Question about Sylvania Televison & Video
When a tape is inserted it plays for a few seconds and then the vcr turns off
  • Sylvania Master
  • 5,686 Answers
Sounds like a mode switch problem. You could try cleaning it with Servisol Video 40, see image below. It may have to be replaced if badly worn.
Posted on Mar 10, 2010
SOURCE:
Video on my Sony VCR (SLV-780HF) goes gray after playing a tape a few seconds. What could be the problem?
The only real cure will be to clean the video head. If that doesn't work then I'm afraid that whatever recorded you EP mode tape was not set up well tracking wise. So other machines struggle to track the tape. Some VCR's will only playback SP or LP tapes and don't have EP mode. In which case you should check to see if these VCR's can play the EP tape and if they can't find one that can.
Dec 06, 2012 | Sony Televison & Video
My emerson EWV603 vcr. When I turn it on or when I insert a videocasette, the screen is blue. How do I get to the menu stuff so that I can program my vcr?
Sounds like your VCR & TV are on different channels.
The VCR's ouput is channel 3 or 4. Try turning your TV to either channel and see if you get a picture. OR try playing the tape and after 2 or 3 seconds, push the play button again for a few seconds to change the VCR's ouput channel.
Oct 08, 2009 | Emerson EWV603 VHS VCR
Vcr tape plays for a few seconds then powers off
remove cassette mechanisum and clean all the sensor's
Sep 28, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Panasonic VCR 7350 displays error messages and cant insert tape
There is either some damage to the mechanism or the mode switch is faulty. If you know what to look for taking the top cover off might show what part of the mechanism is damaged.
If it is the mode switch then it will need to be replaced. This can't be done without the service manual as the vcr needs to be set up. And they are never set up in the eject position.
Sep 27, 2017 | Panasonic AG-7350 VHS/S-VHS playback VCR
Magnavox zv450mw8 Walmart VCR/DVD recorder. shuts off
on vcr's if the tape is hard to turn the tape will sense this and reject the tape. Try to get a tape that you can feel turn free eaiser. I would rewind it to the middle of the tape so each side is equal and it would make the tape run easier. If it runs ok then the unit is bad and is too sensitve to the pull on the tape. This is all designed in the electronics and there is not much you can do about it then get return it if you can.
Jan 01, 2009 | Philips Magnavox DVD/VCR Dual Player
VCR problems
My solution was to call my warranty company. I'm sending it in and getting my money back. They said it would cost more to fix it than I paid for it.
Nov 10, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
What do I do when my Emerson TV keeps turning off by itself?
I had the same problem with mine turning off after 3-5 seconds. After much research I found a suggestion that on some combo units the vcr part could have a power supply cutout if it is not working correctly. I tried to insert a tape and found that the tape mechanism would not accept a tape. I used a little bit of force and managed to insert a tape. I then played the tape forwards and backwards and the power stayed on! I ejected the tape and found the TV then worked just fine. The power has now been on for over one hour. I hope this give you another avenue to try and fix your problem.
Nov 30, 2007 | Televison & Video
VHS player stops
VCR is set with blank tape..Bring up vcr control on TV with television set on Chanel #3, go to menu
Follows procedure for progamming date,time start,time finish,chanel and.speed and single recording.finally click on menu and turn vcr off. Vcr lights indicate set for taping,,.Does no start to tape at requested time and lights indication taping ready stays on ??????
Aug 22, 2007 | Zenith DVR413 DVD Recorder/VCR
VCR plays for a few seconds and rewinds. Now, the VCR plays tape in fast forward mode
Most everyone I know had problems with the tv/vcr combo including myself. I'll never buy one again. I'm sorry you are having the same problem.
Aug 28, 2006 | Quasar VV-2002 20 in. TV/VCR Combo
Televison & Video Logo
26,813 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
