Question about Microwave Ovens
Ge microwave - making noise - Microwave Ovens
  • 4 more comments
  • Anonymous Sep 27, 2008
    GE microwave is Making lound droning noise when heating up. It still heats up.
  • shaffer3028 Oct 29, 2008
    My microwave starting making a buzzing noise and then had a slight burning smell. Any thoughts?
  • smw21cn Nov 23, 2008
    My GE Microwave make noice when heating up
  • keddp Dec 07, 2008
    The microwave started like normal, but after about 5 seconds it started to make a loud humming sound,then made a little popping sound and had an electrical smell. Could this be a manufacture's defect with a product recall?
  • jfbuch Mar 12, 2009
    when the door is closed it makes a buzzing noise, the micro still works and the noise goes away when turned on and used
  • miladykim May 16, 2009
    My microwave (GE Profile Spacemaker LX1800) also makes a noise and has a slight electrical burning smell.  This usually only happens when there is a little item in the oven.  Such as a bag of popcorn or bite sized items.  Larger items cook fine and no noise is heard.
I have a GE counter top microwave oven. When the oven starts cooking (the magnetron turns on) the oven makes a harsh buzzing noise. What is wrong and what should be done?
Posted on Jan 18, 2010
  • Kathy Liebler Hammill Feb 18, 2014
    Mine does loud buzzing too. I have tried moving it, banging on it, I even called GE. They said I shouldn't be using it. Is that a ploy to get people to buy new ones when it isn't truly necessary?
If the microwave works fine it is most likely two interior panels or exterior panels touching. See if you can locate an area stops the buzzing when you push on it. Mine buzzed very loud at start up and I ended up solving it with a small piece of insulation between the outer case and the front bezel. I like the zero dollar fixes.
Posted on Apr 08, 2010
  • John Godd Nov 27, 2012
    Interesting as I have the same problem-outer case not as tight fitting as it should be so vibrates and rattles like hell when oven is on. What did you use as the insulation, as obviously I don't want to use anything that might give off fumes or be a melting/fire hazzard.
Im having the same problem with my one year old Spacemaker. Harsh buzzing sound when heating. Though everything works well. I took the grill off the front of the unit that sits over the door, and turned it on --- no buzzing noise. I put it back on and tightened it down with the three screws that attach it --- buzzing noise back again. Not sure what the solution is. The grille part seems fine.
Posted on Mar 07, 2010
  • Kevin Klinkerfues Jan 07, 2015
    I ended up putting two, one quarter inch, self tapping screws through the bottom, lower side of the microwave. No noise ever again.
4 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Profile Space,aker 1800 microwave is making
You should keep it unplugged until it's fixed. If it's cooking while it should be off, that can damage the oven or even start a fire.
It's either a failed door switch or door switch mount, or a bad electrolytic capacitor on the control board, which we can repair for $39.95.
If you're hearing a fan or motor running, I'd suspect the switch. See this file for help.
If it's a buzz (like a power line buzz) then I'd suspect the board capacitor.
Feel free to contact me directly (and please include your full model number from the tag in or on the unit) for more help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on May 28, 2010
bestdarngood
  • 3037 Answers
SOURCE: Microwave GE Model #JE1640WB - Makes noise when
Magnetron is done. This part heats the food. GE microwaves tend to have them stop working quite frequently. They basically make up the majority of the cost of the microwave, so instead of replacing the magnetron, you would be better off getting a new microwave.
Benjamin
Posted on Jul 15, 2009
  • 4090 Answers
SOURCE: ge spacemaker microwave JVM1330BW002 making noise, food not warm
bad news I am afraid. the heart of the unit has had a coronary and needs a tech to intervene
Posted on Aug 01, 2009
GE JEM25 makes unfamiliar noise when door is closed, noise stops when door is opened.
normally your have 3 problem noises: a) power diodes b) high voltage capacitor c) magnetron see the diagram. i recomend you get help from some qualified service tech for fix it.
God bless you
Jul 14, 2012 | GE JEM25 Microwave Oven
My Microwave is making a loudbuzzer noise when it's on
HI Dianne,
The loud noise you describe can be from two components, I would advice to have the unit checked. The repair could be cheater then replacement, when it comes to microwaves, aftermarket parts are cheaper. I would suspect the magnetron or diode would be the problem in this description you gave above. Some of the GE models had a 10 year warranty on the magnetron, so check your user manual before having the unit serviced, it maybe under warranty for the repair anyways. You can always call GE for a warranty status on your unit as well. Good Luck
Apr 24, 2012 | GE Profile Spacemaker 1.8 Cu. Ft....
GE spacesaver II making loud noise and is not heating up food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jun 04, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacesaver microwave JVM1631WB002- making popping noise
The material is popping as a result of being heated.
Jan 19, 2018 | GE Microwave Ovens
GE SpacemakerXL Microwave oven clicking noise
Spacemaker t/t motors are very easy to change. Removed the screws from bottom of microwave. the bottom panel will found towards wall. Mtr is in very center of unit. Should have 2 wires going to it
Nov 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker microwave JVM1330BW002 making noise, food not warm
Jul 31, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Benjamin
Jul 15, 2009 | General Electric Microwave Oven
GE JVM1650 Microwave Making Loud Noise
hello Frank. Sorry to tell you that the magnetron is going bad and making that terrible noise. Since the inside of a microwave, even unplugged has up to 2000 residual and deadly volts of electricity I recommend either calling a pro or replacing the unit.
Jul 12, 2009 | Microwave Ovens
GE over the range microwave making grinding noise
This sounds like the stirrer. If it sticks or stops, the microwaves can damage or destroy it. You may have a bad stirrer or magnetron. There is an important bulletin that covers these problems. To see if yours is covered, see: http://207.234.249.73/mwd/ge_mw_mag_kit_bulletin.pdf If you need more help, please follow-up.
Apr 30, 2007 | GE JVM1650 1000 Watts Microwave Oven
Microwave Ovens Logo
4,228 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
