Question about Dell Latitude D600 Notebook
Dell Latitude C510/610 wont turn on
My laptop won't turn on. This is with a fully charged battery and/or the power adaptor. When I press the power button all of the lights (3) come on as do the lights on the right hand side (3 if I'm using the power adaptor) but they only remain on for about 3 seconds. The hard drive doesn't seem to be booting up nor does the fan turn on.
HELP!!!
  • 11 more comments
  • Uplate Mar 07, 2008
    I've tried reseating the memory...not sure where the hard drive is...but I have removed the battery and unplugged the power cord for 15 minutes. None of that has worked.
    Just tried powering the computer with the power cord and no battery...devil...nothing there...
    It was having problems with running really slow...well...much slower than it normally runs.
    I may be mistaking the fan for the hard drive sound that I hear normally when it boots up.
    thank you for your help zzedly....
    Now I'm looking for a way around that damn fan...
    OK...this may sound crazy...but I took the laptop out to the garage and blew on the fan with an air compressor...and the laptop booted up...but once it was on for a while it shut itself off.(The fan never kicked on)
    So...new fan? And is it that difficult to repair myself? (I'm quite mechanicly inclined and not afraid to break what in my mind is already broken) BUT I'd also like to be able to say I fixed the %^&$#&* thing....so any instructions on how to replace the fan would be much appreciated...
    THANK YOU IN ADVANCE!!!!! :)
    YOU ROCK ZZEDLY!!!!
    Thank you so much for your fast, friendly and accurate help!!!!
    A credit to the site!!!!
    Would you mind if I added you...just incase I set something on fire or cause World War 3 with this fan replacement?
    Thanks again for your excellent advice!!!!
  • Uplate Mar 08, 2008
    Had to let you know....I GOT THE FAN OUT!!! Have a new one on order....
    Now....here's to hoping I can put this thing back together....
    I'm guessing thats harder than ripping it apart...
  • Uplate Mar 10, 2008
    ohh I'm worried about the putting all the parts together and making them actually fit....and WORK!! Have the fan on order, so once it arrives I'll attempt the "repair"...I'll be looking here for guidance and praying to the laptop *** for good measure...
  • Uplate Mar 14, 2008
    Ok...me again....replaced the fan...and...nothing...still won't turn on
  • Uplate Mar 27, 2008
    ok...replaced the heatsink and the computer fan...still having the same 3 seconds before it all shuts off...
    what else can it be?
    Yes the fan (cooling not the heatsink) is connected to the motherboard. Double checked that it was connected correctly just in case.
    The screen does not wake up at all in those brief 3 seconds.
    Unfortunately I don't have anyone with a hard drive I can swap with.
    The system does the exact same thing with the power cord and no battery, three seconds and then off.
  • drewster Apr 12, 2008
    Unbelievable, spent numerous hours trying a bunch of fancy highly recommended fixes gleaned from various techy sights in order to breath new life into my company laptop. Being an engineer at a major NW airframe manufacturer, I was in dire need of a fix to keep me from having to go into the plant on the weekend. None of the fancy fixes worked. Then I happened across Zzedly and the nutbag with the compressor in his garage... well the idea intrigued me. Not being paid enough to own a snazzy air compressor, I proceeded to administer pulmonary resuscitation to the laptop... that is to say I gave the fan a ********. It responded favorably and at this moment it is humming along contentedly in that post-orgasmic bliss. All I can say is that Zzedly and the rest of you IT Geeks Totally Rock! p.s. don't tell my company that I gave my computer a *******... it could be grounds for dismissal : )
  • BiGGiE-D-LeB Apr 19, 2009
    well i took it to the guy that fixes comps and hacks stuff so yeah and he said that these comps are too old. i was like wtf man it was better than before now it freezes every second i hate that guy. the little kid drew on the back of my laptop lol im glad it was in pencil or i wouldnt of went there and killed him :P
  • Tygh Duval
    Tygh Duval May 11, 2010
    • Have you tried powering the computer with only the power cord plugged in (battery is not installed)?
    • Did anything strange/different happen around the same time this issue began?
