Question about Samsung LN-S4692D 46 in. LCD HDTV
Samsung LNR408DX/XAA Wont power up
I have a Samsung LCD LNR408DX/XAA that is approaching two years old in June. Recently when trying to power up the TV it would fail and not turn on. The TV would make a clicking sound as if it were about to turn on but would not turn on. On some occasions I could hit the power button several times, unplug the power cord and it would then turn on. Now however the TV will not power on and will continue to make a clicking sound about every minute or so. The red light that is on the power button on the TV will flash 4 times, I have heard that you are able to tell what is wrong with the TV by how many times this light flashes? Any suggestions, I am trying to avoid a costly repair? Thanks
  • 5 more comments
  • Anonymous Mar 18, 2008
    I have the same symptoms & it is only 8 months old. It just shut off while I was watching. I have the flashing power led 4 times & clicking sounds. I do have warranty coverage & they will be out soon. I will let you know what they find.
  • Anonymous Mar 28, 2008
    I have the same thing i died slowly first you could unplug and it would reset and now when i plug it back in the light flashes the 4 times and thegoes off. If i wait i alittle while the light comes back on and if i push it the sme thing happens. One other note when you unplug it it sounds like three relays click.
  • Anonymous Aug 15, 2008
    I have the same issue, and trying to find a way to get it fix through Fry's or Samsung. If anyone knows anything please post.
  • ambikagarg Aug 25, 2008
    hi ! i have the same problem. Same TV - please advice
  • shk1979 Feb 22, 2009
    TV wont power up. click,click,click and so on. I left it for 7 hours and it didn't turn on. TV is 2 years old this month. Definately the last samsung product i buy!
  • montana9 Apr 19, 2009
    From turning off the tv from the nite before, it would try to come on; but
    would make a clicking sound in an effort to come on...Once it did, I left it on. I came back later and, it had a funny smell to it. Once I turned it off it has not come back on..This is just another problem I have come to
    realize. My first one was the tv would just go black..But, it would come
    back on if I turn it off and back on. I will not buy another Samsung tv. I
    should have known. I am a Sony person..but, thought Samsung was an
    equel...That was my mistake...that I won't make again.. I have heard
    nothing but bad about there service, even if you have an extended warranty. I'm sorry if any of you have this same problem..Samsung will
    not stand behind there product. I have a model 4093...40' it has a great
    picture..but, if you can see it..its not worth the money.
  • Anonymous Apr 30, 2009
    I have the same problem and the warranty expired two months ago!
    I am an electronic tech and all can say it is obviously a bad design as many people have the same problem. Local service agent req. one week before they can look at it and $78.00 fee to say what is wrong.
    I was to fix and use as a spare and buy the brand new Samsung with Ethernet but I just decided to start using another brand.
    Many of my business & friends ask what to buy in electronics and I will advise against Samsung in the future both here in Oz and Europe
    LA40R71BDX
    New Friend:
  • 7 Answers
I had the same problem with a 52" Samsung LCD. I found 2 electrolytic caps with bulging tops on the power supply board. (see pic). I looked to be the 5v section but I'm not sure. I got replacement at Fry's for $1.90 each. All is well!
Ahwatukee Al
Samsung LNR408DX/XAA Wont power up - ff0cf58.jpg
Posted on Jul 21, 2009
    I followed the suggestion of checking the capacitors on the power board. They were shot so I tried taking the power board to get them replaced. It was really hard to get anyone to help me. Most of the repair shops stated they would not just fix the board and they would only repair it if the whole TV was brought in.     One of the smaller shops did help me out. He stated that this is not a Samsung problem, this is a LCD problem. My Samsung was only the second Samsung he has fixed in 4 months. He stated he has worked on many other brands daily with the same problem. This made me feel better after hearing all the problems and complaints on this thread.     The shop actually replaced all seven capacitors with 35v ones. He states blown capacitors won't be an issue in the future.  He explained that during some busy screen play, especially with HD gaming, these capacitors end up running 12-14v through them and that's what destroys the 10v capacitors. It's like putting a gallon and a half of water in a one gallon container and something has to give.     Sorry, I like to educate and explain things so am a little long winded. In Short: If you are experiencing clicking in your Samsung, Don't throw it out, Don't curse it, and call around to see who will not just replace the parts but potentially upgrade board to prevent future visits.
Posted on Aug 21, 2009
I fixed this problem myself for £10 when samsung clicks and wont turn on its a fault with the power board. To fix this i removed the back pannel(16 screws) and inside is the power board with 6 screws holdining it in. In one of the top corners you can see 6 small ressisters 4 of which were blown on mine due to high tv usage and being left on stand by all the time. I took the board along to my local electronics shop and asked them to replace the blown one put it back together and has worked fine ever since.
