I was wondering if the audio jack that came with my 2035wm could be plugged into the digital audio output jack of my new computer and therefore have digital audio playing through the Viewsonic monitor's speakers.
  • 492 Answers
It cannot be. Digital audio is different from the analog audio that the speakers use.
Posted on Mar 07, 2008
SHG7980 Windows 8 drivers not available
If there is a driver needed ?
Click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question / exclamation? ! mark or a red X Right click to reinstall drivers
If your computer came with a motherboard disk the drivers could be on it
or you might download slimdrivers.
Rather doing a driver hunt
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
Windows XP/Vista/7/8
Note: it will find all of your outdated drivers
This is a free driver solutions
which will automatically search for and find the correct driver
You will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point.
Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
It might take some time being free
The headphone jack on the computer connects to the sound card, a hardware device that controls audio input and output on the PC.
The card contains a digital-to-analog converter that converts analog audio into digital signals and visa-versa.
The performance of the headphone jack, therefore, depends on how well the sound card functions; if the card doesn't work, then the headphones connected to the PC won't output sound.
Reconfiguring the audio settings will often fix problems with audio output on the headphone jack, but if the former fails to resolve the issue, replacing the sound card in its entirety is sometimes the only means of repair.
Click "Start." Enter "sound" into the search box. Select "Sound" from beneath Control Panel.
Double-click "Headphones."
If no "Headphones" option is available, double-click "Speakers."
Click "Properties" on the General tab.
Check the Device Status field for errors. Look up the message on Microsoft Support for more assistance, if applicable.
Close the window if the Device Status field reads "This Device Is Working Properly." Go to the "Levels" tab.
Click the speaker button to unmute the volume if the icon contains a red circle-backslash symbol. Drag the top slider to the right to increase the headphone volume.
Go to the "Enhancements" tab.
Check "Disable all Sound Effects." Go to Applications, and then clear "Allow Applications to Take Exclusive Control of This Device."
Click "OK" to close Headphones Properties or Speakers Properties.
Test the audio.
If the headphones fail to output sound, unplug the headphones from the computer.
Reconnect the headphones to the PC.
Headphone jacks are color-coded lime green on most PCs.
Look for the headphones symbol if the jacks are not color-coded.
Plug the headphones into the line-out port on the back of the computer if the headphone jack on the front of the PC fails to work, or visa-versa.
Test the headphones.
If headphones still won't emit sound, the sound card most likely requires replacement.
Replacing the Sound Card
Shut down the computer. Remove the power cord from the back of the PC.
Disconnect the keyboard, mouse, monitor and all other peripheral devices.
Loosen the screws found on the back of the case, then slide the cover panel off of the case. Touch the chassis to protect the hardware from electrostatic discharge, or ESD.
Set the computer on its side.
Locate the sound card found on the opposite of the audio jacks and loosen the screw that secures the card to the computer.
If no expansion card is located opposite the jacks, the computer uses an integrated sound card which can't be removed.
Remove the new audio card from its protective packaging.
Line up the card with an available expansion slot on the motherboard, then push the card down into the slot to install the new audio jacks.
Screw the card to the computer case.
Reassemble the computer.
Turn on the PC. Boot in to Windows and insert the CD that came with the new expansion card. Follow the onscreen instructions to install the sound card software to the computer.
Plug the headphones into the new line-out jack.
Jul 10, 2013 | Intel Computers & Internet
Headphone jack does not work
The headphone jack on the computer connects to the sound card, a hardware device that controls audio input and output on the PC. The card contains a digital-to-analog converter that converts analog audio into digital signals and visa-versa. The performance of the headphone jack, therefore, depends on how well the sound card functions; if the card doesn't work, then the headphones connected to the PC won't output sound. Reconfiguring the audio settings will often fix problems with audio output on the headphone jack, but if the former fails to resolve the issue, replacing the sound card in its entirety is sometimes the only means of repair.
