Erasing DVD+RW I have just bought a wharfdale dvd 24HD recorder and am working through the instructions and trying out all the different things but one thing I can't find is how to erase a re-writable dvd could you also explain what HDMI is and does yours sandra mclennan
  • sandramcl1 Mar 07, 2008
    thanks i have erased the dvd on my laptop but will contact customer services as itisn't ideal to erase on a computer
    sandra
  • 492 Answers
HDMI refers to High Definition Multiple Interface. I is a cord made to carry both High Def audio as well as video. Erasing the dvd can be done by a computer software, typically Nero, but I would suggest contacting Customer service to find out if the recorder is capabale of erasing RW media.
Posted on Mar 07, 2008
Have maxell dvd-rw 4.7gb with 2hrs time; i need it to be formated; so that i can record programs so that I can watch them later like the Pat's game because I get up early and work 12hours days
DVD - & + are different writing formats that emerged and are still being argued over as to which is the best so these days to avoid any consumer confusion most manufacturers produce dual format writers that can write in both - and + ( but some writer can only write in minus if its a - drive so if you bought a + disk it woulnt work and vice versa )
CD types and by no means a comprehensive listing....
CDR ~ Write once
CDRW ~ Write and Erase many times
DVD-R ~ Write once
DVD+R ~ Write once
DVD-RW ~ Write and Erase many times
CVD+RW ~ Write and Erase many times
( These have a 4.7gb limit )
Hope this helps you
Sep 13, 2011 | Computers & Internet
What is the difference between a DVD+RW and a DVD-RW.
DVD-RW
It is the re-recordable version of the DVD-R. To use this type of media you will need to buy a DVD-RW recorder. The DVD-RW recorders usually record DVD-R, CD-R and CD-RW media, too. Similarly to what happens to DVD-R, DVD-RW disks can be played in newer commercial DVD players without any problems. Older commercial devices cannot recognize the media, refusing to play the disk. To play a DVD-RW disk, commercial players need the disk to be finished. After finishing the disk, you can only record new data in it by reformatting it, which makes you lose all the recorded data.
DVD+RW
It is the re-recordable version of the DVD+R and everything that was said about the DVD+R is valid for the DVD+RW. Only the newest DVD players play movies recorded in disks using this format. There are recorders on the market that can record both DVD-RW disks and DVD+RW ones. These recorders are called DVD?±RW. Similarly to the DVD-RW, the disk needs to be finished to be played in commercial DVD players, and to record new data in the disk after having finished it requires reformatting it, which makes all the data in it to be erased. DVD+RW recorders are usually capable of reading DVD-RW disks (but not of recording them) and vice-versa.
There you are.
Aug 22, 2011 | Acer Computers & Internet
I have dubbed vcr tape to a Sony DVD-RW disc and tried playing it back through a toshiba player and it keeps coming up Bad Disk. My PC won't even recognise it. When started dubbing the screen displayed 1hr...
Did you say you used a DVD-RW disc to transfer a videotape onto? The reason your PC won't recognise that disc is because the data format on it is a different language to what PCs understand - plus an unfinalised DVD-RW won't play in other DVD players - it is usually an incompatible format.
(DVD+RW discs with titles/top menus created in video mode CAN be played on a PC DVD drive or a normal DVD player as can finalised DVD-R discs (DVD-R discs MUST be recorded and finalised in the same recorder for compatible playback). DVD-RW discs can only be viewed on the unit they were written/recorded on.
The other reason for the 'remaining space' on the disc you describe showing less than 120 minutes is due to a title recently being recorded or erased - unless you format it - the 120 minute / 4.7GB DVD-RW will not show full available space. Erasing titles on re-writable DVDs does not increase space. The same rule applies to unfinalised +R / -R discs (you cannot re-format these to get the space back once recorded - they are 'once only' writables)
I recommend you invest in some DVD-R discs and re-copy your VHS tape to that - then if you are satisfied with the result, title etc., finalise the DVD-R - it will play on any DVD player or PC with DVD support (or it should). These discs are relatively inexpensive to buy just about anywhere.
Final note: do NOT finalise the DVD-RW you recorded (I hope you haven't already done this) - simply format/erase it - re-use it for something else or keep it until you need it.
You can use any brand of DVD, just take note of the format before recording/playing.
Mar 21, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
When I insert a new DVD RW it says can not read disc check disc. The camera will not give me the option to initialize disc either. These are brand new discs that I am using. I can record with older disc...
You have to be sure you bought the correct disks. Look in your manual or your camera. You could use DVD-RW or DVD+RW. They are not universal. You have to use the correct version. You also may want to try a DVD-R or DVD+R. They are cheaper but are not re-recordable. They are not erasable either. A good thing if you don't want to "accidentally" erase your movies!
Dec 18, 2009 | Canon DC210 DVD Camcorder
HOW CAN I ERASE A DVD-RW ?
Be sure it's an DVD-RW.
Some DVD's have the logo, but they only write after the first record.
To erase a DVD, you need to use the recorder software.
For most common like NERO, you can see it here, for example:
You can also do it using DVDInfoPro > Erase/Format DVD±RW
Oct 28, 2009 | Toshiba DR570 DVD Recorder
Error code E 4 54040990
jamesgranger - I think your DVD recorder is still having trouble reading the DVD+RW. It should not have a problem using a DVD+RW many times. Try taking the DVD+RW and put it in your computer. Find it in Explorer, right-click and choose "Erase". Then try to record to it using the DVD recorder again. If it works, you can use this to record, though it might be a pain.
The fact that your machine will record to the +R means that it works. Failing to work (record or erase) on the +RW means it's not reading it well. I would try running the lens cleaner again if it were mine. Also, I would make sure that the unit didn't have a lot of dust in it. If you can, power it off and use some spray-air to be sure there's no dust. You may have cleaned the lens, but if there's a lot of dust inside the unit, it will quickly find it's way back to the lens and you'll have the same problem. Michael
Jul 09, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
DVD player won't record full time that is programed into it
There are two things are likely that can cause this: media and copyright protection. If you use DVD-RW or DVD-RAM, you should be able to copy shows ONE time onto the DVD. If you use DVD+RW, or DVD+R, it may issue a copy protection message just before it stops recording.
If the media is bad, it can also cause the machine to stop recording, I believe. You could put it into a PC and try erasing the contents before re-trying to use it in the DVD recorder.
tom
Dec 19, 2008 | LG DR787T DVD Recorder
Cannot play this disc
The DVD-R130 can only record to DVD-R and DVD-RW disks - it cannot identify blank DVD+R and DVD+RW disks. For recorded DVD disks, the player will play finalised DVD+R/+RW disks without any problem.
May 06, 2007 | Samsung DVD-R130 DVD Recorder
Loading DVD-RW discs
My recorder has stopped accepting NEW DVD-RW discs and ejects them.
There is no problem loading DVD-R (new or recorded)or loading previous recorded DVD-RW, initializing and re-recording
I have tried several different DVD-RW makes. Puzzling??
Nov 03, 2006 | Pioneer DVR-5100H DVD Recorder
Televison & Video Logo
119 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