    • When the computer did work, and you turned it on, was it normal for you to hear the fan start? It's possible that if the CPU fan is shot, the system knows this and will not allow the system to boot (for fear of things overheating).
    Sergeant:
  • 300 Answers
I have more of a suspicion of the CPU fan than the hard drive, right now. If a hard drive goes bad, the system will wake up, go through it's POST (Power On Self Test), and then tell you there's an issue with the hard drive. If the CPU fan goes bad, the system turns on, sees an RPM of 0 on the fan, then turns back off. That hypothesis also fits in with the slowness you were seeing. If a CPU starts to overheat (because the fan isn't running well), it will start to throttle the clock speed down in an attempt to produce less heat.
Unfortunately, it sounds like your laptop may be in need of a professional repair facility.
Posted on Mar 07, 2008
  • 2 more comments
  • Tygh Duval
    Tygh Duval Mar 07, 2008
    I take no responsibility for any harm you might do to your computer during this repair. But if you want to go for it, let's rock!
    Here are the instructions on how to remove the fan.
    Here is a link to a place that sells replacement parts (including fans). Click the dropdown menu and select "Laptop Fans, Heatsink" and in the other dropdown select your model of laptop. I would highly recommend having the old fan in your hand when purchasing the replacement, as you'll be able to match the exact p/n of the fan.
    You might also try looking on eBay for the replacement, as many times they are much cheaper.
  • Tygh Duval
    Glad I could help! You can add me, if you'd like.
  • Tygh Duval
    Tygh Duval Mar 10, 2008
    Assuming the replacement fan is exactly the same as the failed one, the swap should be easy.
  • Tygh Duval
    Tygh Duval Mar 27, 2008
    So here's my logic. Normally, the laptop is turning on for about 3 seconds, then back off. When you hit it with the compressed air through the exhaust port, it booted up and worked normally for a little while, then shut off. So in my mind, the air is either:
    • Spinning the fan to make the system happy.
    • Cooling something to make the system happy.
    With the replacement fan, one would expect it should spin on it's own now. I trust you, but I have to ask this anyway, you did connect the tiny little connector from the new fan to the motherboard, yes?
    I just have a hard time believing the issue is related to the hard drive or some other device. If that were the case, the system should at least show something on screen and run for more than 3 seconds.
    A few more questions:
    1. Does the screen wake up at all in the 3 seconds it's on?
    2. Do you know anyone with another laptop that you could swap hard drives with, just to confirm (for sure) that it's not the problem?
    3. You said the system will not work with only the power cord (no battery). In this case, does it still start for 3 seconds or does it do absolutely nothing at all?
    New Friend:
  • 4 Answers
I had the same problem on mine and eventually figured out the power board was bad. Replaced the powerboard and it works fine now. have to remover the screen mounts, keyboard and the cover plate to get it out
Posted on Jul 09, 2013
    Problem Solver:
  • 10 Answers
Hi Friends,
Problem with Dell Laptops?
For solutions for your problem you need to visit a site by just Click Here .
For any hardware problem with Dell Laptop you can Click Here
Posted on Jul 23, 2010
Factory problem.Power plate inside loose contact with motherborad.Hard push docking part in same time with power button fix thing.Google this ...You will find whole explanation.
Posted on Aug 16, 2008
Dell c600 latitude when it tries to boot up it says can't find hard drive
Posted on May 22, 2008
  • elmonlis May 22, 2008
    by the way i have a cd with linux on it and it will boot with it
2 Suggested Answers
SOURCE: Dell Latitude C610 Laptop won't turn on
i've been bummed with this laptop.
same thing happens to me - except all my lights come on for a split second then only the power light stays on underneath the monitor - which is black - and nothing else shows any sign of being turned on.
also..
the f, z, n, and some other key are broken.
well - they work, but only after several hard hits.
Posted on Nov 08, 2008
Dell latitude 10 st2 e wont boot
Hi voyagerbooks,
Request you to try following the below steps which might help:
    (1)Turn off the computer.
    (2)Remove all the external peripherals like AC Adaptor, flash drives, battery, etc.
    (3)Press and hold the power button for 30 sec which releases the static on the computer (if any)
    (4)Put back the battery and plug in the AC Adaptor.