Click "Start." Enter "sound" into the search box. Select "Sound" from beneath Control Panel. Double-click "Headphones." If no "Headphones" option is available, double-click "Speakers." Click "Properties" on the General tab. Check the Device Status field for errors. Look up the message on Microsoft Support for more assistance, if applicable. Close the window if the Device Status field reads "This Device Is Working Properly." Go to the "Levels" tab. Click the speaker button to unmute the volume if the icon contains a red circle-backslash symbol. Drag the top slider to the right to increase the headphone volume. Go to the "Enhancements" tab. Check "Disable all Sound Effects." Go to Applications, and then clear "Allow Applications to Take Exclusive Control of This Device." Click "OK" to close Headphones Properties or Speakers Properties. Test the audio. If the headphones fail to output sound, unplug the headphones from the computer. Reconnect the headphones to the PC. Headphone jacks are color-coded lime green on most PCs. Look for the headphones symbol if the jacks are not color-coded. Plug the headphones into the line-out port on the back of the computer if the headphone jack on the front of the PC fails to work, or visa-versa. Test the headphones. If headphones still won't emit sound, the sound card most likely requires replacement. b> Replacing the Sound Card b> Shut down the computer. Remove the power cord from the back of the PC. Disconnect the keyboard, mouse, monitor and all other peripheral devices. Loosen the screws found on the back of the case, then slide the cover panel off of the case. Touch the chassis to protect the hardware from electrostatic discharge, or ESD. Set the computer on its side. Locate the sound card found on the opposite of the audio jacks and loosen the screw that secures the card to the computer. If no expansion card is located opposite the jacks, the computer uses an integrated sound card which can't be removed. Remove the new audio card from its protective packaging. Line up the card with an available expansion slot on the motherboard, then push the card down into the slot to install the new audio jacks. Screw the card to the computer case. Reassemble the computer. Turn on the PC. Boot in to Windows and insert the CD that came with the new expansion card. Follow the onscreen instructions to install the sound card software to the computer. Plug the headphones into the new line-out jack. Hope this helps.
Jan 21, 2013 | Acer Aspire Computers & Internet
Can you get dual channel audio (four Chan) out of a toshiba l300 laptop?
Yes you can just grab a cable (both ends) male jack,like the male jack of the mic jack and plug one end to the PC and the other to your audio system
Apr 30, 2012 | Computers & Internet
I am not getting anysound from the speakers
This monitor has integrated speakers so therefor needs an audio cable to plug in from your computers Audio Output Socket (usually green color) into the monitors audio input jack. It needs a stero type plug for right and left sound. Have a great day.
Dec 05, 2010 | Daewoo F227B Monitor
Just bought X-140 speakers. Plugged them in and connected them to the audio output jack on the back of my HP desktop model SR5710Y. Booted up the computer and logged on to Pandora. Got sound from the...
Most HPs have a utility in the Conrol panel for speaker jack output assignment, verify you have them plugged into the green jack not blue/pink, verify that the digital output only is not selected in the speaker control panel. you say built in speakers , are these in the monitor, some HPS have two outputs that can be controlled individually, again this is in the control panel audio properties utility, sometimes there is a audio icon by the clock (bottom right) that will also adjust these settings, but the "control panel" way is more reliable.
Aug 27, 2010 | Audio Players & Recorders
Can i hook up computer and use tv as monitor
I believe your TV only has component video and S video inputs Therefore it depends on what the video outputs are on your computer. If you have S video out on your computer's graphics card then you can plug it right in. Sound must be run separately from your audio out jack to the TV. If your computer has an analog RCV video output then that would work too.
Dec 04, 2009 | Hitachi 46F500 46" Rear Projection...
Do I need speakers with my syncmaster 2233 for sound, if so WHERE do I plug them in on the computer?
Yes you do! Simple speakers with one jack plug into the green jack plug connector either on the front or at the rear of your computer.
Nov 04, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Connecting BA735 digital 3.5mm plug with S/PDIF coax jack
The male mono plug (from the left small speaker) should be connected into the right speaker (small speaker with controls) . After plugging the multi pin cable from the control speaker to the sub-woofer you need to plug in a signal source from your computer (or any other digital signal) into the sub-woofer. This digital input looks like an ordinary RCA plug but carries many channels of audio. That connects to the enabled digital output of your computer. Some computers output digital through a 3.5mm jack others look just like an RCA phono jack. If you are lucky some BA735 sub-woofers have a second input that is a standard 3.5mm stereo jack and it will take analog audio from computer, DVD, MP3 player or the like. I have three sets of these speakers that I love because of their big volume considering such a small size.
Mar 29, 2009 | Boston Acoustics BA735 Computer Speakers
Can I connect a mini plug DIGITAL audio source into these?
Hello bobbobbob, These speakers would work great. First question is: Do you already own these speakers, or would you be buying them? If you already own them, then yes, use them, if not, a more economical solution would be the Bose Companion 2 speakers here: http://www.bose.com/controller?event=VIEW_PRODUCT_PAGE_EVENT&product=companion2_multimedia_index These are about half the price, and have exceptional clarity for someone like your aunt. They also will allow her flat panel TV to plug and play very easily. Please let us know if you need any additional information. Best regards and kudos for helping your aunt out! nightdiver
Sep 04, 2006 | Edirol MA-20D Computer Speakers
50 people viewed this question
 Grubhead
Grubhead
