly:
  1. Turn off the gas at the propane tank
  2. Disconnect the gas line from the tank
  3. Open the grill lid
  4. Turn all control valves to high
  5. Wait for about a minute
  6. Turn all control valves to off
  7. Reconnect the gas line to the tank
  8. SLOWLY turn on the gas at the tank
  9. Light the grill normally
  10. Your grill should now heat normally
To keep the regulator from sticking again make sure that you turn off the control valves first, then turn off the tank valve. Always open your tank valve slowly.
If this doesn't work give it a second try. If you still have low flame then you probably have a faulty regulator that will need to be replaced.
2. Uneven heating/hot spots: Most grills have uneven heating. Of course this doesn't mean that one part gets volcanic hot while other areas are cool enough to park your drink. The number one cause of uneven heating is a blocked burner. Burners have a series of holes or ports along the sides that gas flows through to produce flame. Frequently drippings run over the burner and clog parts of it. Typically you can use a wire brush to remove these deposits from the burner and you should be in good shape. Sometimes the burners become so clogged that you will have to remove the burner from the grill to clean it. Some grills you can simply lift the burners out, others are bolted in and difficult to remove. If you can easily get your burner out remove it from the grill and clean it thoroughly with a stiff wire brush. Make sure you get all the gunk out from the inside of the burner. Do not use oven cleaner or harsh detergents on your burners; some can be very delicate and prone to rusting.
3. It just won't light: Some grills have push button (pizo electric) igniters and others are battery powered. If you have the battery type, try replacing the batteries (hey, it's worth a try). What you need to find out is if you are getting a spark in the igniter unit. The igniter is going to be near one (or several) of the burner(s). Some grills have independent ignition, some have a single igniter. If you have independent ignition and none of the burners will light then you have a faulty button or the wiring is bad. You will probably have to get these parts replaced. If you have independent ignition and one of the burners will not light or you have a single igniter and none of them will light you probably have something clogging that igniter. Pull off the cooking grates and barrier to get down to the burner. Locate the affected igniter and push the button. You should see a spark. If the igniter is clogged, clean it out and test it again. If there is nothing clogging the igniter then you need to inspect the wiring. Faulty wiring or switches will need to be replaced.
Goodluck,
Please don't forget to rate the solution
  • 871 Answers
Hi there
the way you described it only indicates that something there is loose, its the valve that is loose . what you can do is manually check what is its operation, and only you can do it since you have already checked and pinpointed that whenever you remove your finger, the fire goes out right?
that only means that the canister is not really positioned correctly there so that it can meet the valve.
it may be 2 things.
1) loose valve
2)loose canister holder.
unfortunately, when i checked there site, its already discontinued... too bad. its such a great product though.
please feel free to post what happens ok.
  • earl norman llanera
    earl norman llanera Apr 02, 2008
    yup
    ok. nicely done.
    it is indeed a loss if youre going to scrap that. however, if there is nothing to fix there,
    i can just advice you to improvise. like putting something there to hold the canister or valve. becuase its just loose. how about sticking something there just to make it firm...
    what do you think?
  • 796 Answers
Hello
Posted on Mar 08, 2008
  • isaac johny
    isaac johny Mar 08, 2008
    there may be something blocking the way of the gas.....
    try it again cleaning the wents...
TEC Sterling II, Pilot light not lighting ceramic burners. Got new ignitor. It does create a spark but it doesn't jump to the pilot light or to the burners.
The gas may not be reaching the burners. Try match lighting a burner to see if it is. If it isn't do the following.
To solve this problem, first be sure you have adequate gas in the tank. If that checks out OK, do the following:
1. Turn the gas tank valve OFF and disconnect the hose from the tank. If you're using as 1 Lb
Canister tank. Turn the valve off and remove the canister.
2. Wait 5 minutes and reconnect the hose to the tank. Reinsert the canister.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. Or you will have to replace the Canister Assembly. For that you'll have to go to Tec Grills. If you replace it, turn the tank valve ON Very, Very Slowly.
Hope this helped you.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling.
Jul 08, 2011 | Tec Sterling II Grill
I have a kenmore gas grill that has the side burner. Up until recently, it has been working great. However, now the main grill won't light when pressing the ignition button but the side burner lights...