    (5)Let the computer charge for some time.
    (6)Try turning on the computer.
    If the computer doesn't turn on then check if the computer gives any series of beeps or if there are any diagnostics LEDs shown on it.
    Thanks and Regards.
    Kiran Kumar.
    #iworkfordell.
Apr 07, 2015 | Dell Computers & Internet
The battery of my Dell Latitude D600 is not charging fully. It only runs for 10 minutes when fully charged. Moreover, the battery indicator flashes 4 times red and one time green. Is it the battery problem...
That sounds like a bad battery. Be sure not to leave charger plugged into your computer while not plugged into power or the power switched off. That will really kill your weak battery and then you won't have 10 minutes. You can live okay with a battery like yours but if you ever need to replace ram or do a serious BIOS update the bad battery will not alallow it.
Sep 12, 2012 | Dell Latitude D600 Notebook
Dell Latitude D830 Laptop Computer PC Notebook Battery wont charge
if the laptop is working with the adaptor connected then the battery is out....
install a new battery....
Nov 18, 2010 | Dell Latitude D830 Laptop Computer PC...
Dell laptop wont turn on. battery only works if it is already charged and it doesn't run on A/C power.
It means that is something wrong, most surely with te AC/DC adaptor. Try with other compatible adaptor or take the laptop to service.
Nov 02, 2010 | Dell Latitude D505 Notebook
Won't turn on. Battery is plugged in and lit. n
Try removing your battery pack. Then connect the power adaptor (even without the battery) and connect is directly to the power outlet. If it powers up, then the battery pack might be defective or totally drained.
If the battery is just totally drained, simply place the battery to the laptop. Do not turn the laptop on. Plug the power adaptor to the laptop and plug it to the power source. If you see that the charging LED is blinking in your laptop, then just leave it charging up to 5 to 8 hours.
Never use a laptop on battery mode while it is plugged in to a power source. This is the number 1 reason why laptop batteries don't last longer.
Jun 06, 2010 | Sony VAIO Notebook
What should I do if my Dell Latitude Tablet won't charge? It was charging the other day. I turned it off. When I turned it on again, it says its on AC power, but the battery is not charging at all. It has...
try unplugging the laptop.... turn the power off... take the battery out ... insert the battery ... turn the laptop back on and plug it in.... make sure you have the battery snug... If this doesn't work you can take the battery into a battery plus store for testing ... it might be that your battery is shot... these things happen
Oct 16, 2009 | Dell Latitude XT2 Tablet PC Notebook
BATTERY PROBLEMS?
Hi
Latitude D620 battery module has a battery charge tester. First remove the battery or turn the laptop over and press the battery icon and the note the battery LED indication.
If there is no LEDs lite, shut down the laptop, connected the power Adaptor, install the battery and check if the battery charge LED lites up.
If it doesn't double check the power Adaptor. Latitude D620 is rated to use a 90W Adaptor. There is a 60W Adaptor (looks very similar to) but this is for other Latitudes and AMD Vostro systems.
If the Adaptor has the correct rating, then check below for more info;
1) [Very Likely] The battery may be faulty or end-of-life and needs replacing. Check the battery connector on the Latitude and battery itself for any broken or bent pins or bits.
2) [Possible] You have the wrong power Adaptor or the Adaptor is faulty. This however would not explain why the battery is undetected.
Start up the Latitude into System BIOS (F2). Under System > Battery information check the battery and AC Adaptor status
If the Latitude D620 has warranty you may open a warranty claim with Dell Support.
Mike
Apr 02, 2008 | Dell Latitude D620 Notebook
could it be your hard drive...... and have you tried getting into the bios at all.... if you can get into your bios, change your boot order to cd drive first, install your os disk and try doing a repair . if that dont work try a new hard drive.
Mar 14, 2008 | Dell Latitude D600 Notebook
Dell latitude D600 battery charge light flashing
my suggestion is that you allow the batteries to fully recharge(which only happens when the computer is fully off, when the battery is deep discharged.
that will take around 6 to 10 hours each..
Mar 10, 2008 | Dell Inspiron E1505 Notebook
Dell Latitude D600 Notebook Logo
1,789 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
