Question about Uniden 5.8GHz Cordless Phone
INCOMING CALLS Phone will ring 1 time & display caller ID, then hesitates (like it is hanging up) phone will ring again & display "INCOMING CALL". Also if I answer on 1st ring I have an open line (can't connect with caller). I hope you can help! THANK YOU!!!!! Cheryl
Not sure it this is a solution for ALL your problems, but...
I had a similar issue: Phone rings, caller ID info displays then seems to hesitate, then displays only "INCOMING CALL."
The issue seemed to be caused by interference with other devices on the same line (in my case, an alarm system).
Tech support had me change a setting on my TRU9466 base unit (this is one of the PowerMax 5.8ghz models). This is how we did it step-by-step on the base unit:
MENU
GLOBAL SETUP
IN-USE LINE SETUP
select LINE 1
switch to TYPE B
This seems to have solved the Caller ID "interference" issue -- my Caller ID now displays as it should. The Tech Support person suggested trying that TYPE A/TYPE B setting on "OFF" if TYPE B didn't solve the problem, but thankfully, it did.
Now Cheryl, it sounds like your issue is more involved than this -- I didn't have any connection problems -- but perhaps they're related -- you might try my solution.
Posted on Apr 18, 2008
I live in the USA. My caller ID stopped displaying incoming calls. Last incoming call on the display says 12.2.14. Even when phone is ringing, caller ID does not display name, number,time,date,etc.
Call Phone Co and see if you are programed for the Caller ID feature. In some areas this feature cost more. Whether or not you are paying for it, it may not be programmed in their switch for you?
Feb 06, 2015 | Vtech 5.8GHz Cordless Phone with Digital...
Uniden cordless phone caller id quit working
Using the Caller ID and Redial Lists
Caller ID (CID) is a service available from your telephone provider that shows the phone number (and sometimes the caller's name) of incoming calls. Contact your telephone provider for more information.
Caller ID list
Redial list
When a call comes in, the phone displays the number and name (if available) of the caller.
The phone saves the information for the last 30 received calls to the
CID list.
When it's in standby, the handset shows how many calls came in since the last time you checked the CID list.
Each handset remembers the last 5 numbers you dialed on it. The redial list is separate for each handset.
Dec 02, 2012 | Uniden Cordless Phone
Incoming call does not show in caller id window all the time. sometimes it simply says "incoming call" without identifying the caller. other times is works proberly.
Caller ID information is sent after the first full ring. If the call is answered too soon, the caller ID information may not have been sent yet. Some of the many and varied networks do not send caller ID information. In this case you may notice that caller ID is missing only on calls from certain callers. Occasionally bad data is sent, causing your phone to reject it.
Jan 23, 2011 | Panasonic KX-TG5632 Phone
Kx tga931ct
I received no ID on my incoming calls. I have ensured caller taking ID is checked "ON" in phone options but some reason I do not have caller ID on my incoming calls. Anyone help is greatly appreciated. Thanks.
Mar 29, 2010 | Panasonic KX-TG1033S Cordless Phone
Caller ID
battery weak change ur battery
Sep 23, 2008 | Astra Meridian 9417 Corded Phone
Can't receive incoming calls
same here... I unlock it but it doesn't received call
Aug 16, 2008 | Motorola Mobility A1200
Caller ID
Does this happen for all incoming calls? Some phones have their caller ID hidden by their network service.
May 15, 2008 | Panasonic KX-T7730 Corded Phone
Caller ID
if you are putting 1 then the area code , just put in the area then the number and nt the 1 digit this should help
Feb 05, 2008 | Motorola Mobility RAZR V3
How do I view caller ID?
The KX-T7731 is a proprietary system phone. You have a Panasonic phone system. Caller ID is transmitted between the first and second ring but the phone system itself is the only part that gets this information. The system has to be compatible for caller ID and it has to collect the caller ID data and send this information to your phone(s). Your phone can be used on many different Panasonic phone systems. The phone's part number does not help you. First thing you need to do is find out what system you have and if it has caller ID. The phone system part number should start with KXT like your phone.
Sep 17, 2007 | Panasonic KX-T7731 Corded Phone
Uniden 5.8GHz Cordless Phone Logo
377 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
