Hoover performa eco 1300
Will wash,,,wont drain or spin, cleared outpipe, was blocked
  • salingerak Apr 26, 2009
    My Hoover Performa Eco 1300 will wash, but does not drain or spin.
4 Suggested Answers
  • 653 Answers
SOURCE: Need to know what the programme numbers mean please!
Here is the Hoover site where you can download an instruction manual. http://service.hoover.co.uk/manuals/?Section=2 I had no idea Hoover made washers, dryers, or combo units. They only sell vacuums on this side of the pond.
Posted on Apr 21, 2009
barkencoa
  • 3463 Answers
SOURCE: Will wash but won't spin unless water syphoned off
Check to see if there is a filter located at the bottom front of washer behind plastic trim, if no filter, then remove rear panel of washer, and remove and check pump for blockage or malfunction.
Please rate my so9lution.
Thanks
Posted on Nov 01, 2009
blueextc3221
  • 15935 Answers
SOURCE: I have a Hoover Performa ECO 1300. The washing is
For low water volume - or "Trickling" effect...
1. Turn off the water supply to both hoses.
2. Remove hoses (one at a time so you don't get them confused)
3. On the washer side - look for a removeable screen inside wher you just removed the hose.
4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes.
5. Replace the inlet screens.
6. Re-fit the hose to the machine.
7. Turn on water supply valves.
8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
Hoover performa 900 model number washing machine user guide
Check out this site and see if you can find your model number of your machine.....http://www.whitegoodshelp.co.uk/washing-machine-instruction-books-and-user-manuals/
Aug 25, 2014 | Washing Machines
Hi i have a hoover washing machine hnf 6127 it functions perfectly but wont spin the drum goes round on the wash cycles but will not pick up speed on the spin i have checked the filter is not blocked
If it is not picking up speed on the spin cycle then it is the motor or the belt. check the belt first for proper tension and make sure the motor has the proper output. I think something is slipping and not transferring torque to the tub.
Mar 12, 2014 | Hoover Washing Machines
My Hoover Ultracare 1300 washing machine has just stopped before the spin - full of water. I have tried several options but can't get it to move at all from that. It will rinse and move clothes around, but...
Yes. the pump may be blocked. look at the bottom of the washing machine front and you will see a flap undoo this and take out any bitts stuck in. Caution. Make sure the washing machine is un pluged and when you unscrew that plug. all of the water will come out of the machine. Best to do it outside. If that dose not work it means the pump has blown.
Dec 15, 2009 | Hoover UltraCare HC6 130M Front Load...
Will wash but won't spin unless water syphoned off by draining through pipe into low bucket. So, the spin motor is ok, the pipe is not blocked... but the pump..... how can I get to clear out the pump?.......
Thanks
Nov 01, 2009 | Washing Machines
Apr 21, 2009 | Washing Machines
User guide for hoover performa eco 1200
http://service.hoover.co.uk/manuals/Manuals.aspx?Section=10
go to that website to get an online manual for any hoover machine. the performa eco is a WB120.
Mar 26, 2009 | Washing Machines
I am looking for the instruction manual for the hoover performa eco wb120 washer dryer as i cant seem to spin my washing which is stuck in the machine
My partner fixed this problem by taking the machine back out and found that the connection to the water outlet pipe under the sink had a buung left in so after it was removed my machine drained
Mar 22, 2009 | Hoover Washing Machines
Our hoover ultra care 1300 large load washing machine spin fault
The most common cause of machines stopping mid cycle is not draining. Your machine should have a filter behind the kick plate at the bottom.
If this is not the case please post back for further assistance.
Jan 21, 2009 | Hoover UltraCare HC6 130M Front Load...
Hoover washer dryer saver 1300
I have inherited a hoover saver 1300 in new flat, the dials have worn away and it goes onto drying mode after wash, how can i have it on wash and spin only - NO DRYING? Thanks
Apr 12, 2008 | Hoover H120M Front Load Washer / Dryer
Washing machine wont empty
hi there this is a common fault empty the water into a bucket and remove the water pump to check for blockages, the pump is located at the rerar lefthand side of the w/m.
also check your drain hose where it connects under your sink.
hope this helps
Dec 11, 2007 | Washing Machines
Washing Machines Logo
528 people viewed this question
Top Washing Machines Experts