More than likely, the electrode spark ignitors on your main burners need to be cleaned. They will get covered with grease over time. Also check the wiring from the ignitor module to each spark ignitor being sure that all wiring is firmly in place. To clean the electrode(s) ... a cotton ball dipped in alcohol will work fine.
Hope this helped you solve the problem and Happy Grilling!
Apr 09, 2011 | Kenmore 700 sq. in. Cooking Area Gas Grill...
The striker button won't light the grill but a match will. It is an older Genesis Silver approximately five years old.
If your piezzo ignitor is still sparking, but not lighting the burners, then you may have one of the following problems. 1) If you have a standard push button piezzo igniter or a rotary style igniter, check for spark. Can you hear or see the spark? It's hard to see the spark in bright daylight. It's easier to view the spark at dusk or dawn. It should spark an "arc" at the burner. If not, adjust it if necessary. 2) The igniter wire may have a short, causing the spark to arc somewhere else along the wire and not at the burner. Replace igniter wire. 3) It's also possible the igniter tip where it sparks has a cracked or broken porcelain portion of the igniter, causing the spark to not arc at the tip where it's supposed to. Replace the igniter piece. 4) Your burner may be clogged or rusted at the point where the ignitor sparks to light it. Clean the burner. 5) If your push button ignitor is not sparking at all, it may be stuck inside from being out in the weather. While pushing it, spray it with WD-40 to unstick it.
Hope this helps. Douglas
Aug 05, 2010 | Weber Genesis Silver C Grill
Have a large mobile propane grill with burner problems
Ok, here is a check list for your most common gas grill lighting problems:
1) Check your tank. Is it empty or nearly empty? The tare weight (T.W.) of your cylinder is stamped on the collar. This is the weight of your empty cylinder, usually around 18 lbs. Weigh it on your bathroom scale2_bing.gif. Propane weighs 4.25 lbs/gal. If it weighs around 20 lbs or less - Refill it. If not, go to #2.
2) Make sure you didn't turn the gas tank valve on too fast. Some gas hoses have a built-in excess flow valve that stops the flow of gas to a trickle if opened too fast. Close the tank valve and let sit for a few minutes. Or just disconnect it and reconnect it. Turn the tank valve very slowly and then try lighting it again. If it doesn't help, go to #3.
3) Is the igniter sparking? Some are battery2_bing.gif powered-check the battery or replace it. If you have a standard push button piezzo igniter or a rotary style2_bing.gif igniter, check for spark. Can you hear or see the spark? It's hard to see the spark in bright daylight. It's easier to view the spark at dusk or dawn. It should spark an "arc" at the burner. If not, adjust it if necessary. The igniter wire may have a short, causing the spark to arc somewhere else along the wire and not at the burner. Replace igniter wire. It's also possible the igniter tip where it sparks has a cracked or broken porcelain portion of the igniter, causing the spark to not arc at the tip where it's supposed to. Replace the igniter piece. If not, go to #4.
4) You may have a rusted, clogged or damaged burner or venturi tube. With a flashlight, check for spider webs, wasp nests or dirt (mud) dauber nests in the opening of the venturi tube where it connects at each gas valve orifice. Clean it out manually or blow it out with air compressor. Make sure the air adjustment opening (on the end of the burner's venturi tube) has not been changed. If it's closed too much, it will be difficult to light and cause lazy yellow flames. If it's not clogged, the burner may just be old and rusted and the burner holes are not allowing very much gas through anymore. It's also possible the burner has rusted so bad, the burner holes have been enlarged, it is falling apart or has cracks along the burner seams. If so, replace the burner(s) immediately. It is unsafe to use. Your local propane co can usually order the parts you need and some will even do the work, if you are uncomfortable doing it yourself. Bring with you the Make, Model and Serial number of the grill, so they can order the correct parts for your specific grill. Also specify whether it's natural gas2_bing.gif or propane.
