Question about Samsung 793S 17" CRT Monitor
VERY DARK COLORS ON THE SCREEN..
TESTED THE VOLTES ON THE CRT PINS FOR THE RGB VOLTS WAS 46 V ! THE SERVICE MANUAL READ IS 10 VOLTS ON THIS PINS..PLS HELP ME
HAZEMAWAD71@YAHOO.COM
  • hazemawad Mar 09, 2008
    thanks a lot ,,i will try this tips thanks for responsing fast
Signal cable menu block
Posted on Aug 29, 2010
  • 151 Answers
Check power section the brightness control transistor could be open.The voltages are ok on rgb.check heater voltage
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Posted on Mar 08, 2008
2002 Town and Country. Why does it have a rough idle, dies when stopping, has sluggish power, and sounds terrible?
Suspect throttle positioning sensor (TPS)...can be tested...need a meter set to read 5 volts DC...Tps is located on throttle body...it has a three wire connector with wire colors: Brown/Orange...Dark Blue/Dark Green...And Pink/Yellow...Engine off...Push points of safety pins deep into into rear of in place connector PLUS METER LEAD on Brown/Orange wire and NEGATIVE METER LEAD into DarkBlue/DarkGreen...Set meter to read 5 volts...Start engine...At idle (Yes, I know it is running rough) then read meter...RECORD READING...Next rev engine to full throttle...RECORD READING...First reading must be .08 volts...Second must be 4.5 volts...If second reading is less than 3 volts...example 2.4volts TPS is culprit...Replace TPS...all readings OK? Let me know...saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Jun 23, 2015 | Chrysler Cars & Trucks
There are re-trace lines across the CRT.
check the G2 ,if to high retrace lines wil be vissable.If ok check the RGB,12V on picturetube panel.
Are the lines in one collor then check the circuit of theat collor
Jul 27, 2009 | Televison & Video
Why is my truck 2003 dodge dakota 4.7 v8 magnum running rough i dont know what else to do
Lets not change any more parts in the hope problem will be solved...Lets trouble shoot...Most probable cause is the Throttle Positioning Sensor (TPS)...It is located on the throttle body...Has three wire connector: Wire colors are Orange, Orange/Dark Blue, and Black/Light Blue...If you have a wee bit of experience with a volt meter here is test procedure...Leave TPS connector in place...Take two safety pins ...Push one into rear of connector into Orange/Dark Blue and other into Black/Light Blue...Set meter to read 5 volts...Clip + meter lead to Orange/ Dark Blue pin and - meter lead to Black/Light Blue...Start engine...Meter must read .08 volts at idle...Attempt to increase throttle as high as it will go...Meter must read at least 4 volts...If not TPS is the fault...Send results...saailer
* See picture of TPS
Aug 10, 2014 | Cars & Trucks
Intermittent alternator
Hi Denny, perform the following tests:
1. Fill acid type batteries to proper levels.
2. Charge battery overnight at 1-2 amps you need 12 volts or better after charging.
3. Make sure all connections are clean and tight especially the negative cable at both ends.
4. Hook up volt meter to battery and start engine, if meter falls below 9.5 v replace battery.
5. With engine running at 3600 RPM battery should read 14.3-14.7 volts if not continue tests.
6. Unplug voltage regulator from alternator at crankcase by front of primary cover.
7. To test voltage regulator go to: https://www.youtube.com/watch?v=F8EjV0IjW9Q
8. With ohm meter, one lead grounded, touch alternator pin meter should read infinity, if not replace stator.
9. With ohm meter, both leads touching alternator pins meter should read 0.1 to 0.2 ohms on 1989 and later models. 0.2 to 0.4 ohms 1988 and earlier models, if not replace stator.
10. With volt meter set on AC scale, both leads touching alternator pins meter should read
16 to 20 volts AC for every 1000 RPM'S 1989 and later and 19 to 26 volts AC for every 1000 RPMS. If not replace rotor. Good luck
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Sep 09, 2013 | Harley Davidson FLHTCUI Electra Glide...
