Question about GPS
Confused #1 tom tom not charging or wont turn on was plugged into computor. My tom tom one didn't come with a disc is there a way to get one o guru of the tom tom?
SELECTED WRONG COUNTRY ON START UP NOW I CAN'T CHANGE IT
Posted on Mar 07, 2008
Purchased new tom tom yesterday, excuse my ignorance i am new to computors, where is the ucb plug on my computor to update tom yom
if you are on a laptop the usb ports are usually on the sides or on a desktop they are on the front or back of the unit.
Sep 14, 2011 | Tomtom ONE XL GPS
My tom tom wont turn on where is the reset bitton
look for a small hole on the outside case near the sd card reader. might need a paperclip or pin to poke the microswitch inside the hole. simply clicking the switch doesn't work, try holding it for 5 seconds then try to power up. Common problem with GPS devices, (my mio included) is after being plugged in for a long time, the battery life becomes nil and it relies upon the charger. Check tom to xl for further problem solving. google search TOM TOM XL won't power up.
Mar 14, 2010 | Tomtom XL 340S Car GPS Receiver
Tom tom just stopped working
my tomtom does it now and then. solution is to take it to the car plug the car charger in to it, then press the reset button wait about 3 or 4 secounds and should come back on you don't have to remove your card. plging in to the computor does nothing it needs power when you press the reset botton
Sep 07, 2009 | Tomtom GO 720 GPS Receiver
Tomtom only charges on fast charger base. Why?
if it is not charging in the car then the socket in the car is dead, blown fuse or defective socket..
Aug 09, 2009 | Tomtom GO 920 GPS Receiver
Tom tom wont turn on.
turn device over and look for tiny reset button near to power connect strip. then use a blunt safety pin to reset,this should allow you to then turn it on,this works on 500 ,700 ,900 , 510 , 710 , 910 , hope this helps .
Jun 06, 2009 | GPS
Tom tom go 300 wont turn on
c48ee42.jpg ctf1800
Rank:guru_s.gif Guru
Rating: 85%, 3949 votes
leave on charge for two hours, then with the SD card out hold down the reset button at the back of unit for ten seconds and then the 'on' switch for ten seconds.
Apr 18, 2009 | Tomtom GO 300 GPS Receiver
Unit (tom tom 1xl) turning off
One hour is about the time the unit will run without a power source.
You need to check that the cigarette lighter is working. Check the car fuse.
Check the fuse (one of the six bumps) on the cigarette lighter plug has not blown.
Is the cigarette lighter / Tom Tom lead damaged in any way?
Peter
Mar 01, 2009 | Tomtom One XL GPS Receiver
Confused tomtom
Yes the battery in your TOM TOM needs to be replaced. You can ship it to TOM TOM or go to there site and put the service request in for it. Hopefully it might be under warrenty still
Feb 13, 2008 | Tomtom One Europe v2 GPS Receiver
Tom tom go 910
TOM Tom no charge and will not turn on
STEP 1
Connect your TomTom to your
computer True True (``````````` (``````````` 0 95250 95250 clip_image002.gif via USB and open up your Windows Explorer and go to the drive. (It will be listed as TOMTOM (E) or some other drive letter).
Copy the Yellow Folders one by one to your PC. Ideally, save all the folders under a new folder that you name.
You may find that the folder ttntools and gns may not be copied. This is o.k. if they aren't.
STEP 2
Format your Tomtom via MY Computer.
STEP 3
Copy the Yellow Folders from the
backup True True (``````````` (``````````` 0 95250 95250 clip_image002.gif you made in STEP 1 back to the TomTom.
STEP 4
Open TomTom Home
Click on Upate Now.
Install the latest update onto your TomTom.
Once installed, switch your TomTom off, then disconnect if from the PC.
Thats it. From now on, make a full backup using TomTom Home prior to any updates.
Also note, that copying all the files will take some time.
Oct 29, 2007 | Tomtom GO 910 GPS Receiver
GPS Logo
466 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
