Question about Gateway (1531356) DVD±RW Burner
DVDS burn failure
Hi, Can you help me?
I try to copy a DVD and I'm using Power2Go to copy it, and it reads the DVD, then when I put the blank in, it spits it out and says, Burn failed. #oxEB20B9C
  • azapromotion Feb 19, 2009
    After months of successful DVD burning, I have not been able to burn a DVD. I use Nero, Sony DVD Architect, AVS Remaker. None have successfully burn a blank DVD. I have updated the DVD device, and yet I still have the problem. Can you help with this issue. Thanking you in advance. -Azah
    Novelist:
  • 104 Answers
Mmmm... to hard to know what is happening, as many things in computers that problem could come from many sides.
First advice: USE NERO (JUST NERO) its the best for windows.
You can get NERO for free on the net, at least just a trial version.
Second advive: make sure you have at least 512 MB of RAM
enough free HD space at lease 5 giga for a DVD.
Do this first to ensure your problem is not the software youre using... I will assume at this point that your operative system is running perfectly, because if not, your problem is just there.
And I will also assume your CD/DVD unit is 100% OK... otherwise nothing will help.
Install NERO and try burning at a low speed (8 maximum)
if you have problems... I would need much more information on this matter and you might need to spend money in a new recorder.
gluck
Posted on Mar 14, 2008
What is Power2Go and do I need it
That depends. What OS are you running? What type of files will you burn to disc (and what capacity disc)?
The program lets you burn various files to CD, DVD or BD. If you only plan on burning data files, you may not need it. If you burn ISO to create bootable CDs or DVDs, you might find it useful if you have XP. Windows 7 and 8 include a feature to correctly burn ISOs. (I don't remember if that feature is included in Vista.)
If you want to copy optical discs to burn backup copies, this software will also handle that. The Windows built-in software doesn't copy discs with DRM.
If you are compiling your own audio and video and then burning the resultant file to disc, the software is partially useful. (Another program has to do the compiling.)
There are other programs that do the same tasks as Power2Go. Roxio Creator (includes the video editing and playback software in addition to the burning unit) and Nero Burning ROM are commonly advertised options. A review of Power2Go with links to reviews of similar products is here: http://www.pcmag.com/article2/0,2817,2407197,00.asp .
I hope this helps. If you need additional information, please add a comment with your OS and file burning plans.
(I burn more ISOs and data files. Thus I use the Windows built-in software most of the time.)
Jun 24, 2013 | CyberLink Power2Go
The drive plays DVDs and can read doc files, but
This problem is normal and exists with many CD/DVD drives.
On some of the drives, if you put in blank discs and try to open the disc in My Computer or Windows Explorer, Windows displays no contents or a blank disc. Whereas on other drives, you get the error message that you mentioned about incorrect function.
What software are you using to burn CDs or DVDs? Are you able to burn CDs but not DVDs or you can't burn both the discs? Did you try a CDs with a different make/manufacturer? Some drives refuse on some disc makes. Try another disc and another writing speed, or try the lowest writing speed available with your software.
Hope that helps,
Regards,
Raspal
Mar 22, 2010 | ASUS SDRW-08D1S-U USB 2.0 Slim External...
Trying to copy DVD data discs to hard drive, some work, many fail with unable to read errors part way through. Tried copy and paste, drag and drop, tried the Power2Go that came with the HPVista64 bit...
The first thing I thought of is that the discs could be scratched, but I doubt that's the problem.
Another possible problem (although unlikely) is that the discs themselves are bad. Sometimes they come with bad sectors, and don't always work.
Next idea could have to do with the burning process not being as perfect as it could. This could either be because of other tasks running during the burn, or burning at a too high speed.
I see that you said you've replaced the drive, so that pretty much rules that out. However, I do have one last suggestion that may help.
I've found that quite a few people have had problems with the Power2Go software, and that may very well be the culprit.
I suggest you download CDBurnerXP from HERE and try burning another disc. Make sure that when you do it, you have as few processes running as possible and do it at one of the lowest speeds possible. Oh and even though the program has "XP" in the name, it still works on Vista,7, etc.
Hope this helped :)
Nov 28, 2009 | HP HDX16t Premium Series Notebook
Cd burner makes blank cds
try isolating the problem by plugging an external cd/dvd drive via the USB. use this to burn CD/DVD if the process works, replace your laptop dvd drive.
Jul 07, 2009 | Dell Dimension 4600 PC Desktop
I can't burn anything with my DVD/CD-ROM but it reads dvds and cds
first reinstall the operating system and then you use either nero 6 or NTI CD? DVD maker
Jun 01, 2009 | Computers & Internet
Burning problem
Try different brand. Your Drive is a sensitive type and it only accepts some DVD-R brands. Also try DVD-RW disc. I had the same problem but not specifically the exact problem. My drive is cd writer only. Same problem, I just used diff CD-R brand like Imation and Philips and the burning works like a charm.
Jul 26, 2008 | Lite On LITE-ON SOHC-5236V COMBO BK OEM...
Dvd burner question
First off is the drive a read only drive or a Read/write drive? If you look at the front drawer check to see if there is a big RW(read/writable) on the front of the drawer. If it doesn't have the RW then you won't be able to burn discs. If it says RW then you will be able use it to copy DVDs. You accomplish this by using software to copy the disc you're interested in to your hard drive and then using the copy on the hard disc to copy back to a blank recordable DVD placed in to tray.
Jul 23, 2008 | Computers & Internet
My dvdrom drive wont let me access the drive
ITs a dvd rom drive. It will not burn blank dvds
in order to burn, it has to cd-r/cd-rw/dvd-r/dvd-rw. If a drive cannot write to a blank disc, it will eject it. Rom drives read only (Read Only Memory), Combo drives- burn cd's only read dvd's, and super drives both read and write to cds and dvds.
Oct 23, 2007 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Computers & Internet Logo
153 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