Motorcycle is not starting without battery
Hi, Abhi27_2008 first perform the following tests:
2. Charge battery overnight at 1-2 amps you need 12.5 volts or better after charging.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Hook up battery positive cable, then with your multimeter on the milliamp scale connect one lead to the negative battery post and the other lead to the ground cable. Meter should read 3 milliamps or less, 10 milliamps with a radio, 15 milliamps with radio and CB. If your meter reads higher you need to isolate the circuit by pulling fuses and circuit breakers one at a time and observe meter for a drop in amperage then get out your test light and track down the short in that circuit.
5. Hook up a voltmeter to the battery and start the engine, if meter falls below 9.0 volts while cranking you need to perform a proper load test on the battery and replace if necessary.
6. With the engine running at 3600 RPM, the battery should read 14.3-14.7 volts if not continue tests.
7. Unplug the voltage regulator from the alternator at crankcase by the front of the primary cover.
8. To test voltage regulator go to https://www.youtube.com/watch?v=F8EjV0IjW9Q
9. With ohm meter, one lead grounded, touch alternator pin meter should read infinity, if not replace the stator.
10. With ohm meter, both leads touching alternator pins meter should read 0.1 to 0.2 ohms on 1989 and later models. 0.2 to 0.4 ohms 1988 and earlier models, if not replace the stator.
11. With the voltmeter set on AC scale, both leads touching alternator pins meter should read 16 to 20 volts AC for every 1000 RPM'S 1989 and later and 19 to 26 volts AC for every 1000 RPMS. If not replace the rotor.
For more information about your issue please visit the websites below. Good luck and have a nice day.
How to test and repair the charging system on scooter
How To Test Stator
The Ultimate GY6 Starter Ignition Troubleshooting Tutorial
Top results matching Bajaj Discover service manual Scribd
Bajaj Discover 100M 2014 service manual DOWNLOAD FREE FULLMANUALS COM
Aug 07, 2012 | Bajaj Discover DTS-I Motorcycles
My Sony TV kv32s22 has a problem. It has audio but no video. There isn´t oscilation of the flyback at firts it turning on but now the red led is flashing all time. I look the pin for 9 volts has 8.2V...
Just moved my mitsubishi big screen from one location to another. The tv wont communicate to the remote and the tv will not resond manually. Pls help
Jan 08, 2010 | Sony KV-32S22 32" TV
Faint lines show up when i get dark screens in movies
First check what color of faint lines comes then reduce Screen Volts in TV of that CRT (tube)
Take off lower front cover, speaker grille of TV, there you will see focus control block that has 6 control knobs, upper 3 knobs are focus adjustment of red-green-blue CRTs and lower 3 knobs are screen volt controls for red-green-blue CRTs. Turn screen volt control knob CCW to reduce screen volts of desired CRT.
Put TV on any free AV input so screen will be dark enough to adjust screen volts.
Thanks.
Aug 28, 2009 | Sony KP-57WS500 57" Rear Projection...
0 volts on pin 9 of the flyback
Base on the service manual information, yes IC561 could be defective.
You did not get the +15 volts because the TV failed to power up and the majority of voltages are coming from the flyback transformer.
Aug 17, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Split screen and dark colors
Good Day, scharania;
Try all of these: 1).HORIZONTAL PULLING AND TEARING, MAY ALSO HAVE VERTICAL ROLLING OR VERTICAL BLANKING BAR LOCKING IN THE MIDDLE OF THE PICTURE. CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 (9-VOLT REGULATOR) ON THE SIGNAL PCB. 2). CHECK C2P08 100 UFD 16 V OFF PIN 3 OF IC2P03 (3.2 VOLT REGULATOR) ON THE SIGNAL PCB. 3).
CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB. Good Luck, big IRISH.
Jul 30, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Green screen
replace the capacitor 10/250 volt or all 250 volt capacitors around the plyback section. and check also the supply of RGB it is 180 volt.
Oct 24, 2007 | RCA 20V500T 20" TV
Samsung 793S 17" CRT Monitor Logo
56 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
