Question about Epson Stylus Photo R220 InkJet Printer
Printing Problems with Photos
When printing photos green blemishes all over photos.
How do I fix it?
Your help would be appreciated.
  • scarface54 Mar 20, 2008
    THANKS
    ITS OK NOW
    KIND REGARDS
    ALAN SEAL
  • reedler_07 Sep 07, 2008
    When printing photos green blemishes all over photos. But all collors have no gaps on the nozzle check. I also tried several ink charging and head cleaning even powerful celaning using the SSC utility, and I also kept the ink solution pumps itself from an open syringe to the head pins and caps but that didn't help on my problem.
    Is there any other option?
    Problem Solver:
  • 12 Answers
You can try this one just to isolate if it is an issue with the software or with the hardware itself
it is just for windows users only
1) Make sure the printer is turned on but not printing.
NOTE: You cannot clean the print head if the any of the cartridges are expended. Replace the appropriate ink cartridge before proceeding.
2) Load letter size paper.
3) Click on START.
For Windows 95/98/ME: Click SETTINGS, PRINTERS, then RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PROPERTIES from the drop-down menu. Proceed to Step 4.
For Windows 2000: Click SETTINGS, PRINTERS, then RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows XP: Click CONTROL PANEL, PRINTERS AND FAXES. RIGHT-CLICK your EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. If this icon is not showing, select VIEW INSTALLED PRINTERS. Then RIGHT-CLICK the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows Vista: Click CONTROL PANEL,HARDWARE AND SOUND then PRINTERS. Note: these steps may vary depending on how Vista is setup. RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
4) Click on the UTILITY or MAINTENANCE tab, then click on HEAD CLEANING.
5) Follow the instructions on the screen to clean the printhead. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
6) When the power light stops flashing click PRINT NOZZLE CHECK PATTERN and then click NEXT.
7) If the nozzle check pattern has no gaps in its lines, click FINISH. If the pattern has any gaps, click CLEAN to clean the printhead again.
8) If the situation continues after three cleaning cycles and nozzle checks, replace one of the affected ink cartridge(s).
9) Once the cartridge(s) has been replaced, please follow steps one through seven up to three times.
If the nozzle check still has gaps after you have run at least 3 consecutive cleaning cycles and replaced the affected ink cartridge(s) with genuine Epson inks, your printer will require service.
Posted on Mar 19, 2008
My EPSON Stylus Photo 1400 Ink Jet Printer is printing blank photos. The ink levels are fine, it's feeding photo paper fine, it's making the same noise as it does when it prints but the photos are...
Your problems states that photos are being blank when trying to print it.
Please try these tips.
  • Make sure your printer is selected in the Print window or in the Macintosh Page Setup and Print windows.
  • The print head nozzles may need cleaning.
  • Make sure your printer software settings are set for the paper size you're using.
Plus,i also wanted to know if you can print ordinary documents or print a test page.
Hope this helps.
Thanks,
FixerDelta
Sep 09, 2011 | Epson Stylus 1400 InkJet Photo Printer
Printing with a green hue
photo r300 printer is printing coulor photos ok but when i use adobe 7 i turn my pictures into black and white and then i hilight some coulor into the photos good prints but now the prints have a green hue to them ?
Oct 22, 2009 | Epson Stylus Photo R300 InkJet Printer
Color on photos suddenly has a blue - purple wash with no greens
Your yellow cartridge is probably not working as your photos suggest. Remove and reinsert the yellow cartridge. Try printing only yellow color.
Your printer has a separate head for printing; the nozzle for yellow ink might be clogged. Try running a head cleaning routine from your printer software.
Sep 15, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Problems with printing photos. Hp Psc 1410
check the configurations again, if the problem were still there, try with other cartridges.
Aug 13, 2009 | HP PSC 1410 All-In-One InkJet Printer
All printing is green
http://www.fixya.com/support/r1213373-faint_output_when_printing_from_leopard
Jul 16, 2009 | Epson Stylus C88 InkJet Photo Printer
HP C6180 won't print borderless photos
Also had ongoing problem of paper jams printing PDF files, but not when printing any other files. Solved both problems by uninstalling and reinstalling printer driver.
Feb 03, 2009 | HP Photosmart C6180 All-In-One InkJet...
R1800 printing way too green/yellow
I had a similar problem with my R800 . I got a colour profiler to fix it and he used a spyder. Made an amazing difference. Well worth the trouble especially if you are printing a lot of photos
jenni U.K.
Nov 22, 2008 | Epson Stylus Photo R300 InkJet Printer
Vista : what is ICM setting for Photo Printing
Check the HP web page. They have some colour profiles available to download I believe
Jul 04, 2008 | HP PSC 1315 All-In-One InkJet Printer
Printing problems
If your not low on ink try shaking the cartridges right before you use them.
Jun 05, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Problems printing photos.
Verify when the print box comes up that monochrome (Greyscale) is not selected.
Jan 18, 2008 | Canon i860 InkJet Photo Printer
Epson Stylus Photo R220 InkJet Printer Logo
94 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