5) If none of these resolve the issues you are having, it is also possible you have a faulty or defective regulator, which may mean replacement. If the pressure still seems too low and none of the above has helped, and you have a silver/gray regulator; many have an adjustment screw on the top center of the diaphragm. Remove the outer cap and turn the inside screw clockwise in 1/4 turns to increase the pressure until the desired flame size is accomplished. Flames should be as blue as possible, but will burn orange if there is food or drippings on it. Yellow flames are not good, and will soot up everything and not cook as hot as blue flames do. Yellow flames could mean you do not have the right air shutter adjustment, clogged burners, or possibly defective burners, as mentioned above in #4.
6) Also make sure you have the hose connection tightened snugly to the propane tank valve to ensure the inner valve seat is fully depressed allowing gas to exit fully without any restriction. The black plastic female fitting should be hand tightened only. Older versions that use a left-hand male brass POL valve, requires a 7/8 open end wrench or adjustable wrench to tighten.
Hope this helps! Good luck in your trouble shooting! Douglas
May 19, 2010 | Big Green Egg Extra Large - XLHD...
Burners will not ignite and it seems they are not getting any gas
Here, try my trouble shooting checklist and see if one of them works for the most common gas grill lighting problems:
May 17, 2010 | Brinkmann 810-2300-B Grill
Only the infared burner does not ignite.
If you have a push button sparker the wire may be off or the sparker may be worn. You can check for spark when it is dark out. If you dont think you have spark then try to light the burner the "old school" way just hold a match or flame to the white area and then turn and hold the gas knob. If you can light it the old school way then its your spark. I would remove the sparker (unscrew the plastic nut on it remove the wire if its stll on) and test it on your hand. If the sparker works you will know because you will get a shock from the end of it. If you dont get a shock then you need to buy a new one. I hope this helps
Feb 02, 2009 | Dacor OB36 Gas Grill
Viking Gas Burner issue?
is this a sealed burner unit? if so the burner base (the heavy brass part under the burner cap) has to be sitting just right. you will notice that it has holes around the the sides make sure that where your ignitor sparks to it that it aligns with the lowest hole on the burner base. if you have a great flame all around the burner after checking what i mentioned i would replace the spark module. if it continues to drive you crazy with the noise - just unplug it. the burners will continue working fine without power.
Dec 23, 2008 | Viking 42 in. Professional Series...
I have a char-broil 3 burner grill that is about 6 years old. It has 3 circular burners. The amount of gas now getting to the burners is equivalent to low even when the dials are on high. Do I have a...
most likely burner problem try removing burners (they generally just lift out or held by 1 or 2 screws) clean the sides of the burners with wire brush most likely then orifices on burners are clogged hope that works for you
Aug 23, 2008 | Char-Broil CharBroil 4637318 Grill
Ducane 3400042 lighting problems
Good answer... but remember (if you have the regular burners on... The Rotisserie will not light.) 1. Cut all knobs off... Then push and hold in Rotisserie button as you turn to high.
2. Press ignition button, until you hear rotisserie ignite. 3. Keep holding in the rotisserie button until the thermostat realizes the gas is on and burning. (IT must get hot enough to keep gas flowing.) Hope that helps, Dave
Apr 08, 2008 | Ducane 30400040 Stainless Steel Grill
Ignite prob
You've got two different things going on.  First - the type of igniter used on your model does wear.  I have had mine for over 10 years and have gone through 3 such igniters - and I grill nearly 3 times per week over the 25 week "grilling" season where I live. Spring for the $12 part and just replace it. The other issue sounds like a clogged cross-over system.  I would remove the burners, including the cross-over bar on the far left side that connects them.  Clean the exterior with a stiff steel/brass brush and the inside with a bottle brush.  Make sure all the holes are clear to allow gas to flow easily - use a wooden tooth-pick to do this to make sure you don't change the size of the holes! Put that baby back together and I think you'll find you'll be good as new!
These grills are great.  Now, if Weber could only fix the uneven heat problem between the left and right side I'd REALLY be happy!  (I wish they would even just admit there IS a problem!)
Good luck and happy grilling.
Mar 03, 2008 | Weber Genesis Silver B Grill
Thane Q-BBQ Grill Logo
511 people viewed this question
Top Thane Grilling Experts
Paul Carew
Hjalmer Lamminen
Hjalmer Lamminen
sureshd2008
Are you a Thane Grilling Expert? Answer questions, earn points and help others
