Question about Lexmark P6250 All-In-One InkJet Photo Printer
Paper Jam Error for Lexmark P6350
Hello out there,
Can anyone provide a solution for a paper jam error for the Lexmark P6350? I have done everything I could think of including using a can duster to make sure any debris is out of the way, turning it of and on in hopes of re-booting.
I appreciate the time.
  • Anonymous Mar 15, 2008
    Everything is fine. However,it says I have a paper jam when I don't have one. I tried plugging my printer out, but it still says paper jam.
  • Anonymous Mar 27, 2008
    I have an x 4530 that says i have a paper jam, but I can not see where it is. Ids there a way to get into the x4530 through the back?
YEAH TARDS TO THE RESCUE!!
THIS SOLUTION IS COPYRIGHTED AND AN ORIGINAL ALL ELSE ARE FAKE!!!
this is for the lexmark P6250, but it should be the same on the other home printers.
go to this link to watch the video, it works TOO!!!:
http://www.metacafe.com/watch/1316324/fixing_lexmark_p6250_paper_jam/
After help me make money by visiting my website and clicking on the google adsense ads:
http://reidfag.googlepages.com
Posted on May 14, 2008
Clear paper jam error
Have you unplugged the machine and wait a few seconds plug back in?
Dec 15, 2012 | Lexmark P315 InkJet Photo Printer
4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
We had a paper jam in the front of printer but now the printer is saying 202paper jam open rear door. We have done this several times. I do not see any paper jamming the printer anywhere. We have shut off...
Please click on the link provided below. This will show you steps on how to correct the error. http://bitly.com/r09NH8 For further assistance please contact Lexmark Technical Support Center.
Feb 14, 2011 | Lexmark T430 Laser Printer
Paper jam problem
Hello... i have a copier IR6570. If i load the paper from tray 1, it always jammed. But if i load from other trays, everything goes well. Can anyone help me, please...?.
Jul 20, 2010 | Canon imageRUNNER 1370F Grayscale Copier
Error 241.1 Paper Jam. I have reseated the tray
Brand New T652n lexmark printer get a paper jam every time! just opened and haven't been able to print one paper. Doesn't matter if you print from tray one or tray two. It gets stuck right after the rollers pick it up and try to send it to the toner. Any suggestions? I've tried to reseat the toner, plain paper, sized the paper correctly, I've tried just about everything I can think of! I can feed paper manually through the top tray, and it will print. But, just using the manual tray defeats the purpose of the other two trays. Anyone else having this issue?
May 26, 2010 | Dell 5310n Laser Printer
MY PRINTER SAYS PAPER JAM BUT HERE IS NO PAPER IN IT ???
Look for any traces of tiny paper shreds that might got stuck between the rollers. That might be causing the paper jam error. If you could open the back cover, check from there also as those paper shreds might also blocking the sensor.
Sep 18, 2009 | Canon L120 Fax Laser Printer
242.13 paper jam error We cannot find any paper jammed in the paper
hello,
The paper jam error 242.13 can be caused by an actual paper jam in the printer but since you did not find any paper the next thing would be pickup rollers. The pickup rollers can become worn and if they don't grap the paper right it will not more from the tray. There is a sensor that tells the printer that the paper exiting the paper tray and to start the printing. If this sensor does not detect paper when it should be there it gives a "paper jam" error thinking the paper is jammed. Look at the top page of paper for 1 or 2 light gray marks. If you see them then the rollers are the problem. You can see the rollers if you turn the printer on its side and remove the paper tray. To test the pickup rollers you can take off the rubber rollers( they look like white rubber band) from the wheel and turn them inside out, this will work as a temp fix untill you can get them replaced. If you need them replaced we can provide them or you can call a local repair show. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
Over 21 years of computer and printer support/repair
Jun 18, 2009 | Lexmark T644 Laser Printer
Paper jam error on lexmark x9350
Since it is a hardware issue i request you to contact the Lexmark technical support. (US and Canada).
1-800-LEXMARK (539-6275)
Apr 04, 2009 | Lexmark X9350 All-In-One InkJet Printer
Code 200 Paper Jam Error
Hi Mike,
This error can be caused by many reasons, some of them are:
Caused by Paper Stuck Under the Second Transfer Roll
Sporadic or Intermittent 200 Paper Jams
"200 Paper Jam" Resulting from a Possibly Damaged Tray
"200 paper jam" When Attempting to Print from Tray 2
To troubleshoot this problem, please click the links with their respective causes.
Please rate it fixya if it was helpful.
Thank you
Dec 19, 2008 | Lexmark C750 Laser Printer
Paper jam error message
Try this website for a paper jam problem with your printer.
Click Here
May 26, 2008 | Lexmark P4350 All-In-One InkJet Printer
Lexmark P6250 All-In-One InkJet Photo Printer Logo
703 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