Posted on Jan 17, 2009
When I turn on my TV, I get sound, but no picture, any ideas as to what is happening here?
Posted on Jul 08, 2009
Same thing happened to me. The screws holding the hdmi input to the back of the tv weren't there - it came from the factory that way. Samsung didn't care. I found a replacement board on eBay.
Posted on Aug 14, 2008
Anyone know where I can get a replacement board for the 408DX/XAA LCD TV ?. The HDMI port came loose and can not be soldered back on. Thanks in advance for your help!
Posted on Apr 29, 2008
  • 29 Answers
Power supply is bad
Posted on Mar 16, 2008
Is it possible to replace the HDMI input connector of my Samsung LNR408DX/XAA? What is the exact name or code/type etc for replacement of the HDMI female connector of my Samsung LNR408DX/XAA? I seem to...
Re soldering the sockets connections on the pcboard will normally fix this problem. It is unusual to require a socket but possible. Sockets are available through a good electronics outlet, depending on your country.
Dec 27, 2010 | Televison & Video
I have a Samsung LCD LNR408DX/XAA when I go to turn on my TV it sounds as if the TV turns on but its just a black screen. I tried changing the channel and it blinks but doesn't display any channels or...
I am now having this same exact problem.
Apparently there are 4 boards that can be the issue. BUT you must bring it to an Authorized unauthorized service center to resolve the issue. I brought mine to an unauthorized service center and they can not buy the part. My particular issue is a TCOM board on the back of the display which only authorized dealers can buy. In fact if an Unauthoirzed dealer calls up the J&J Samsung parts distributor J&J doesn't even have it their parts inventory so as far as they know the part doesn't exist. which it does you just need to call an Authorized part dealer in your area which you can get the number from 800 SAMSUNG
There are 4 boards unauthorized service centers are allowed to sell 2 PC BOARDS
1 POD PCB
1 Power PCB
When you call Samsung get a CLAIM nuber...
WHAT A PITA
May 07, 2010 | Samsung LN-S4692D 46 in. LCD HDTV
Tele wont turn out on just got light falsing on button and tickin noise
known fault samsung will fix for free they did with mine my tv was 3-4 years old they fixed it june 10 let the experts fix it
Apr 25, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
3 year old Samsung 40 inch LCD TV will not turn on
The problem is 4 capacitors on the power supply board. Just had mine done under warranty. They (Sears) replaced the whole power board but you can get larger capacitors and just replace those for alot cheaper if not under warranty.
Dec 10, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
Samsung LNR408DX/XAA Won't power up. Sound works but as far as the screen, no input/source works. After it died I noticed that the screen was very hot especially the upper Left side. In the dark, the...
It sounds like this is a problem with the inverter boards on the LCD panel. Unfortunately the inverter boards are usually only available with the whole LCD panel and the only way to fix it is by replacing the whole LCD panel. This is the most expensive part of the TV (about $1000) and you will need to take the whole TV apart in order to replace the panel. A new TV of similar make and model will usually be about the same price as the repair.
Nov 09, 2009 | Samsung LN-R408D 40 in. LCD HDTV
SAMSUNG TV WONT TURN ON JUST CLICKS
I just fixed this very same problem. The capacitors are the problem. However, I think that if you have some minimal skills with soldering, you can fix this yourself. You just need to take out the system board, then the power supply parts are on the top right. The bad capacitor(s) will be bulging at the top and possibly have some brown stuff coming out. The ones that go bad are 1000microfarad, 10V, however you can replace them with higher voltage. I got 35V caps from radio shack for 1.59 each. You just need to solder out the bad ones and then put the new ones in and solder. Remember that the negative end goes on the side with the bold black part of the circle on the system board. Then just cut off the extra ends of the capacitors. If you are capable of doing this yourself, you will spend at most 6 dollars instead of however much a technician costs.
Sep 24, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
Tv has no picture
TRY NEW JACKS AND OTHER INPUTS
May 15, 2009 | Samsung LN-R408D 40 in. LCD HDTV
Samsung lnt4042hx/xaa 40in lcd tv wont turn on
I concur with Lightnbaby.... had same problem... my TV LNT4042HX/XAA took 10 min to start sometimes... the capacitors on the power supply board had bubbles on top 4 of them all 10/1000Uf. Samsung wanted to charge $220+ to have a guy come out and fix. J&J parts (samsung vendor) wanted $108 for a new board. I replaced the 4 capacitors for $4.68 and the TV works fine now!!!!!
Apr 14, 2009 | Samsung LN-T4042H 40 in. LCD HDTV
Samsung LN-S4692D 46 in. LCD HDTV Logo
2,391 people viewed this question
Jerry Greenberg
Jerry Greenberg
