Question about Canon imageCLASS MF5550 All-In-One Laser Printer
Alarm will not clear "Supply Rec. Paper Tray: LTR, their are no jams and the cartridge is installed properly. MF5550
  • 4 more comments
  • Anonymous Apr 10, 2008
    The alarm won't stop blinking and the "supply rec. paper" keeps blinking. Help!!!!
  • Anonymous May 10, 2008
    I have the same problem and its not connected to the printer at the moment
  • Anonymous May 22, 2008
    I have this message "Supply rec. paper"
    Try: ltr, please help me with this problem.
  • Anonymous Jul 17, 2008
    Having exact same problem. Error reads Supply Rec. Paper Tray : LTR but I am in Europe and we use A4 paper size here (and not Letter)...
    Tried everything. Alarm will not clear.
    Canon help line in PORTUGAL not available to take calls for the last 45 mins.....
    I wonder how this is going to turn out! Maybe should have gone with HP or something .
  • azucenaretam Oct 27, 2008
    the alarm will not clear, it says supply rec. paper tray ltr
  • Pete88 Nov 29, 2008
    I have the same problem. There are plastic sensor tabs either on the tray or or the tray housing of the printer. They are flimsy and sometimes prevent or get in the way of re-loading of paper tray and break off. Lack of this tab touching the sensor makes printer incorrectly think the unit is out of paper. very poor design.
Open lest cover - there you will find two sensor - one for Manuel freed sensor and other one is tray paper sensor . Flip the paper tray sensor straight up and put the electric tape permanently. Now your printer will know that you have paper even if you do not have . this is a temporary solution.
thanks
AL
Posted on Apr 28, 2009
    New Friend:
  • 116 Answers
Check paper size
If it is ok go to print job cancel and cancel all jobs
if the error comes while computer connected printing
before click ok go to peinter properties and change input paper size to A4 and out put as match paper size then click ok .
Posted on Mar 21, 2008
One possible solution that seems to work for me is to open the front cover and close it again. Even if you did not need to access this part of the printer.
Posted on Dec 18, 2008
A temporary fix is to manually feed paper, one sheet at a time, through the front. I think my long-term solution is going to be buying a new unit.
Posted on Dec 22, 2008
Light under memory/alarm is flashing red. Window
if the error is change paper size also, under printer properties set the paper size i.e. A4, by default its ltr and these can cause problems.After that turn off and on.
Hope that helps.
If not, send more detailed description.
Aug 27, 2010 | Canon imageCLASS D320 Digital Copier
MF5500 Paper Jams Everywhere
check the paper ,from cassete tray to the drum and exit,on every section you have a sensor,check it ,
Feb 29, 2008 | Canon imageCLASS MF5550 All-In-One Laser...
Supply rec. paper tray:ltr
1) unplug machine from power supply.
2) Under printer properties, select custom paper size and set it on A4 if you use A4.
3) Power on the machine and then try to print.
Hope that helped
Jun 29, 2010 | Canon imageCLASS D320 Digital Copier
Machine won't print, copy or receive a fax
With red button stop the copy, or switch off and on.
If you print on this unit make sure that you did choose a right format of paper (A4,A5,...)
You can change the format ap printer properties or preferences
May 21, 2009 | Canon imageCLASS® MF6550 Laser Printer
Supply Rec. Paper tray will not clear even with a whole ****
Ok try this - switch the machine off at the mains, empty the paper tray. Push the paper tray back in and switch on the machine with no paper in it. When it's finished warming up it should tell you the tray is empty. Then put paper in. This will usually clear it.
Jan 24, 2009 | Canon imageCLASS MF5550 All-In-One Laser...
"Supply Rec. Paper Tray : LTR"
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 07, 2009 | Canon imageCLASS MF8180C All-In-One Laser...
I cant recive any fax
Sometimes the plain paper in the tray underneath upsets the whole machine.
Open up the top of the machine, as if you were going to change the toner cartridge. Pull out the cartridge carefully to mae sure that there is not a piece of paper jameed underneath. Replace the catridge and close the top of the machine. when you close the top 'door' the machine will make a noise as if it is resetting itself - the 'jam' display may or may not clear at this point. Next, pull out the paper tray. You will need to stoop down to look into the gap where the tray normally sits. If there is a piece of paper jammed at the back this will need to be carefully removed. If you pull it out make sure there a re no fragments left int he machine - you can check this by oepning out the piece of paper removed and see if there are any pieces missing.
Finally, if all is clear, replace the paper tray (it would be worth topping up your supply of paper as the 'jam' message sometimes comes up when the machine has a low paper supply.
Hope this helps.
Sep 08, 2008 | Canon FAX-L350 Plain Paper Laser
Msg:supply rec paper
Ya, I had that same problem too; I was printing something that was over printing margins, and then i had the message "supply rec. paper......" on the lcd screen. I ended up fixing the problem by clearing/canceling all the documents i was printing on my computer, and clearing/canceling all the documents saved inside the MEMORY OF THE PRINTER (note the green light with the "memory, in use" which means it's probably still trying to print the document that's too big, so it wont print anything else). (<--- not sure if that was your problem, but it was mine)
Anyways, to clear the memory inside the printer, i pressed the "status monitor" button located to the left of the "B&W start" button, and then i scrolled over to "print status, select job to cancel" and canceled all jobs, and then once i canceled all jobs, the alarm disappeared, and it was fixed XD
Feb 13, 2008 | Canon imageCLASS MF8180C All-In-One Laser...
and PLEASE HELP
Make sure you check both paper sources, the side tray going empty will cause your alarm to go on
Apr 25, 2007 | Canon imageCLASS MF5550 All-In-One Laser...
Won't feed the paper
the problem with your machine maybe that the default paper size programmed into your machine. My guess is that it is set to legal size{ 81/2x14} Get your owners manual out and see how to program the paper size in the user settings sections.
Jan 18, 2007 | Canon imageCLASS MF5550 All-In-One Laser...
Canon imageCLASS MF5550 All-In-One Laser Printer Logo
1,006 people viewed this question
old marine
old marine
