Question about Philips 55PW9363 55" Rear Projection HDTV-Ready Television
Broke and lost
I need to find two components for the tv. One is the ciruit board that has the power, volume, channel, and menu buttons on it. The other is the remote. How do i get these two components
  • Kaiden54 Mar 11, 2008
    Please Post the link it would be very helpful and Jaime867 the model number is 55pw9363/17f. I will have to find the chassis number. Where would that be located?
  • Jaime Hernandez May 11, 2010
    What is the exact model and chassis number?
  • 2,336 Answers
Check this site as well. They seem to have the remote and probably the keyboard circuit as well.
Good Luck.
Posted on Mar 11, 2008
  • Philips Master
  • 8,617 Answers
I have a source for quite a few of those parts used. Let me know if you would like me to post the link.
Posted on Mar 07, 2008
  • Sonny Berry
    Sonny Berry Mar 11, 2008
    The remote can be purchased at replacementremotes.com just enter the model number. The keyboard circuit board can be purchased here at the following link just click on the phillips/magnavox section and you will find the key board circuit board listed. Here is the link
    http://servicemanuals.vstore.ca/
I have a Sharp TV model LC-32SB24U. I cannot access the menu screen because I lost the remote control. Is there another way I can change channels without a remote?
The Sharp LC-32SB24U has menu, input, volume up/down and channel up/down buttons on the top of the TV. When you access the Menu using the buttons on the TV, the Input button is the same as the Enter key. The volume up/down buttons map to the left and right arrows. The channel up/down buttons remain up and down. The Menu button is the closest to the power button (on the right). The volume buttons are the ones on the left.
Make sure that the input is set to TV to change channels. Then you need to program the available channels, access the Menu and navigate to Setup (left/right arrows). Press Input to enter this sub-menu. Then use the Up/Down arrows to select CH Setup. Press Input again to enter. Now you can set the channel source and let the TV scan for channels that have a strong enough OTA signal or are unencrypted cable channels. These are the top two options in the Channel Setup menu. The details are available in the manual which is available here: http://static.highspeedbackbone.net/pdf/Sharp_LC37SB24U_LC32SB24U_Manual.pdf . For OTA channels, you may need to check the signal strength under the Antenna Setup - Digital option in this Setup menu. OTA Digital signals will not be tuned in if the signal strength is low. It's an all-or-none tuning; amplifiers and external antennas may help. See tvfool.com for details of transmitters and the recommended antenna for your area. (Warning: damaged amplifiers can become filters and block the signal on some channels. Replace the amplifier if it is damaged.)
If you look to replace your original remote with a universal remote, you'll need one that was programmed more than 6 months after the TV was released. That may be 12/2005 based on the manual copyright date. Look for a remote that has a Menu and Input or Source button and check all of the codes to find one that matches all of the features on your original remote. Amazon has an OEM remote for the LC-32SB24U; remotes.com also has a replacement remote available that has been programmed for the TV. (On remotes.com, search for the LC32SB24U.)
I hope this helps.
Oct 26, 2015 | Sharp LC-32SB24U 32 in. LCD TV
ILO LCD Color HDTV does not change channels / volumn...just turns on/off
The symptoms your TV is experiencing is due to a power supply that is not longer providing the 5 volts properly to the circuitry.
It seems to be a common failure on these TV sets.
Apr 29, 2008 | iLO 3200 32 in. LCD Television
I have a Insignia 32 inch LCD TV Model number NS-LCD32. It recently started displaying no inputs. The backlight comes on but no inputs/ no sound. Green lines display if you press the menu,input, channel...
The first troubleshooting step would be to measure all the voltages from the power supply to the other circuits boards specially the 5 volts going to the main board. If you have the following: Insignia 6HA0112010 Power Supply, check FU502 for open conditions.
If all the voltages appear normal, then the main board should be replace since is hard to find individual components for a component level repair.
Let me know if you need further assistance.
Aug 21, 2010 | Insignia 32" 720p Flat-Panel LCD HDTV
Orion TVD2710. Lost remote, can't change signal input
I would suggest you try to find a universal remote that has an "input" or "source" button and program that one to your tv. By pressing the "source" or "input" button, it will change the input to the tv. I hope this helps! -Der Strom
Apr 06, 2010 | Orion STV2763 27" TV
Tv channel is automatically changing
sounds like it need some cleaning , or main board might be disaligned , open it and take a look at the plastic buttons that touches the main board switches , good luck , AJ
Oct 24, 2009 | Televison & Video
Am i able to get into the menu of small orion tv without a remote
Try holding down both volume buttons on the front of the set. If the menu comes up use the the volume and channel buttons on the front of the set to navigate in the menu. I hope this helps you.
Mar 23, 2009 | Orion1934 19" TV
Time TV
By saying that volume and picture controls work, do you mean you can access the TV's onscreen menu? If so, you may need to re-scan for available channels if you are using the TV's internal tuner. If the memory of those channels has been lost, the TV does not know where to "look" for a signal. You may also need to perform a power drain:
1. Unplug the product's power cable so that the device is not grounded to the house. Do not simply turn off the power-bar if one is in use.
2. Press and hold in the products power button for 1 minute to release the retained electricity from the capacitors and circuit board.
3. Plug the product back into the wall outlet rather than a power-bar to rule it out of contributing to the problem and turn the device back on. After this step, try the channel scan again if it didn't resolve the issue the first time.
Oct 16, 2008 | Televison & Video
Channel memory reset
Bryan,
Usually the menu can be accessed from the buttons on the console, sometimes by pressing a "menu" button but other times by pressing both Volume or Channel (+ AND -, UP AND DOWN) buttons simultaneously. Menu levels are usually selected with one or the other of Volume or Channel, and toggles/selections with whichever doesn't do the levels.
Nov 05, 2007 | Sharp 27K-S300 27" TV
Cannot access menu
The tv has lost the menu,in order for the menu to come up in the screen it needs horizontal and vertical sync,the syncs come from the secondary of the flyback and from the vertical Ic.Is rare but We have seen it happen,sometimes you also have an Ic called character generator and it could be bad.You will need the assitance of a servicer for this problem because there are voltages to measure and signal to trace.
Oct 01, 2006 | Zenith SY1931SG TV
Philips 55PW9363 55" Rear Projection HDTV-Ready Television Logo
32 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
