Just receved from on online shop My Sunfly KBOXSF Karaoke Machine . When I set it up every thing plying. but my mic doest'n come through the TV speakers. please help me out how to soleve the this problem. Thank you Troy
I bought my Singing Machine STVD 919 at a garage sale. Said it worked and was still in the box with everything included. Even still had the Styrofoam in it. My problem is the remote control doesn't work. I tried just about everything. If someone knows how to fix this problem I would appreciate it. Thank you.
Cindy
Hi Troy,
Have you inserted the mic in the right input? Make sure it is not inserted in the headphones input. Besides that take a look at the display menu and make sure the volume is turned on.
What devices will the M1 Samson work with? Only Karaoke machines? If I plug it into my laptop will I have to use an ap to do karaoke or could my daughter sing along with youtube videos and that kind of thing?
The music to sing along with apparently MUST come from a disk played on the unit. It appears that the external audio jacks are just to use the unit as either a boombox or to drive a larger sound system. You will have to convert your IPOD music into a Karaoke compatible CD to be able to sing along with it... They probably detect MIC input and mute any incoming signals from the RCA jack inputs,
Any program you wish to use your webcam in will normally require you to configure your webcam software to that program. Make sure the webcam mic is set as default TEST SPEAKERS Right click on speaker icon in System Tray Select "Playback Devices" The speaker icon ( checked as working) and volume level graph should be visible Right click on the volume graph and click "Test" Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC Click "Recording" tab. To set required (webcam) mic as default - click on mic font to highlight and click "Properties" In lower dropbox display "Use this device enable" click 'OK' Click "Levels" tab and ramp up sliders ( adjust to suit later) Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Configure to your karaoke program
Logitech have a good support site - downloads - forums - contacts etc
Browse the photo gallery and click on your webcam to navigate to the support page for your webcam.- older models on page 2 use the link "Still cant find your product" at bottom of page 1
check the manual. also go to their website for answers. look at the back of the machine and see if it does have a connection to hook it up to speakers. also, if you have a mic see if it has a on/off switch. you could have it in the off position and not on; also, check the machine to see if it has a knob to turn to mic.
Hi, got this info from philips customer service. Was desperately trying to get the karaoke function to work for 2 weeks! Plug in your microphone. Press "KARAOKE" button until you see "MIC OFF" text, and immediately press RIGHT button. It will now shows "MIC ON"! "ECHO", "KEY" options will now shows up when pressing "KARAOKE" button repeatedly. However, microphone sound will not be available on digital output, you'll have to use the audio RCA. Happy singing!
