I insert the key, turn the ignition and the engine barely cranks over, sometimes pausing as if there isn't enough power. However, new battery was installed last week. I wonder if it could be a starter issue (I've had plenty of those throughout the years with this truck).
You could have a starter that draws too much amperage or a bad ground. Check your grounds at the battery cables and check that the battery is fully charged. You may have an alternator problem. If the battery is fully charged check the starting and charging systems and that will tell you your problem.
The first step is to narrow down the cause of the no-start.
Let's go over the process of starting the car, so you have a better understanding of what is going on when you turn the key:
H
Here is what happens on a properly running car:
You sit behind the wheel and insert the ignition key into the switch.
You then turn the key to the spring loaded start position. When you do that, the ignition switch engages the starter by connecting the battery to the electric starter motor which, in turn cranks the engine over. This can be easily heard and is referred to as cranking the engine over.
The next thing you will hear is the engine running, which is your signal to release the key.
At that point, the engine is running and you are ready to place the transmission selector in Drive and be on your way.
