Question about Maytag Neptune Washer
Slow cold water
The cold water comes in slow.
  • 55 Answers
Could be clog at valve inlet. Turn off water at hoses. Remove cold water hose to washer. Check for obstructions at washer inlet.
Posted on Mar 07, 2008
Why water comes out slowly?
This can be caused by several problems. The most likely is that your filter needs to be changed. Another potential problem could be that your fresh food side is too cold. There is a water reservoir in the back of the fresh food side to chill the water, if it gets too cold ice could be forming inside it, slowing down the water flow.
Other things to check is water pressure going to the refrigerator, and finally the water valves located in the back of the refrigerator could be starting to fail.
May 30, 2014 | Refrigerators
Cold water come in very slow
check screen for stones or cloges on inlet hose....
Dec 22, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Do the profile washers have a inlet filter for cold water.Hot water comes in fine.Cold very slow
check the cold water hose the screen in the hose to the cold water,selenoid may be clogged or have hard water deposets,just clean out see if this helps
Jul 03, 2010 | GE Profile WPRE6100G Top Load Washer
The colded water comes out very very slow
Change yhour water valve the rubber in side the valve wear out. switch your hoses at the wall and you will see what I mean.
Jun 06, 2010 | Whirlpool LSN1000LW Top Load Washer
The cold water comes out slow . I have already taken the hose off of the back of the washer and the water flows good there. When cold/cold is used the water comes out very slow. When cold/hot is used the...
you need a water valve sounds like you may have hard water and the valve has clogged try switching the hoses on the rear of the washer and see if that corrects your problem
Jan 07, 2010 | Kenmore Washing Machines
My GWL10 fills really slowly. It starts fine with the hot water, then slows to a trickle when it switches to cold but it doesn't seem to affect it if I change the temperature selection. I normally leave it...
sounds like you have a restriction on the cold water water pipe kinked or a blockage turn off cold water and remove pipe from cold tap then turn tap on and see if water is coming through fast enough if it is then the restriction is in the hose or valve on washing machine if not then the restriction is in the cold water tap
Jul 14, 2009 | Fisher and Paykel GWL11 Top Load Washer
Cold water is slow when filling for rinse cycle
Turn off the cold water.
Remove the cold water hose from the machine.
Look inside the cold water inlet on the machine and clean the debris from the screen.
Problem solved.
Feb 22, 2009 | GE WJRR4170E Top Load Washer
Cold water will come in verry slow
if your water pressure is good the water valves are bad.
Dec 14, 2008 | Washing Machines
Kenmore wash macine
its in your cold water line valve to the washer if it works good with hot water the valve are incoming line being blocked when you turn it on the pressure comes in fast then when pressure is gone water slows down so when its off the pressure builds back up it runs fast then slow
Feb 27, 2008 | Washing Machines
Washing Machines Logo
111 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
