Limiting max volume on a Philips TV ??
I need to make a limitation for the maximum volume on my TV. This means that how much you ever try to go louder with the buttons both on the remot and TV, the volume needs to stop on a preset value. Is this possible ??
I've heard about a "hidden" menue or something where this is possible.
Kind Reagrds/ Lasse
  • 492 Answers
This is usual done by a volume limiter. There are many tvs that have them but if it is not displayed in the sound settings menu I would safely say that the tv does not have this feature.
Posted on Mar 07, 2008
2011 115hp 4stroke runs strong to 3800 rpm but won't throttle up any higher. Compression is good, injectors have been cleaned and new plugs.
Nearly all the things that could limit the maximum revs of a mechanical unintentional nature would probably cause the power to reduce as the maximum rpm is neared so acceleration would similarly reduce and if climbing a hill the maximum would never be reached.
If your description is accurate and the engine produces normal power to 3800 without tapering and won't go any further it is something only electronic rpm limiting is capable of rather than the usual culprits of strangled intake, strangled exhaust, insufficient fuel or timing problems. Sometimes it was something as simple as the throttle butterfly not opening fully.
Checking the injectors is only half the testing the fuel system should have - the fuel pressure and delivery volume and regulator function needs to be checked.
Opel once made an engine of 1.4 litre and over time it was stretched to 2.0 litres and beyond. That engine pulled strongly until it reached a ceiling of about 5400 rpm, less for a high mileage model. It was impossible to make the intake ports large enough or to maintain a sensible shape to the ports which made the rpm self limiting and was my only experience of what you describe in over 40 years. In all other cases of limited rpm the power always tapered because of external faults.
Feb 24, 2018 | Cars & Trucks
Is it possible to limit the volumn so that it cannot be put above 33 on the scale either from remote or on side of TV? Tried unlocking parental control, setting volumn and then relocking. Didnt work
volume limiting is self defeating because of the various volumes from different shows and different section of the shows. so there will not be a volume limiting switch/ mode on your set.
Oct 08, 2013 | Televison & Video
Hi! the M.vol does not get above 6db.. how can i fix it?
Your receiver has a customizable setting for volume limiting control, up to +18dB maximum.
Find your system setup button either on the front panel of the receiver or the remote control and press it, then press enter. On the display it will show number one, a two and a three. 1 is for speakers, 2 is for input and 3 is for option. You want to select number three.
Use the right arrow key to highlight number three with the cursor and press enter. Use your up or down arrow key to select the next item that appears on the display in a list. The first thing listed is the setting for the volume limit control. Use your right or left arrow key to select a limit up to 18dB which is the maximum, or select off, which is also the maximum. Then press enter.
Aug 20, 2011 | Denon AVR-1507 Receiver
Low sound, at maximum volume
possible reasons
is there a volume limiter switched on in the menu?
Is whatever is feeding the amp at the correct level, are you feeding from line out or does it depend on tv's volume settings?
Is it distorted, if not the amp is probably ok
Mar 07, 2011 | Philips Audio Players & Recorders
Remove lock from volume setting
Limit the volume Listening to loud sounds for longer than a moment can be harmful to the listener. You can set the volume level of the player to suit your preferences: 1 From the main menu, select Settings > Sound settings > Volume limit > Settings. 2 Press Vol- or Vol+ to adjust the level. 3 Press to set. > When you set a volume limit, you can no longer exceed the set volume, even if you press the Vol+ button. To enable maximum volume again, set the volume limit back to maximum or turn off, select Settings > Sound settings > Volume limit > Off.
Thanks for rating Good luck
Dec 22, 2010 | Philips Audio Players & Recorders
Philips HTS8100 owner. Have ben using the soundbar since Decembr 2007 with no issues. it is intgrated with a sony bravia tv. tried to turn on sound (tv input) and have very limited sound. Turned up to...
Same problem with my HTS8100. Little-to-no sound. Sometimes sound comes on very intermittently. I downloaded the software patch from the Philips website and installed it. This fixed the sound problem for about a week, then the problem came back. I'm not sure what else to do.
Dec 22, 2010 | Philips SoundBar DVD Home Theater with...
Crate bass amp bt220 limit led is flashing with the volume only at half
You can reach the limiting IRRESPECTIVE of where the volume control is set when you have a guitar or other source that has HIGH output.
Guitars that have battery in them with internal amplifiers are an example of a high output guitar. Plain inductive pickups may require the volume control to be set at say 70% to reach limiting.
Please NOTE that the volume control is NOT linear, but is an "audio taper".
Limiting means you are probably driving it too hard. Many learn the hard way when speakers and thee power amp fail.
When the cone is driven too far beyond the pole pieces of the magnet, then the IMPEDANCE of the speaker becomes relatively low and can damage the power amp. The limiter tries to prevent this by sensing the current and or voltage and will back off the gain internally. This causes distortion when it happens.
Dec 14, 2009 | Crate Music
When the volume for my TV is at 100% the tv is almost too quiet to hear on some stations. Can this be fixed?
are you using any kind of digital cable or satellite box?
If so check and make sure all the seeting in the box is at 100% and set to FIXED
Also some tv's have an option for sound limiting as far as max volume and steady volume.
Make sure those are disbled.
Jul 16, 2009 | Insignia Televison & Video
CANNOT FIND UNLOCKING CODE FOR VOLUME LIMITER ON IPOD CLASSIC BLACK 120GB
this should help you below. If you have set a password on the volume limit and forgot the password please let me know cause you will then have to remove the password or restore the device. This is only one step in trying to remove the volume limit it may work or it may not and you will have to use another method. But please tell me if this method works and if it doesnt i will instruct you on where to go from here. To set the maximum volume limit for iPod classic: 1 Choose Settings > Volume Limit. The volume control shows the current volume. 2 Use the Click Wheel to select the maximum volume limit. You can press Play to hear the currently selected song play while you select the maximum volume limit. 3 Press Play/Pause to set the maximum volume limit. A triangle on the volume bar indicates the maximum volume limit. 4 Press the Menu button to accept the maximum volume limit without requiring a combination to change it. Or, on the Enter Combination screen, set a combination to require that the combination be entered to change the maximum volume limit. If you need further assistance please feel free to follow up with a comment and i will be here to
assist you. If this assisted you please feel free to rate the comment. thanks and have a great day.
Jul 15, 2009 | Apple iPod classic MP3 Player
Televison & Video Logo
624 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
